Old 04-09-2008, 04:50 PM   #1
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
Default Cel 1445
Hey everyone, My 2000 2.5RS' CEL came on. I went down to autozone to see what code it was and the scanner spat back 1445. I just passed 71k miles. Any ideas on what things I should check before bringing it into somewhere? Thanks
Doc Holiday is offline   Reply With Quote
Old 04-09-2008, 05:32 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
I believe that trouble code is for an evaporative emissions problem.
There is a reflash available for your ECU which corrects a problem in the logic associated with P1445. This reflash also corrects about a half dozen other logic problems. Your Subaru dealer can apply this reflash while you wait. However, I can't guarantee that'll you'll never see a P1445 after the reflash.
Jon [in CT] is offline   Reply With Quote
Old 04-09-2008, 09:57 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
air assist injector solenoid malfunction
Old 04-09-2008, 10:36 PM   #4
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
isn't that P0065?
Old 04-10-2008, 07:31 AM   #5
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
also, my gas cap is tight
Old 04-10-2008, 03:03 PM   #6
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
Bump
All the results I can find from searching seem pretty to be inconclusive, anyone have any info?
Old 04-10-2008, 06:35 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally Posted by Doc Holiday View Post
Bump
What are you searching for? munkis provided the correct meaning for P1445.
Old 04-11-2008, 08:23 AM   #8
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
Yeah, I saw his post, I was hoping someone might have some advice on how to go about fixing this, ease/aprox cost, etc.
Nevermind though, I got a better answer in my regional forum on a related post.
Thanks!
Old 05-14-2008, 02:47 AM   #9
wrxtunerd
Member#: 135287
2008 STi
just pulled this off my friends 01 rs and need to know more about it please!!!
wrxtunerd is offline   Reply With Quote
Old 05-14-2008, 11:43 AM   #10
Subaru Distributors Corp.
Vendor
Member#: 168711
that year had air assist injectors to improve emissions, there is a solenoid that directs air flow to the back side of the fuel injectors. Most likely have a problem with it.
Subaru Distributors Corp. is offline   Reply With Quote
Old 07-09-2008, 12:28 PM   #11
wrx-rex
Member#: 15103
2000 2.5RS
BRP
The dealer just pulled this code on my car - however they checked the air-assist solenoid and claim it's in good working order. Possibly the valve was temporarily stuck?
('00 RS)
wrx-rex is offline   Reply With Quote
CEL 1445- loose gas cap etc w/ meth kit phuhs04 Service & Maintenance 6 05-16-2008 05:41 PM
CEL 1445- loose gas cap etc w/ meth kit phuhs04 Newbies & FAQs 5 05-15-2008 09:09 PM
Anyone with Borla header and CEL, did the ECU recall fix the CEL? Suba_Roo Normally Aspirated Powertrain 14 01-25-2003 12:53 AM
Code 1445 (Check Engine Light) c-shell Service & Maintenance 4 08-12-2002 12:23 PM
CEL or no CEL? chuglobal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-25-2002 03:23 PM
