Old 04-09-2008, 05:25 PM   #1
Roostmonkey
Member#: 173822
2008 WRX Premium
Default 2008 WRX: 17x7 42mm offset?
Another paramedic where I work has a set of Enkei 17x7 100mm 42mm offset wheels from his old Civic SI. I know this offset is pushing it, but will they fit? $500 for the set of wheels plus a nice set of tires is the deal.
Roostmonkey is offline   Reply With Quote
Old 04-09-2008, 05:29 PM   #2
dRICHey
Member#: 175780
08 Gettin' Flush
its def no upgrade from your stockers, but if you really wanna??
dRICHey is offline   Reply With Quote
Old 04-09-2008, 05:30 PM   #3
WRC-boxer
Member#: 147186
GM6
HS13
if they're off a civic they are most likely 4x100, unless its a type-r then its 5x114.3
either way it won't fit
your WRX is 5x100
basically unless wheels are 5x100 they won't fit, and unless you want to have camber/fender roll & pull keep the offset fairly high, take a look at the offset FAQ for the "right" or "safe" offsets, even though you can run lower with a few changes and difficulties, plus it looks better
cheers
-Evan
WRC-boxer is offline   Reply With Quote
Old 04-09-2008, 05:41 PM   #4
Roostmonkey
Member#: 173822
2008 WRX Premium
I want to stick with 17 inch wheels, as I think 18's are too heavy, and the tire prices for those rims are quite a bit more.
From what I know, the rims are 5x100mm, double cut for 5x114mm.
Old 04-09-2008, 07:17 PM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
sure it's a good deal but you already have a set of 17x7 wheels so why spend money on yet another set of 17x7 wheels?
Old 04-09-2008, 08:45 PM   #6
Roostmonkey
Member#: 173822
2008 WRX Premium
Dood, you just don't get it...
Old 04-09-2008, 08:54 PM   #7
WRC-boxer
Member#: 147186
GM6
HS13
as long as they're 5x100, and you like them, go for it
cheers
-Evan
Old 04-09-2008, 09:10 PM   #8
nhat
Member#: 140163
03 STi
hellaflunctional
i actually think you don't but ok. enjoy the wheels
Old 04-10-2008, 10:01 AM   #9
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
yeah. getting another set of wheels in the same exact size...I think your not getting it roostmonkey. You do realize that you can get wider as well as larger wheels. You dont have to be limited to a 17x7 when a 17x8 will fit nicely and allow for more rubber if you choose.
blahhblahh is offline   Reply With Quote
Old 03-27-2009, 09:04 PM   #10
jjt17
Member#: 202572
I have a 2008 wrx hatch and I picked up a set of 17x7 et42 without knowing the offset for super cheap. i love the look of them new wheels and really want to run them
Will these rub with stock suspension?
jjt17 is offline   Reply With Quote
Old 03-27-2009, 09:51 PM   #11
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
on my 08 wrx i have 17X8 +48 rims and they dont rub at all.also lowered on sti pinks.if that helps at all.
424wrx is offline   Reply With Quote
17x7 42mm offset? jaskillz Tire & Wheel 3 02-24-2006 03:34 PM
Will 18 x 7.5 +42mm offset fit 05 STI? Inprogress Tire & Wheel 1 06-29-2005 10:11 PM
wheel/tire experts - 18X7.5 +42mm offset will667 Tire & Wheel 2 05-20-2005 10:38 PM
17x7 42mm offset SCA260 Tire & Wheel 1 03-07-2005 08:30 PM
18" x 8" 42mm offset wheel for FXT? Neil Wallerstein Forester Forum 5 02-08-2004 02:07 PM
