Old 04-09-2008, 05:40 PM   #1
CGuerra54
Member#: 157082
2004 STi
Default Intercooler Tilted
When look at the front of my car through the scoop the whole right side of the intercooler is tilted. It doesn't seem that my motor is tilted just the intercooler.
It seems like the motor mounts are fine. I pulled my ebrake all the way up put it in first and let the clutch out slowly and the motor moves a little. But my car is also high mileage and from the records from the previous owner there is nothing saying that he changed the mounts. So im assuming thats normal from all the wear and tear.
Anybody ever come across this problem? When I bought the car it was never like that, but I recently noticed it.
CGuerra54 is offline   Reply With Quote
Old 04-09-2008, 05:59 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Normally it should be level from L to R with a slight tilt up from the front towards the rear. At least that's how mine is/was with the stock set up...
wrxdrvr is offline   Reply With Quote
Old 04-09-2008, 06:11 PM   #3
CGuerra54
Member#: 157082
2004 STi
I know that its supposed to be tiltled like that but it is tilted down on the right side.
Old 04-09-2008, 06:22 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Well then something is not right, you need to check it out.
Old 04-09-2008, 06:23 PM   #5
CGuerra54
Member#: 157082
2004 STi
Obviously, thats why I posted this, lol.
Old 04-09-2008, 06:41 PM   #6
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
The intercooler is bolted up wrong. Check the bolt on the drivers side of the intercooler, most likely it is bolted the wrong way. If so, it will cause the intercooler be at an weird angle.
xxxjuhstenxxx is offline   Reply With Quote
Old 04-09-2008, 08:48 PM   #7
djoye
Member#: 50072
2003 WRX
[email protected] 20psi
Wow, is it possible to bolt up the intercooler wrong? You must have to be one of those folks that can break anything to accomplish that, heh.
djoye is offline   Reply With Quote
Old 04-09-2008, 09:23 PM   #8
epik_x
Member#: 100694
2003 WRX
MPB
Have you checked the brackets that the intercooler mounts too?
epik_x is offline   Reply With Quote
Old 04-09-2008, 10:51 PM   #9
MasterKwan
Member#: 98961
2003 WRX
Mine's tilted a bit too. I'm not worried about it. Looks like one of the brackets is slightly bent. Probably the passenger side bracket. It doesn't really matter.
Old 04-09-2008, 11:39 PM   #10
CGuerra54
Member#: 157082
2004 STi
Thanks guys. I mounted the bracket on top instead of underneath.
Old 04-10-2008, 01:06 AM   #11
MasterKwan
Member#: 98961
2003 WRX
How exactly did you do that? In case mine's wrong too.
Old 04-10-2008, 01:20 AM   #12
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Are you sure the passenger side is tilted up, and not the driver's side a little lower? Close your hood slowly and see if you can tell from outside, look how the splitter meets up with it. Is the passenger side scrunched, or is there a gap on the driver's side?
crap I took too long
Audiosavvy is offline   Reply With Quote
Old 04-10-2008, 01:44 AM   #13
ItalianGuy
Member#: 60685
Tire Rack is still
cheaper
If you're not paying attention it can happen, and after you bolt it in you think "why does that look funny?". Don't bother asking how I know
ItalianGuy is offline   Reply With Quote
Intercooler tilting for lower IC temps! o2sys General Community 11 07-27-2013 09:21 AM
TablesawerZ Left hand tilt or Right hand tilt? [email protected] Off-Topic 11 09-08-2006 06:37 PM
Is the 5Zigen Fireball muffler tilted like the apex n1? Keiho Normally Aspirated Powertrain 3 04-25-2001 12:10 AM
Tilt sensor in the RS? Duva Mid Atlantic Impreza Club -- MAIC 3 10-12-2000 12:34 AM
My Car is Tilted nizz Technical Forum Archive 22 07-26-2000 04:09 PM
