Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 04-09-2008, 07:45 PM   #1
harrisont
Member#: 172972
09 Nissan GT-R
Gunmetal Grey
Default oil capacity?
how many quarts of oil should i put in?
harrisont is offline   Reply With Quote
Old 04-09-2008, 09:24 PM   #2
n8t_dog
Member#: 132583
02 stock
white
Owner's manual states 4.8.
n8t_dog is offline   Reply With Quote
Old 04-09-2008, 09:40 PM   #3
msedly
Member#: 136531
Cobb Stg 2
Why not look in the owners manual?
msedly is offline   Reply With Quote
Old 04-09-2008, 10:05 PM   #4
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
MY04 manual state 4.8...Autozone will tell you 4.5...go with 4.8
skingfreak is offline   Reply With Quote
Old 04-10-2008, 01:20 PM   #5
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
F AutoZone, they suck. OP, 4.8 it is....do you not have an owners manual? Searching helps too. Dump all 5 Qt in, you'll be fine....you don't get a full Qt out of each bottle anyway.
REXtard04 is offline   Reply With Quote
Old 04-10-2008, 02:23 PM   #6
vashachiroku
Member#: 87511
Depends on if you change your oil filter as well, which if you dont your just being cheap =) its 4.8 with oil filter change.
vashachiroku is offline   Reply With Quote
Old 04-10-2008, 05:25 PM   #7
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Throw in 5 with a filter. Slam hood and call it good. RP
drivin blind is offline   Reply With Quote
Old 05-09-2008, 02:07 AM   #8
jobber
Member#: 164043
2015 WRX and FozzyXT
Whats really weird is... I'm super anal about oil level..
so:
oil change at 57,546 (when i bought the car), I put in 5.5 qts castrol 5w-30
oil change at 60,231, I put in 5.5 qts castrol 5w-30
oil change at 62,949, I put in 5 quarts Amsoil 5w-30
I swear my level has always been perfect to top mark on all 3 oil changes. so I cant understand how 5 quarts is full when it was 5.5 before.
jobber is offline   Reply With Quote
Old 05-09-2008, 10:37 AM   #9
bluesubie
Member#: 767
04 FXT
Which top mark? Sounds like your oil should be hitting the max notch instead of the full line.
-Dennis
Old 05-09-2008, 10:41 AM   #10
jobber
Member#: 164043
-Dennis
maybe you're right. but i thought it was the high mark of high/low. I been holding off on putting in the extra 1/2 quart until I measure a few more times.
Old 05-10-2008, 12:39 PM   #11
ST0ICH
Member#: 120306
2005 年ワ
Make sure you measure on flat ground, front driveways are notorious for misleading oil levels.
ST0ICH is offline   Reply With Quote
Old 05-10-2008, 01:32 PM   #12
sidewayz
Member#: 5810
2001 S366 2.5RS
fill it till the oil level is at the oil cap
seriosuly don't do that.. and for god sakes you should know the answer
sidewayz is offline   Reply With Quote
Old 05-10-2008, 02:18 PM   #13
flstffxe
Member#: 155358
2008 Forester
Steel Silver
I have witnessed this in a buick 3800. The shop I was working at did the oil change, she came back 1/2hr-1hr later saying we owed her for 12qts she purchased to top the oil level off on her car. We were confused until we realized what she had done was to fill it up until oil was at the oil cap. We went out to the car and there was a pool under the car about 3 feet wide and running out from behind the car.
flstffxe is offline   Reply With Quote
Oil Capacity 2001 GT? eastbaysubaru Legacy Forum 10 02-11-2002 01:21 AM
WRX Mt Tranny Oil Capacity? Imprezer Transmission (AT/MT) & Driveline 2 10-25-2001 12:01 AM
02 WRX rear diff. oil capacity? bikerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-12-2001 12:00 PM
WRX oil capacity harrydog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-30-2001 08:59 PM
Oil Capacity [Q] Peaty General Forum Archive 8 02-24-2001 01:53 AM
