Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-09-2008, 08:55 PM   #1
gathermewool
Member#: 143624
14 FXT Touring
VRP
Default M.A.P. sensor
Preface:
'97 LGT 180k
Obtained 5V reference voltage from the harness. Vacuum to the M.A.P. sensor is ~21 in. H2O
Haynes Manual states that the Sens voltage should vary from < 3V at idle (high vacuum) to 2V at WOT (low vacuum)
If the reference voltage is 5V and the M.A.P. sensor output voltage varies from 3-2V, I would assume the M.A.P. sensor consists of a varistor (variable resistor) operated by a diaphragm. I could be wrong, but this makes sense to me. Couldn't find anything online about the M.A.P. internals.
Question:
With a multimeter, will the resistance change with the M.A.P. sensor hooked up to a vacuum pump when measured from signal to ground. I pulled it and measured infinite resistance (open circuit) at atm pressure (vacuum pump not attached.) There was no change in resistance after applying 21 in. of vacuum (still infinite resistance.)
Varistor failure?
diaphragm failure?
dance monkey, dance?
EGR thread:
I pulled the M.A.P. sensor to trouble shoot the below listed EGR flow malfunction (P0400) problem I have. Instead of having every one read through the entire thing to answer this simple question, I decided to post it separately.
http://forums.nasioc.com/forums/show....php?t=1456396
gathermewool is offline   Reply With Quote
Old 04-09-2008, 09:49 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
key on if you 5v power 5v referance and a good ground at the harness with it unplugged from the sensor chances are the sensor is no good.
and yes its a variable resistor attached to a bored that is pulled on by a diaphram changing the resisitance.
Old 04-09-2008, 10:06 PM   #3
gathermewool
Member#: 143624
14 FXT Touring
VRP
Thanks, brother. Hopefully this is the culprit. I'm not one to just throw parts at a problem. The issue now is finding a cheap, gently used MAP. $250 for a new one??? no freaking way! who's parting out!? ( checked the parting out threads ; ) )
Front 02 Sensor,Rear 02 Sensor,MAF Sensor,Blox Shift Knob,SPT Oil Cap, bunch of stuff TopEndPull Engine/Power/Exhaust 11 08-14-2009 05:48 PM
FS (OH): WRX/STi rear o2 sensor, MAF sensor, MAP sensor coolblue05 Engine/Power/Exhaust 14 07-07-2009 02:52 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 01:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 01:28 PM
wtb: Tumble Generator Valve (TGV) sensor / Throttle Position Sensor (TPS) Sensor simprezl25 Private 'Wanted' Classifieds 0 01-10-2007 04:25 PM
