Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 04-09-2008, 09:26 PM   #1
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
Default ej20k spun bearing
So ya, I spun a bearing in my 20k...im assuming. I posted on rs25.com so i might as well post here too just in case anyone else wants to do some research. there are multiple assumptions as to why the bearing spun but thats the past and well...here is the new. I bought an ej257 shortblock with all the gaskets, seals, blah blah blah. so i disconnected everything from vacuum hoses to power steering lines from the 20k. i pulled the motor and well...for those of you that don't know, inside the transmission there is a fairly long cylinder shaped piece of metal that slides into the clutch fork that needs removing before you try pulling the motor out of the engine bay...i spent about an hr trying to figure out what the hell was binding so finally i called ecs and well, lets just say i should've done that 1st ;] anyhow, ive got the motor almost completely torn down minus the heads...gotta get a special star socket for them so anyhow, here are some pictures of what ive accomplished so far...anybody know of any GREAT east coast turbo porting/coating/cleaning shops? every dam place ive called its went straight to voicemail which is quite frustrating considering i could already have sent the turbo off...so anyhow, here are some pictures for you guys to check out
empty engine bay
valves
look, im fred flinstone! hehe...what the hell is up with that fogged up parking lamp???
buncha random bits, oh ya...i was just starting to bag everything up
parts from which the random bits originated
head w/o cams
the engine at the end of the night, yes i know...crappy pic
p.s. does anybody know the torque down specs of basically everything important? gotta find that out before i start assembling it back together after i get the heads back and the new ej257 block
2.5rsTurbo is offline   Reply With Quote
Old 04-10-2008, 11:18 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
interesting. What's happening with the EJ20k's???? I'm hearing a bit about them and also the 02-03 2.0L's spinning rod bearings.
A lot of work! Saves ya a lot of $$$ taking the motor out yourself. Gotta love the sliding pin for the clutch fork, eh? lolz So you're not going to rebuild the EJ20K? I would at least recommend getting pistons for the EJ257. Only think I don't like about the EJ257 is the machine trim on the outside cylinder walls. It's trimmed to clear the washer for the HALF-BLOCK bolts. This is a weak spot of ALL the EJ25's. All the lower displacement EJ-series don't have this; anything EJ22 and less.
The head bolts are the MOST important one for torque specs.
21ft lbs in a a-f sequence. 51ft lbs in a-f sequence. Loosen 180* a-f sequence and another 180*. Then tighten middle TWO to 25ft lbs, outters to 11ft lbs, then 80-90* turn in a-f sequence, then another 80-90* turn making sure you don't go over 90*.
..........Cylinder Header..........
Front--------------------Rear
IN-CAM GEAR - C - - A - - F
EX-CAM GEAR - E - - B - - D
Water pump and oil pump torque specs are 7lbs, VERY LIGHT. Oil pan are 4lbs? Timing belt covers are 3lbs? Pulleys are 25lbs and some are 36lbs?
FuJi K is offline   Reply With Quote
Old 04-10-2008, 07:28 PM   #3
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
wow awesome fuji k, thanks a lot...plz keep it coming!
Old 04-10-2008, 07:55 PM   #4
keirnna
Member#: 50167
1996 Subaru STI RA
The transmission release also got me when I pulled my 20K with a spun bearing.
keirnna is offline   Reply With Quote
Old 04-10-2008, 10:59 PM   #5
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
it got me too
Old 04-11-2008, 12:02 AM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
It gets everyone the first time.
~Josh~
Old 04-11-2008, 12:47 AM   #7
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
When I pulled my 20k a few weeks ago i was like, wtf, how the hell am I supposed to get that fork off the clutch.
Figured it out though.
I decided to go a route different than everyone else and rebuild my 20k. I pick up my crank and rods tom and my ACL Race bearings showed up today.
If there are any bolt specs your after I have a few PDF files I got from another member that might help you out. Let me know
-Derek
fishheadback is offline   Reply With Quote
Old 04-11-2008, 07:39 PM   #8
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
thanks for the comments guys, fish head, i will let you know when i need them, thanks again
Old 04-12-2008, 06:13 PM   #9
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
so im sending my turbo off here soon to deadbolt enterprises and getting a monster port/compressor port/exhaust side is getting coated with high temp stuff and im getting it checked for anything wrong inside the turbo...only 405.50 shipped back to me with all that done, i will be paying shipping separately to them though...ill take pics before and after the ports ;]
Old 04-12-2008, 06:57 PM   #10
keirnna
Member#: 50167
1996 Subaru STI RA
I am sure you will like the VF22 or whatever turbo you have after all of that but why not spend that on an FP Green?
Old 04-18-2008, 06:07 PM   #11
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
well, an fp green costs at least 800 right? i have no idea how much they cost but it can't be any cheaper than re-using my vf22 with porting/coating/and just making sure the thing is still in tact, it will spool as fast as any stock turbo "im guessing" b/c of the port and the .5 more liters...this is the biggest IHI series turbo that makes 320whp on a 2.0, so hopefully i can get more than that ;] we will see though within a couple of weeks of me putting everything back together and getting it fully tuned for stock boost, im starting at 8psi and going to stock, hoping to clear more hp than expected, i doubt ill see 350 on stock boost though ;] stay tuned...
Old 04-18-2008, 06:29 PM   #12
keirnna
Member#: 50167
1996 Subaru STI RA
The VF22 is not capable of 320 WHP on any decent dyno especially with a 2 liter. A dyno jet, sure, but not any dyno dynamics etc. Yes you can get a used FP Green for $800 normally. If you get the 2.4" inlet it is plug and play in your car. The VF22 could be sold right now for close to $400 maybe a bit less. Which there is no way that the DB P&P is going to be under $400. The FP Green is a much more capable proven power turbo. The VF22 is great if you have no other options.
Old 04-21-2008, 03:31 PM   #13
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
well i think im going with a superzilla now, my vf22 is shot, metal got in it and screwed it all up...does anyone know the specs for ej20k heads on the lift and valve clearance? they are at the machine shop and those guys dont know the specs on the valves...someone please help
Old 04-21-2008, 05:39 PM   #14
keirnna
Member#: 50167
1996 Subaru STI RA
Did they disassemble your 22 and tell you that? My 20K that spun a bearing didn't mess up my VF23.
Old 04-21-2008, 05:46 PM   #15
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
ya, i had deadbolt look at it...they said metal chunks got into the turbo and ruined the bearing and the bearing seals or something...they said its unrepairable and not rebuildable...so now im going to get a superzilla i think...i just need the specs for my head to get the dam valves adjusted!!! someone please help!!!!!!!!!!!!!!!!!!!!!!!
Old 04-21-2008, 05:56 PM   #16
keirnna
Member#: 50167
1996 Subaru STI RA
That sucks. Did it free spin before you sent it? I have a VF22 I just emailed them about. It sucks that IHI are such turds about rebuild kits.
Old 04-21-2008, 08:21 PM   #17
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
i spun it, it was fine...it had no shaft play but the center section was the part that was screwed
Old 04-21-2008, 08:32 PM   #18
keirnna
Member#: 50167
1996 Subaru STI RA
Hmm if it was me I would have continued to run it.
Old 04-21-2008, 10:42 PM   #19
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
oh well, im sure i will completely satisfied with a new sz49
Old 04-22-2008, 12:31 AM   #20
sidewayz
Member#: 5810
2001 S366 2.5RS
For head porting etc. Check out Head Games in NJ. THE BEST head work PERIOD
(609) 882-3211
Ryan
Area1320
sidewayz is offline   Reply With Quote
Old 04-22-2008, 02:09 AM   #21
keirnna
Member#: 50167
1996 Subaru STI RA
Just make sure you don't go with a 3" inlet if that is an option because you are never going to find one for the 20K.
Old 04-22-2008, 10:42 PM   #22
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
yes keirnna, ive already accounted for that...shoot, i can barely find a replacement inlet hose for my busted one =/ they have the 2.4" inlet which is supposedly stock size
Old 04-22-2008, 11:28 PM   #23
keirnna
Member#: 50167
1996 Subaru STI RA
There are V3/4 Silicon Inlet hoses all over ebay for under $100. Pick up one of these. I was just making sure you knew that you couldn't use a new age inlet and the opening was 2.4".
Old 04-23-2008, 11:15 AM   #24
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
this guy
http://cgi.ebay.com/ebaymotors/Subar...spagenameZWDVW
i have ordered a few things from them befor
i go them faster than if i ordered from the east coast
get a set of radiator hoses while you are at it
Old 04-23-2008, 05:11 PM   #25
keirnna
Member#: 50167
1996 Subaru STI RA
Yeah Zena Racing. They've also shipped straight to my house in Japan.
The "my ej20k spun a rod bearing" count thread 2slofouru Subaru Conversions 0 02-22-2008 02:34 PM
NY:02 wrx spun bearing otherwise great for motorswap GTIWRX83 Private 'For Sale' Classifieds 2 02-28-2006 06:16 PM
Spun Bearing? Jaships Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-12-2005 09:29 PM
spun bearing snowman4us Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 02-17-2005 03:55 PM
FS:STi V7 Shortblock- with spun bearing (perfect for rebuild!!) Blugin Private 'For Sale' Classifieds 29 09-15-2004 10:55 AM
