Old 04-23-2008, 05:33 PM   #26
kwan_1104
Member#: 127781
and the Zenaracing one is a lot beefier than the stock one
kwan_1104 is offline   Reply With Quote
Old 04-23-2008, 05:37 PM   #27
keirnna
Member#: 50167
1996 Subaru STI RA
Beefier I don't know. I had my stupid Perrin hose colapse on my 04 STI. My Autobahn88 house from Zenaracing has had 0 issues other than it is a complete bear to fit under the intake manifold. The biggest thing for me is the minimum diameter through the hose is bit bigger on the Autobahn88 intake.
keirnna is offline   Reply With Quote
Old 04-23-2008, 05:51 PM   #28
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
oh man, i had trouble getting the stock inlet house out lol...well its good to know you guys know where to get such a part cus my options were almost exhausted
2.5rsTurbo is offline   Reply With Quote
Old 04-23-2008, 07:55 PM   #29
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i took my manifold off
FWIW i used 98 rs (ej25d?) intake manifold gaskets .. which were perfect
Old 04-23-2008, 08:22 PM   #30
keirnna
Member#: 50167
1996 Subaru STI RA
It is impossible to install one of these Autobahn88 hoses without removing the manifold and doing a bit of cutting to remove some fuel line brackets.
Old 04-24-2008, 11:51 AM   #31
kingsubi
Member#: 19239
2011 WRX
Originally Posted by FuJi K View Post
The head bolts are the MOST important one for torque specs.
21ft lbs in a a-f sequence. 51ft lbs in a-f sequence. Loosen 180* a-f sequence and another 180*. Then tighten middle TWO to 25ft lbs, outters to 11ft lbs, then 80-90* turn in a-f sequence, then another 80-90* turn making sure you don't go over 90*.
..........Cylinder Header..........
Front--------------------Rear
IN-CAM GEAR - C - - A - - F
EX-CAM GEAR - E - - B - - D
This is the old method for head bolts. This was revised in 03/04, which involves an extra 40-45 degrees for bolts A & B.
pm me your email and I can send you the pdf for the sequence
For future reference:
Above is right up to and including the backing off 180 twice.
Then:
Tighten in alpha order 36 ft-lbs
Tighten in alpha order 80-90 deg
Tighten in alpha order 40-45 deg
Tighten A & B 40-45 deg.
kingsubi is offline   Reply With Quote
Old 04-30-2008, 12:40 AM   #32
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
here are a couple goodies that i have acquired lately...
(sorry about the pics, its just a blackberry pearl 8) )
version 4 sti 22b steering wheel
powerfc for the 20k
Old 04-30-2008, 12:47 AM   #33
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
meant to throw this pic in too...ej257 aka sti shortblock
Old 05-05-2008, 10:44 PM   #34
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
finally got my ej257 on the engine stand...starting to swap stuff over tomorrow
Old 05-08-2008, 07:27 PM   #35
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
here are the pics...trying to source some torque specs for all this stuff, i think ima break down and buy a hanes manual for the sti shortblock...
ej257 on the stand/ ej20k is obviously on the floor
the 257 upside down as i was finishing up for the night
the 257 right side up
bottom of the ej20k
Old 05-08-2008, 08:16 PM   #36
keirnna
Member#: 50167
1996 Subaru STI RA
What are you doing about the extra crank-case vent on the 257?
Old 05-08-2008, 08:49 PM   #37
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
ehhh????? what? where??
Old 05-09-2008, 05:49 AM   #38
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Originally Posted by keirnna View Post
The VF22 is not capable of 320 WHP on any decent dyno especially with a 2 liter. A dyno jet, sure, but not any dyno dynamics etc. Yes you can get a used FP Green for $800 normally. If you get the 2.4" inlet it is plug and play in your car. The VF22 could be sold right now for close to $400 maybe a bit less. Which there is no way that the DB P&P is going to be under $400. The FP Green is a much more capable proven power turbo. The VF22 is great if you have no other options.
Do you want to put your title on that , considering I did it with a 2L motor before going to the 2835 and stroking out to a 2.2L, and I am not talking about fanboi Autobacs or G Force fudged numbers either.
I think you need to take a trip to Akita.......visit the Suby guys down there and the HKS certified tuning shop!!
You will be suprised what the VF22 and 23 are capable of with the proper support and tuning, and of course the 98 oct gas!!!
DuoMaxwell is offline   Reply With Quote
Old 05-09-2008, 06:03 AM   #39
keirnna
Member#: 50167
1996 Subaru STI RA
98 RON is no better than 94 R+M/2. I don't deny that the 22 and 23 are great turbos. I have both, but I would really like to see and talk to someone pulling 350 WHP out of one without water injection, etc...
Last edited by keirnna; 05-09-2008 at 09:22 PM. Reason: Sorry I mean 350 not 250...
Old 05-09-2008, 10:20 AM   #40
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
so what is this that you speak of???
Old 05-09-2008, 12:45 PM   #41
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
98 RON is no better than 94 R+M/2. I don't deny that the 22 and 23 are great turbos. I have both, but I would really like to see and talk to someone pulling 250 WHP out of one without water injection, etc...
considering my old roommate pulled 260whp out of a vf-30 on cobb's mustang at 5200ft in an 02 usdm on 91, 5 years ago.. that makes little sense
i am hoping to make 325whp running e85 with my k/vf-22
Old 05-09-2008, 01:52 PM   #42
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
/\ details on your setup please
2slofouru is offline   Reply With Quote
Old 05-09-2008, 06:46 PM   #43
kingsubi
Member#: 19239
2011 WRX
put a rubber cap over it - its just an extra crankcase breather for avcs. You may need to dent it slightly to make your crossover pipe fit.
I have had mine covered for almost 2 years now (EJ207) with no issues.
Old 05-09-2008, 08:55 PM   #44
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
heading ot but
nothing fancy
uppipe turbo-back pinks and a very methodical tune by trey (before Christian did the tuning)
still on the road with the same tune as a DD today
Old 05-09-2008, 08:55 PM   #45
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
hmmm ic, i was wondering about that, i figured it was something to do with how my 20k block has that one piece coming off the block that splits into a Y which you can see in the picture...so you just capped yours off eh? hmmm, i still need my little Y piece then?
Old 05-09-2008, 09:11 PM   #46
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
well here are some updated pics...im spending about 2-4 hours a day on this just in case anyone is curious
oil pan w/ some rtv (high temp)
top of 20k heads (after machine shop)
bottom of 20k heads (after machine shop)
the engine with oil pan and heads on!
Old 05-10-2008, 03:16 PM   #47
07blksti
Member#: 146303
2015 sti
Not talking about 98 RON, talking about 98 R+M/2. Stock 96 WRX came with these turbos, with a FCON Pro V Gold tuned, exhaust, injectors, and upped boost 320 was easily being reached.
07blksti is offline   Reply With Quote
Old 05-10-2008, 06:29 PM   #48
keirnna
Member#: 50167
1996 Subaru STI RA
Where are you getting 98 R+M/2? That is not common in Japan and you can't really call that pump gas as it is not very common anywhere. The September 1996 and after WRX came with the VF22 while the V3 STI had the 23 and the V4 had the VF24. I really do not buy that that set-up made 350 especially with the stock top mount.
Old 05-13-2008, 01:06 PM   #49
kike_ej20
Member#: 145440
MY96 WRX GT2835-ProS
EJ20G 2123cc!!
Agree.
kike_ej20 is offline   Reply With Quote
Old 05-13-2008, 02:55 PM   #50
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
speaking of top mounts, i have my 04 + sti tmic for sale, check it out
http://forums.nasioc.com/forums/show...3#post22272563
2002 wrx stage 1 clutch and flywheel (both exedy) for sale as well
http://forums.nasioc.com/forums/show...8#post22272328
The "my ej20k spun a rod bearing" count thread 2slofouru Subaru Conversions 0 02-22-2008 02:34 PM
NY:02 wrx spun bearing otherwise great for motorswap GTIWRX83 Private 'For Sale' Classifieds 2 02-28-2006 06:16 PM
Spun Bearing? Jaships Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-12-2005 09:29 PM
spun bearing snowman4us Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 02-17-2005 03:55 PM
FS:STi V7 Shortblock- with spun bearing (perfect for rebuild!!) Blugin Private 'For Sale' Classifieds 29 09-15-2004 10:55 AM
