Old 04-09-2008, 09:53 PM   #1
wrx_dad
Member#: 99748
2008 Rex
Default check engine light on
Hey guys,
Need some assistance.
Today I got a check engine light turn on.
I had to code pulled @ AutoZone and they said that spark plug 2 & 4 was misfire.
I am thinking that it can be a bad coilpak and not really the plugs or the wires since they been recently changed about 20K. Anyone here know if that can be the problem? I have 130K miles on it. From what I know, itís the original coil pac.
Thanks for any suggestions.
wrx_dad is offline   Reply With Quote
Old 04-09-2008, 10:19 PM   #2
prometheum
Member#: 92003
04 bicycle!
you don't change spark plugs wires on cars with coil packs. if it does have coil packs swap them left to right and see if the problem follows, if it follows change the packs
prometheum is offline   Reply With Quote
Old 04-09-2008, 11:05 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Your WRX has coil-on-plug ignition with no wires, however the OP has a different setup on his LGT. The NA engines have a single coil pack assembly on top of the motor with wires going to the plugs.
Anyway the first thing to check is the towers on the coils, the terminals should be clean and shiny. If they are corroded they should be cleaned, also the coil pack should be checked for cracks or signs of carbon tracking. If either of those is found the coil pack must be replaced.
Old 04-09-2008, 11:29 PM   #4
wrx_dad
Member#: 99748
2008 Rex
Its a legacy, no more WRX. It has spark plug wires, along w/ coil pack
HELP! Check Engine light on & Cruise Control Light Blinking STiURBO Southern California Impreza Club Forum -- SCIC 21 03-15-2007 01:54 AM
Check engine light on and cruise control light flashing mpadovano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-23-2005 02:04 PM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
Check Engine Light ON!!! wrxman555 Mid West Subaru Owners Club Forum -- MWSOC 9 12-09-2000 12:28 AM
HELP: MY00 Check Engine Light... ON.. :(... 2.5RSt'd General Forum Archive 1 11-21-2000 05:05 AM
