Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 04-09-2008, 10:33 PM   #1
WRXislander
Member#: 50064
'02 WRX
MBP
Default Brighter headlight options that won't break the bank?
So I've got an '02 bugeye and the headlights just aren't bright enough. I know about the $$$$$$ options but I was wondering if there was a cheap way to make them significantly brighter. I care 0% percent about looks, I just want something functional.
I'm sick of outrunning my headlights. Also, here in springtime Colorado, the weather is all over the place--rain one day, then snow, then fog--so I'm in a constant struggle to see what's ahead.
Any ideas?
WRXislander is offline   Reply With Quote
Old 04-09-2008, 10:40 PM   #2
filly peeno
Member#: 150315
2009 Legacy
heard osram silverstar bulbs are good
filly peeno is offline   Reply With Quote
Old 04-09-2008, 10:48 PM   #3
Rayme
Member#: 157510
2002 impreza WRX
World rally blue
sylvania x-travision will be brighter than silverstars, also, try aiming the headlights a little higher. I find my '02's headlight light up pretty good. Maybe also polish them with some plasti-x is your lens are a little cloudy/blurry.
Rayme is offline   Reply With Quote
Old 04-09-2008, 10:55 PM   #4
WRXislander
Member#: 50064
'02 WRX
MBP
Yep, already aimed 'em higher. Had this same problem on my old '04 also.
So you think the xtravisions will work huh? Might try that.
Any other suggestions?
Old 04-09-2008, 10:57 PM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
you can look at beefing up the wiring too
Bugeye lighting bliss: wiring harness and Philips VisionPlus
UkNuck is offline   Reply With Quote
Old 04-09-2008, 11:04 PM   #6
WRXislander
Member#: 50064
'02 WRX
MBP
omg, 17 pages Is there a way to sum it all up?
Old 04-10-2008, 04:22 AM   #7
PA-Outback2000
Member#: 161832
2000 Outback Limited
check xenonexpert.com for apexcone HID's. they are $150 + $70 for lifetime warranty if needed. i have had my set since november and love every minute at night! they are so much better then regular halogens. i will never go back to stock again! let me know if u have any other questions.
PA-Outback2000 is offline   Reply With Quote
Old 04-10-2008, 08:47 AM   #8
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
I run the Silverstar Ultras and like them pretty well. About 50 bucks at Autozone.
Acostafan is offline   Reply With Quote
Old 04-10-2008, 08:59 AM   #9
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
Get a wiring harness. The wiring harness takes power directly from the battery and negates some of the voltage drop to increase your brightness. And DON'T get it from suvlights.com from what I've experienced.
HID for 9007 is one of the last thing you would want. Most of the HID kits will lose your hi beam capability. And even if you don't, the beam pattern is well... a blob of light. With HID in 9007 reflector, I can guarantee you that you will not be able to aim your headlights properly against a wall. And if you do plan on getting HID, I hope I will never drive anywhere near your car at night because of the glare.
Silverstars are "white" bulbs with blue coating on them. Any bulbs with blue coating will reduce light output but gives off a whiter light. The whiter light may translate to a false sense of security. I would recommend Philips VisionPlus +50 or Philips Xtreme Power +80 bulbs. They aren't as white as SS ultras, but they can illuminate farther than SS ultras.
Spore is offline   Reply With Quote
Old 04-10-2008, 10:13 AM   #10
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
All you have to do (and should do) is email Daniel at http://www.danielsternlighting.com/ and buy what he says. Yes...just blindly buy what he says. He is the Lord Arisen when it comes to lighting and I ain't kiddin' either.
Old 04-10-2008, 11:07 AM   #11
Rayme
Member#: 157510
2002 impreza WRX
World rally blue
Theres not much option for 9007 bulbs, since the reflectors are made as a high beam / low beam thing..it's real ****ty..and HID's are a big no no. Too bad I'd would have liked to buy those HIR bulbs Daniel recommends.
Old 04-10-2008, 11:12 AM   #12
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
You got the bi-xenon kit? Do you have photos of the beam pattern? Ever been flashed at?
Old 04-10-2008, 12:02 PM   #13
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
^^^^^^^^^^^^^^ Danielsternlighting... 40 bucks and i am happy.. HIDs can wait.
phoenix_wrx is offline   Reply With Quote
Old 04-10-2008, 12:32 PM   #14
JBravo920
Member#: 73420
2008 Camry XLE
& 10' Kawasaki Vulcan 900
I'm running Osram Silverstars +50 for my low beams and HIR bulbs for my high beams. They may not be HID's, but they certainly do light a path...
JBravo920 is offline   Reply With Quote
Old 04-11-2008, 11:56 PM   #15
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Colin! :(
Would love to talk to that guy after checking out his site but I cant get his email link to work. Every time I click it sees "Fatal Login Error".
For some reason it opens IE and forces me to use that POS and thats all I can get out of it.
Later.
Badmunky is offline   Reply With Quote
Old 04-12-2008, 06:01 AM   #16
PA-Outback2000
Member#: 161832
i have the H1 and 9005 dual light. i don't know about the 9007, but a friend has a nissan maxima (his HID aren't from my site mentioned) that uses the "bixenon" where the highbeams are toggled with the same bulb. don't know which number it is. if his are 9007 they aren't too bad. i have gotten flashed less than 5 times since they are in. even when i stand a little in front of the car they aren't blinding at all. the light path is the same as if there was a stock bulb in the headlight. it is not like the projector types, but is a lot better than stock!
Old 04-12-2008, 06:14 AM   #17
jonney_boy
Member#: 28747
06 WRX
throw a "cheap" light bar on the front... then start mounting up aux lamps (suggestion being a pair of hella driving lights and fog lights)...... at approx $100 a pair they would be MUCH brighter than any bulb upgrade your looking at ..
a bit more ugly.... a "tad" more $$.. but WAY more functional for less $$ than a hid upgrade.
jonney_boy is offline   Reply With Quote
Alternative to P Zero Nero M+S that won't break the bank? TurismoLou Tire & Wheel 4 06-06-2010 11:43 PM
Decent winter jackets that won't break the bank Fach Off-Topic 14 01-10-2006 03:25 PM
What are some safe performance enhancing mods that won't break the bank or the car? runnah Newbies & FAQs 15 12-14-2004 06:59 PM
Want water injection? We have a kit that won't break the bank WRXTuner Vendor 'For Sale' Classifieds 44 12-13-2003 02:49 AM
A helmet that won't break the bank MrBaggio Motorsports 20 08-13-2003 06:22 PM
