Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 02-19-2002, 12:58 AM   #1
Kartoffel
Member#: 12976
grocery getter
Default The grounding mod
Well, I did the single point grounding mod tonight. #4 AWG cable from the negative terminal to:
- passenger side intake header
- driver side intake header
- passenger side strut top
- firewall behind intercooler
- driver side sidewall by fender
It FEELS like it runs smoother now. I can't say for sure whether it's an actual improvement or whether it's my mind playing tricks. Oh well. Project is complete. Car is certainly no worse off than before
Kartoffel is offline   Reply With Quote
Old 02-19-2002, 09:24 AM   #2
Tex-WReX2
Guest
Member#:
Default `
Where did you end up picking up your wire and connectors? Don't you live in the Clear Lake area? I work in the area and would appreciate any leads
Wolfgang
Old 02-19-2002, 09:35 AM   #3
Kartoffel
Member#: 12976
grocery getter
I got the wire and ring terminals at EPO on Hercules/Medical Center and highway 3. #4 awg wire is $0.95/ft there - cheaper than most car stereo stores. EPO also has lots of miscellaneous connectors, split loom, zip ties, heat shrink tubing, etc.
To attach the ring terminals to the battery I used one of those quick disconnect battery hookup things with a wheel that you can screw by hand. It has 2 pieces that sandwich together. I sandwiched the ring terminals under the screw knob and stuck a washer on top of them.
Old 02-19-2002, 09:37 AM   #4
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
Default Re: `
Originally posted by Tex-WReX2
Wolfgang
'Sup Wolfie?
I'm thinking of an "easy mod" shop day soon to do this.
Orion is offline   Reply With Quote
Old 02-19-2002, 10:16 AM   #5
Tex-WReX2
Guest
Member#:
Default thanks
That is where I was planning on going. We bought a few computers from there as well as some network cards for work. I think I know what you are talking about regarding the wheel thing. Did you pick it up at a autoparts(ie napa,autozone) store?
Thanks again.
John "much easier than typing Johann Wolfgang Von Phillips"
Old 02-19-2002, 10:24 AM   #6
Kartoffel
Member#: 12976
grocery getter
I got the quick disconnect knob thing at Sears. It was labelled as a "Marine Quick Disconnect Battery Terminal" or something like that. The intended purpose is so you can disconnect your battery w/o tools. The big knob in on top just happened to be an ideal place to clamp a bunch of ring terminals.
Old 02-19-2002, 12:19 PM   #7
maclif
Member#: 11005
2006 spec. B
Is the ECU setup in your car stock?
maclif is offline   Reply With Quote
Old 02-19-2002, 12:34 PM   #8
Kartoffel
Member#: 12976
grocery getter
Yes, stock.
Old 02-19-2002, 03:42 PM   #9
mlambert
Member#: 13831
I'd like to do this mod...wish my tools/garage werent back in Portland...kinda hard to do this in a Holiday Inn parking lot !
mlambert is offline   Reply With Quote
Old 02-19-2002, 03:47 PM   #10
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
Head south on Hwy 6 to Sugar Land. I'll be doing this soon, and installing a PITA boost gauge. (don't ask!) I'm right off 6 and Hwy 90.
Old 02-19-2002, 03:50 PM   #11
mlambert
Member#: 13831
The receptionist here at my work says thats about 5miles south of I-10, is that about right?
Old 02-19-2002, 03:57 PM   #12
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
more like 8-9 miles. if you take 6 the whole way down it will take 20+ min. due to traffic and lights.
If you have Wash. plates, why are the tools in Portland? Isn't that in OR? Only other Portland I know is in Maine!
Oh yeah, you may want to stop by Mobile 1 Autosound on the way down to pick up the 8 gauge wire and connectors. I'll post later in the week about time & location this weekend. I have a couple things going on, but we can schedule a few easy mods during the day.
Old 02-19-2002, 04:30 PM   #13
mlambert
Member#: 13831
washington state! Portland Oregon is where my garage was/is.
Old 02-19-2002, 04:47 PM   #14
QA Guy
Member#: 6739
Default Parts Express...
Parts Express has eight gauge wire and power distribution blocks cheap. If anyone here in Houston wants to do this mod, we could even double/triple/whatever up on an order to save on shipping if you don't mind waiting a few days for it to arrive.
Links:
http://www.partsexpress.com/pe/showd...15390&CATID=56
8 AWG for 19&#162 per ft
http://www.partsexpress.com/pe/showd..._ID=6700&DID=7
power dist block for $4.45
http://www.partsexpress.com/pe/pshow...=095-660&Did=7
8 gauge 5/16" ring terminals (4) for $1.35
http://www.partsexpress.com/pe/pshow...=100-196&Did=7
4 AWG for $1.25 per ft
QA Guy is offline   Reply With Quote
Old 02-19-2002, 04:51 PM   #15
QA Guy
Member#: 6739
Here's a link to a 4 gauge ring terminal pack there, too:
http://www.partsexpress.com/pe/pshow...=095-656&Did=7
$2.85 for a 4 pack.
Old 02-19-2002, 04:55 PM   #16
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
That's great, but to get it here by Saturday means you'll pay a bunch to have it shipped. I'm sure we can find what we need locally. It's not likew were looking for 1/8" compression fittings and tubing for goodness sake!
Old 02-19-2002, 04:57 PM   #17
Kartoffel
Member#: 12976
grocery getter
It's not so bad. I did the mod partially in the parking lot and partially on the front step of my apartment, at night even!
The hardest part was cutting the 4 gauge cable and crimping ring terminals onto the ends. Without a bench vise, I just layed the ring terminals on the pavement and whacked them with a hammer to crimp them. Measuring how long to make each cable was not hard. Bolting the cables up was fairly trivial.
Old 02-19-2002, 05:03 PM   #18
Kartoffel
Member#: 12976
grocery getter
Agreed. If a bunch of people want to get together and ground their cars for a shop day project, let's just go to Home Depot or EPO for the stuff.
EPO has the best prices on #4 and #8 wire, although their prices on ring terminals were a little steep ($0.95 each for 4 gauge ones).
Old 02-19-2002, 05:16 PM   #19
QA Guy
Member#: 6739
I called up EPO earlier and they're selling 8 AWG for 50&#162 /ft, ring terminals for about 50 &#162 to $1 depending on size and distribution blocks for $27 or $28 depending on which purchased.
Even if no one purchased distribution blocks (where the biggest savings are), it would still be about half price or less through Parts Express if a couple of people participate.
Old 02-19-2002, 05:16 PM   #20
jmott
Member#: 6713
2007 Prius
brown
if anyone finds some good gold fittings and good wire, nab em for me and I'll reimburse ya.
and let me know if you want a vice-versa on that
jmott is offline   Reply With Quote
Old 02-19-2002, 05:19 PM   #21
mlambert
Member#: 13831
wow lets do this
I get off work around noon most saturdays...might have to be in Dallas Monday...
Home Depot is just a few exits west on I-10
I can bring beer too
Old 02-19-2002, 05:27 PM   #22
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
wow lets do this
I have a Lowe's and a Home Depot close by. They may not have good quality stuff rings though. There's plenty of car audio ships that will have good stuff.
If you bring beer, I WILL have it at my house! A couple cases might do the job!
hopefully no one will mention how much beer i drink!
Old 02-19-2002, 05:38 PM   #23
jmott
Member#: 6713
2007 Prius
brown
brining beer!
orion, PM me your phone ##
Old 02-19-2002, 05:57 PM   #24
mlambert
Member#: 13831
Sounds like a plan! 9miles away from me works
email is prolly best contact at this point...considering the fact that im "on the road".
Old 02-19-2002, 08:34 PM   #25
QA Guy
Member#: 6739
Now that we've heard from people who AREN'T interested in combining an order from Parts Express to do the grounding mod for extra cheap, is there anyone who IS interested in this? I posted some links and prices earlier in the thread.
From my earlier post in this thread:
"Parts Express has eight gauge wire and power distribution blocks cheap. If anyone here in Houston wants to do this mod, we could even double/triple/whatever up on an order to save on shipping if you don't mind waiting a few days for it to arrive."
Will the grounding mod stop the laser! GHST Electrical & Lighting 5 04-24-2005 02:27 PM
if my battery is in the trunk, and i want to do the ground mod, what do i do STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-25-2003 12:30 PM
Doing the grounding mod tommorow..... Hondaslayer Mid West Subaru Owners Club Forum -- MWSOC 15 04-11-2002 09:49 PM
Thank You For The Grounding Mod txjunglist Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-05-2002 08:51 AM
so I just did the grounding mod jmott Texas Impreza Club Forum -- TXIC 6 03-03-2002 03:20 AM
