Welcome to the North American Subaru Impreza Owners Club Friday July 25, 2014
Old 04-09-2008, 11:13 PM   #1
zach1288
Member#: 150510
2006 Impreza WRX
World Rally Blue
Default Replacing driver side front axle on 95 legacy
I have a bad driver side front axle on my 95 legacy ls. I have replaced axles on Honda's but never on a Subaru. Do you know where i can find a write-up on doing this?
Thanks.
zach1288 is offline   Reply With Quote
Old 04-10-2008, 02:47 AM   #2
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
um..its not that hard, 32mm nut on the axle will be the hardest part lol, can take alotta force to get that freed. Might wanna take it to a shop and have em zap it with the gun for ya first then go to town on it.
How i did mine:
1. Break 32mm nut free
2. Break lugs free
3. Raise car, support on jack stands.
4. Remove wheel
5. Remove 32mm axle nut
6. Remove pin from inner axle spline
7. Unbolt strut from Knuckle (19mm)
8. Drop knuckle to max and slip the outer axle out of the hub by pushing toward tranny
9. Pull halfshaft out toward you.
Reverse this crap to put the new one in. Add a little rotation adjust to get the new axle splines to line up with the transmission of course. Same with outer for the hub. And be sure to put the new pin in and crush the 32mm nut to lock it on the axle where the notch is Hub side.
I think that is pretty much it, then again its almost 3am so ya'll feel free to correct me.
~justin
Kawikid20o2 is offline   Reply With Quote
Old 04-11-2008, 12:23 AM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Be sure to mark where the top strut bolt is, that way you dont screw up your camber. You only have to remove the top strut bolt, and simply loosen the bottom one.
Be sure to remove the spring pin that is on the tranny side of the axle, remember to pound it back in THROUGH the chamfered hole.
~Josh~
Old 04-11-2008, 05:57 PM   #4
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Douse the crap out of the strut bolts with Breakaway or something similar, I snapped one of mine off on my 95.
runninstrong is offline   Reply With Quote
Old 04-12-2008, 02:36 AM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Forgot to mention, the axle only goes on one way, you have to line up the groves. If you look carefully at the tranny splines, and the axle splines, you will see what i'm talking about.
~Josh~
Old 05-08-2008, 12:19 PM   #6
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
Default Thanks
Just because the other guy didn't say thanks I'll say it.
hangman is offline   Reply With Quote
Old 05-08-2008, 01:02 PM   #7
zach1288
Member#: 150510
2006 Impreza WRX
World Rally Blue
Thanks.
Old 08-08-2011, 01:15 PM   #8
Keif
Member#: 107302
Anyone have the torque spec for the axle nut?
Keif is offline   Reply With Quote
Old 08-12-2011, 10:02 AM   #9
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
135-145 ft/lbs
Huffer is offline   Reply With Quote
Old 08-12-2011, 11:59 AM   #10
Keif
Member#: 107302
Thank you, sir.
wtb: drivers side front axle 02 wrx 98tredsvt MWSOC Private Classifieds 0 11-20-2009 01:14 PM
drivers side front axle click under accel, and decel. 05Scooby Factory 2.0L Turbo Powertrain 7 02-24-2009 03:04 AM
WTB: Driver's Side Front Door for 95 Legacy KI-201 Private 'Wanted' Classifieds 0 04-14-2008 09:52 PM
04 sti drivers side front axle bottlediger Private 'Wanted' Classifieds 0 05-28-2005 08:35 PM
WTB: driver side front axle Pacobeagle Private 'Wanted' Classifieds 2 09-20-2003 04:20 AM
