Old 04-10-2008, 01:08 AM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Mid swap Q. Will any "wideband" Subaru 4 wire front AF / 02 sensor work for newer ECU
Much of my experience comes from the older oxygen sensors so I need advice. In the past I've been able to convert between pretty much any sensor type to another (even from a 3 wire system to use a single wire unit!).
My current guess is that most if not all Subarus from my2000 and up use a the same four wire wideband AF sensor and the only difference between them being the harness length and electrical connector.
Background - I am currently swapping an 05 STI engine into a 98RS. The oxygen sensor was damaged and not included so I need a "new" one. The plan is to keep the engine completely stock.
With that said if any of you have a broken oxygen sensor with a plug that would fit the 05 STI harness I would be interested in the plug. (keeping it stock)
Old 04-13-2008, 08:58 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
Can anyone suggest a better forum to ask?
Old 04-14-2008, 02:19 AM   #3
keirnna
Member#: 50167
1996 Subaru STI RA
As long as both sensors send the ECU a signal in the correct voltage range I wouldn't think there would be a problem. Worst case scenario is you would just have to buy a new sensor right?
keirnna is offline   Reply With Quote
Old 04-27-2008, 11:07 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
I converted an 04 WRX front sensor to use the 05 STI plug but it doesnt seem to like it. I'm getting a low voltage DTC.
I haven't tried to troubleshoot yet though. A more pressing issue can be seen here http://forums.nasioc.com/forums/show...php?p=22081623
Will the bosal Dp for 02-05wrxs work for 06s? uniden43 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-12-2006 02:45 PM
Carbotech Panther Plus brake pads (for Subaru 4 pot front pad + WRX 02-03 rear pad) TROLL Private 'For Sale' Classifieds 38 04-29-2006 01:09 AM
FS/WTT: Carbotech Panther Plus pads for Subaru 4 pot fronts + 02/03 WRX rears TROLL Private 'For Sale' Classifieds 10 01-01-2006 10:01 PM
OEM Catless Downpipe, Complete Subaru Turbo Wiring Harness and all sensors snowjob Private 'For Sale' Classifieds 5 09-12-2005 03:36 PM
Will any 15" wheels fit on front of 02 WRX MTREX Brakes, Steering & Suspension 3 06-28-2001 10:09 AM
