Old 04-10-2008, 07:37 PM   #1
MaxMendez
Member#: 108493
04 WRX
Hybrid RI GT30
Default What do i need to instal an 02 trans(rebuilt w/ real gears) in an 04 wrx
I think im going to be installing an 02(with sti SE gears from gruppe-s) trans in an 04 wrx. What do i need to make this work. I heard i need the 02 axles because they will fit the 02 box and the 04 hubs.
-Max
MaxMendez is offline   Reply With Quote
Old 04-10-2008, 08:32 PM   #2
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
I really don't have an answer to your question but I'd just like to know your motive for doing this. The 02 transmissions are the weakest.
573 is offline   Reply With Quote
Old 04-10-2008, 08:37 PM   #3
TH1
Member#: 168973
2007 STI<soldnowZO6d
SWP DOMINATOR III'd
I second that, I am doing the exact opposite next week thanx to a ripped 2nd gear..................Now its 02--->04 .And after I just had the tranny out for a new clutch. Now I will stand by for all the "You dont now how to shift comments".I guess just be careful and you will be fine. Good Luck
TH1 is offline   Reply With Quote
Old 04-10-2008, 09:12 PM   #4
MaxMendez
Member#: 108493
04 WRX
Hybrid RI GT30
you guys are right. Sorry for the confusion, i should have known that was going to come up. It is a rebuilt 02 core with sti SE gears in it. SEE EDIT
Old 04-10-2008, 10:34 PM   #5
msedly
Member#: 136531
Cobb Stg 2
I would assume it's a direct swap because I have an '05 transmission in my '02 and everything swapped in just fine, axles and all.
msedly is offline   Reply With Quote
('93-'01) What do you need to install the licence plate to a 2002 impreza? Hyudra Impreza Forum 18 07-14-2010 10:29 PM
Got an Evo III, what do I need to install it? SomeoneWhoIsntMe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-12-2009 08:42 PM
what do I need to put a Legacy V6 in the 02 impreza qualityracer Normally Aspirated Powertrain 7 11-25-2008 11:10 AM
What do I need to put a STI motor in a 2003 WRX? lasvegasbugeye Subaru Conversions 4 07-31-2007 10:46 PM
Help! Need to install 06 tail lights in an 02 wrx wagon hensblend Interior & Exterior Modification 3 10-21-2006 06:29 PM
