Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 04-10-2008, 08:30 PM   #1
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
Default several ecu codes thrown
after checking my codes a little while ago here is what i came up with.
po507 idle control system rpm higher than expected
po113 intake air temp circuit high input
po108 manifold absolute pressure circuit high input
po519 hmm this one is not listed does anyone know what it may be???
can someone tell me how i could correct each one? any help would be great.
spoolinred is offline   Reply With Quote
Old 04-10-2008, 08:33 PM   #2
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
Try cleaning the IACV:
http://forums.nasioc.com/forums/showthread.php?t=781242
I did this yesterday, never had a problem with high/low idle, but I never cleaned the IACV, and my car has 133K miles on odo. Try doing that if you haven't done it, how many miles on your car. Do you experience spikes in idle or low idle and car dying when coming to a stop?
rexman2002 is offline   Reply With Quote
Old 04-10-2008, 09:43 PM   #3
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
. Do you experience spikes in idle or low idle and car dying when coming to a stop?[/quote]
yes. i could drive the car down the rode and stop somewhere and let the car idle and the rpms would start to climb (slowly) and i have had them climb as far as 3000rpms while sitting and idleing. however i could pull out and drive it down the rode 5-8 miles, and the idle would be normal again...
i will try cleaning the idc and see what happens..thanks
can anyone help with the others?
Old 04-11-2008, 12:13 AM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
Looks like your MAF/IAT sensor is disconnected. Maybe the IAC control solenoid, too.
Jon [in CT] is offline   Reply With Quote
Old 04-11-2008, 04:54 PM   #5
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
well i looked everything over twice and everything is plugged in properly. something i forgot mentioned in first post is that this is a built motor (ej205 just put back on the road couple months ago) and i am still working out the bugs. i got a cam sensor code also but it was where i forgot to plug it in, and i ran it like that for about 2 months. still dont know what a p0519 is?
Old 04-12-2008, 10:20 PM   #6
jryan87
Member#: 130797
2007 WRX TR
01 Leg GT DD
I bet you have a ground missing somewhere, a common sensor ground. I would look into that first. That is usually the case when you have multiple codes like that. the p0519 is a idle air control motor code I believe.
jryan87 is offline   Reply With Quote
Old 04-12-2008, 11:21 PM   #7
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
i wonder why p0519 it is not listed in any of the ecu codes anywhere? thanks i will look into that and see what i come up with.
CEL troubles codes thrown, need help plz Stylz916 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-21-2010 09:47 AM
P0327 Code thrown- confirming understanding Sideshowbob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-26-2009 12:58 AM
CEL with 4 Codes Thrown G Langa Newbies & FAQs 0 07-14-2008 12:00 PM
ST codes thrown rustyzipper AccessPort 0 08-24-2007 01:25 PM
Double CEL blink, no code thrown superg Engine Management & Tuning 5 03-02-2006 01:44 PM
