Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-10-2008, 09:30 PM   #1
slaytalera
Member#: 163816
1999 Legacy Outback
Default 97 outback 2.5L...power adders?
hey guys, my legacy outback has the 2.5L block and i was wondering what i can do to add some much needed power....im sick of being out accelerated by toyota prius'. is it the same 2.5L as the sti?
slaytalera is offline   Reply With Quote
Old 04-10-2008, 11:08 PM   #2
firstshadow
Member#: 153072
03 C32 AMG
99 Impreza OBS
It's got the same engine volume as an STi... but same engine, no. The internals are very different.
firstshadow is offline   Reply With Quote
Old 04-11-2008, 12:08 PM   #3
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
^1+ and a turbo. Options for you: swap, turbo your current motor (should just swap if you plan on doing this), or do bolt on mods such as intake, exhaust, and internals like cams, heads. Search... lots out there on all of these options.
LTracer is offline   Reply With Quote
Old 04-11-2008, 04:25 PM   #4
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
If you wanted to stay N/A I would say first throw on a bigger exhaust and a short ram or cold air intake... A lightweight crank pulley would give you some faster revs, freeing up some lost power...
Delta cams?? You could always send out for regrinds.
OR if you really wanted to get crazy, raise your compression a bit.
96SubyImpreza is offline   Reply With Quote
Old 04-11-2008, 05:48 PM   #5
PA-Outback2000
Member#: 161832
2000 Outback Limited
agree with 96subyimpreza. make it a full exhaust- borla header, random tech cat, stromung or other catback. with intake, pulley and full exhausr, u should be in the 190HP area at the engine. raising compression is way too involved. i would do a turbo conversion or swap before i would do that.
PA-Outback2000 is offline   Reply With Quote
Old 04-12-2008, 02:11 AM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Exhaust, intake, pulleys. Not necessarily in that order, but you get the idea. Is your car an auto? Most likely it is, so a light weight crank pulley is a good option for you. Cams are a little "in depth" on a dohc suby motor, if you havent done them before. So you should probably wait to install cams in your car.
Do a little searching, you will find out alot of things you can do that arent too expensive.
~Josh~
Old 04-12-2008, 02:10 PM   #7
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
If your Outback is getting it's ass handed to it by a Prius, then there's something wrong with your car. Do a tune-up. Then think about upping the power.
Also, if it's an automatic, you might not have any luck beating a Prius, mods or no.
Chi_San is offline   Reply With Quote
Old 04-13-2008, 09:15 PM   #8
slaytalera
Member#: 163816
1999 Legacy Outback
alright thanks guys, btw yes it is an auto() im probably gonna take it in for a tune up next weekend and take it from there.
Old 04-13-2008, 11:53 PM   #9
96SubyImpreza
Member#: 157692
2004 WRX
"Big Red"
You can do what I am going to attempt in a few weeks. Auto manual swap!!!!!!! AHAHAHA I must be crazy
Old 04-14-2008, 04:21 AM   #10
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
Hi, I wouldn't be out just bc u have an auto. The 2.2. in my imp wgn is just fine with its 4eat and its got 164k on it, and hauls...I have done nothing to it besides a cai, and a Pro ecm. Planning on a techworks header, stromung cat back, and a high flow cat, ported and polished heads, bigger valves, have the heads shaved, delta regrinds, port and polish the intake itself, phenolic intake spacers. your legacy should perform fine after gettin a tune up. When you have the tune up done, look on the RO for what was done, plugs, wires, air filter, fuel filter, and oil change. That should help you out.
rivman05 is offline   Reply With Quote
Old 04-14-2008, 04:33 AM   #11
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
one other thing that alotta people dont think about is tranny service?? when was the last time you had it flushed and bands adjusted??? that would make a huge difference in performance.just wanted to add my 2 cents
Subaru Impreza 97-05 2.5l 2.5rs 2.5 Rs Header alysssaa Engine/Power/Exhaust 10 04-23-2010 01:33 AM
Subaru Impreza 97-05 2.5l 2.5rs 2.5 Rs Header alysssaa SWIC Private Classifieds 0 02-16-2010 10:47 PM
WTB: 90-01 2.2L or 97-07 2.5L NA Flywheel ej20forester Private 'Wanted' Classifieds 1 10-27-2009 11:05 AM
2.5RS 5 spd tranny into AT 97 Outback 2.5 RyosukeFC3s Subaru Conversions 4 08-10-2005 01:02 AM
2004 Legacy/Outback 2.5L Power Falls to 160hp in Some States Jon [in CT] News & Rumors 6 09-06-2003 07:33 PM
