Welcome to the North American Subaru Impreza Owners Club Sunday July 13, 2014
Old 04-11-2008, 03:50 AM   #1
bugeyes
Member#: 64494
2001 V7 sti
Default Converting power steering pump to crankcase vacuum pump?
I've been down the track of fitting an electric vacuum pump to generate crankcase vacuum (had it running at about 5" wg).
I didnt want much vacuum but did want it present all rpms and loads.
Electric pump didnt last very long, apart from the noise, large current draw it was never going to be a good long term solution. Pump burnt out as I later found out it wasn't rated for continuous use.
Now I'm thinking of convertng a subaru power steering pump. I'm thinking I may need to slow it down by changing pulley size and the slight oily mist that makes its way through the catch can may be enough to lubricate the vanes inside.
Anyone else tried this or thinking of it????
bugeyes is offline   Reply With Quote
Old 04-11-2008, 08:33 AM   #2
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
I'd look at what's been done with other applications over the years. Various cars (at least here in the US) have had Hydroboost - a PS driven power assist. Diesels and factory turbocharged vehicles often had them.
CTKAG is offline   Reply With Quote
Old 04-11-2008, 03:20 PM   #3
Turbo_Mike
Member#: 130276
2004 Pontiac GTO
LS1 T56 RWD
Not so on WRX/STi, its vacuum boost.
Turbo_Mike is offline   Reply With Quote
Old 04-11-2008, 09:00 PM   #4
nicad
Member#: 33971
2006 WRX
What about using an eductor/ejector in the exhaust stream to draw a vacuum?
nicad is offline   Reply With Quote
Old 04-11-2008, 09:17 PM   #5
shvrdavid
Member#: 86078
2005 Sti
4094R Twin Scroll
Use an air injection pump....
shvrdavid is offline   Reply With Quote
Old 04-12-2008, 01:27 AM   #6
8Complex
Member#: 922
04 FXT
Red
What about using a vacuum pump rated for continuous, non-lubricated use?
Old 04-12-2008, 03:39 AM   #7
bugeyes
Member#: 64494
2001 V7 sti
This issue hasn't been missed.
AS far as I know till my pump arrives they are a standard vane type pump. If this is the case they will need very little lubrication and the vanes can be replaced by plastic types.
I am hoping the small amount of oil mist that makes its way through the catch can will be enough to lubricate it. I know that when I ran the electric pump there was a very small amount of oily mist that would make it through.
Old 04-12-2008, 08:42 AM   #8
Nate8409
Member#: 44034
2006 Global Cooler
Where did you put yours? Vacuum pumps are a great idea to move the crankcase pressure and free up some extra power.
Nate8409 is offline   Reply With Quote
Old 04-12-2008, 11:38 PM   #9
charliew
Member#: 125304
I thought about that and asked my son about this and his answer was the power str. pump is a low volume high pressure pump. A power steering pump is for pressure not volume you need volume to pull a vacuum on the motor. Look elsewhere.
As shvrdavid said a air injection pump might work.
Charliew
charliew is offline   Reply With Quote
Power Steering How-To Rippen Griffen Service & Maintenance 31 12-18-2012 04:42 PM
not gettin power at all to my fuel pump relay onslot19 Electrical & Lighting 2 03-29-2009 10:19 PM
Ford Builds on Electric Power Steering Technology to Enhance Drive Quality, Enable Mo AVANTI R5 Non-Subaru News & Rumors 0 03-12-2009 12:24 PM
wrx power steering rack and New PS pump ki11switch Engine/Power/Exhaust 6 02-06-2009 03:34 AM
What type of power steering fluid to use?? Alan l. Service & Maintenance 11 05-22-2006 11:34 PM
