Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 10-22-2008, 01:32 PM   #276
trippin
Member#: 110335
'08 AW STI &
'08 SSM FSXT
Originally Posted by wichitalegacy View Post
go rotated and flip your manifold !!!!!!!!!
Damn rich man. If thats such a fantastic idea why arent you running it on your 4 X 4ster.
Originally Posted by ict-wrx View Post
what are you lookin to get for those turbo's?
Make me a offer. A legit one, i dont respond to lowballers. Both turbos have approximately 2500 miles and have no issues.
Originally Posted by papafrito View Post
See thats what i am thinking i dont want to be skipping steps. I was afraid if i got it (i wouldnt cause i am broke right now) then i would have run into alot of problems....
I'm going to probably stay true to my original plan of DP, tune, sway's, then brakes. Ill worry about that other stuff later.
I would go sways or tires if your still on those stockers. Then see if the market has improved on choices and prices of DPs and go that way. Unless you really need another 20-30hp and then go stage 2 ASAP. Be nice to that tranny though there is a '08 WRX already in the shop here. First gear is gone with only 240 miles on the car.
trippin is offline   Reply With Quote
Old 10-22-2008, 01:49 PM   #277
papafrito
Member#: 181280
2008 WRX-Prn STG 2.5
Dark Gray Metallic
Wow only 240? Sounds like they have been trying to peel out on the pavement to much... Or they just dont know how to drive AWD. I replaced my springs with some STi pinks thats the only real suspension mod i have done besides the strut tower bar. I would like to get some new winter wheels but that just depends on how things are going to work out.
papafrito is offline   Reply With Quote
Old 10-22-2008, 04:52 PM   #278
sammage
Member#: 162325
2002 WRX Wagon
Is this the red one?
sammage is offline   Reply With Quote
Old 10-22-2008, 05:07 PM   #279
tpendergraft85
Member#: 83198
2002 Bugeye Wagons
2006 Speed Triple
I already checked haha. Its not. Its the pearl white one
tpendergraft85 is offline   Reply With Quote
Old 10-22-2008, 05:22 PM   #280
papafrito
Member#: 181280
Dark Gray Metallic
I dont know what they were doing wrong. I am pretty sure the transmission is the same used in the LGT. And thats a pretty tough transmission. I am no expert but i would probably feel comfy pushing about 300 whp through it some would even probably say more.
Old 10-22-2008, 05:57 PM   #281
sammage
Member#: 162325
2002 WRX Wagon
Unskilled driver>transmission.
Old 10-22-2008, 07:28 PM   #282
wichitalegacy
Member#: 116194
I've done that already to my legacy . no need to do it again !!!!
wichitalegacy is offline   Reply With Quote
Old 10-22-2008, 07:29 PM   #283
wichitalegacy
Member#: 116194
it can handle more . Clutch options were scarce .
Old 10-22-2008, 09:59 PM   #284
Gigabelova
Member#: 81409
2004 Impreza WRX STi
Platinum Silver Metallic
Do you know all thats involved in running a STI turbo? They are not a direct bolt on for your car. '08+ WRX's use the legacy style setup. If you want to run a sti turbo you must at the very least change your manifold and intercooler. Not sure on all the parts involved since i am coming from the sti and forester side of it all. If you are interested in a turbo upgrade you need to be looking at a legacy turbo(vf40,vf46?) or a '09 wrx turbo(vf52). There are a few aftermarket turbos, but it is very limited.
You might as well start with the supporting mods as there are free maps on your AP for them. Stage 2 is a great improvement over stock on any turbo Subaru, especially with a pro-tune. You will be needing supporting mods anyways when it comes time for any type of turbo upgrade.
If you are still interested in a sti turbo let me know. I have both a '07 sti turbo and a '08 sti turbo for sale locally.
I'm curious to why this won't work. Tell me exactly what makes a vf40/6 work and not the vf48? I understand these are 06 and 07 legacy gt turbos. Why would they work and not the vf48? They look similar and have almost the same size. What warrants an intercooler change and an intake manifold?
Gigabelova is offline   Reply With Quote
Old 10-22-2008, 10:36 PM   #285
wichitalegacy
Member#: 116194
Trippin is correct . your best bet is to send your turbo into deadbolt and have them upgrade it for you . They can do a ball bearing 18g . At least they used to do that .
Old 10-22-2008, 10:42 PM   #286
sammage
Member#: 162325
2002 WRX Wagon
They bolt up differently, ie you would have to swap these parts as well.
Old 10-23-2008, 12:37 AM   #287
trippin
Member#: 110335
'08 AW STI &
'08 SSM FSXT
They dont look similar at all. Housing is completely different. The output is rotated 90 degrees counterclockwise and it bolts DIRECTLY to the intercooler on the WRX/Legacy setup. Take a look here. Do a SEARCH on nasioc for legacy turbo options and you will see there arent many choices. And yes I do believe deadbolt still does the upgrades. Or you can buy 18Gs and 20Gs made specifically for your car. It is a hell of a lot of work to get a previous gen turbo on the new setups. It wouldnt be that bad if it was only the intercooler as you need to change that tiny bastard anyways. But with the manifold change and associated issues you are better off just buying a turbo made for your car.
Old 10-23-2008, 08:52 PM   #288
sammage
Member#: 162325
2002 WRX Wagon
Trippin thought it was an essay question
Old 10-24-2008, 01:10 AM   #289
trippin
Member#: 110335
'08 AW STI &
'08 SSM FSXT
Appararently he cant search and he cant see. So i figured i would give him the long version. You effin wrx owners. It was 100 words or less. Technically is that still an essay.
Old 10-24-2008, 02:15 PM   #290
KUMed_Gal
Member#: 188057
2008 Impreza WRX
Red
Papa Frito told me that you guys thought I had already destroyed my first gear....nope not me. I baby my car quite a bit!
KUMed_Gal is offline   Reply With Quote
Old 10-24-2008, 05:33 PM   #291
papafrito
Member#: 181280
Dark Gray Metallic
I found it informative. Actually, i would prefer longer drawn out awnsers gives more depth on the issue at hand.
Old 10-24-2008, 08:30 PM   #292
sammage
Member#: 162325
2002 WRX Wagon
You got an A+ man...
Old 10-24-2008, 09:57 PM   #293
trippin
Member#: 110335
'08 AW STI &
'08 SSM FSXT
I believe everyone has a different red '08 WRX in mind. Is your car a sedan or a wagon?
Thanks brotha. Just trying to be helpful in my own special way.
Old 10-25-2008, 10:49 AM   #294
sammage
Member#: 162325
2002 WRX Wagon
This would be a red WRX with tire pressure "issues"...
Old 10-25-2008, 06:01 PM   #295
trippin
Member#: 110335
'08 AW STI &
'08 SSM FSXT
Also goes from AWD to 2WD at the touch of a button.
Old 10-25-2008, 08:29 PM   #296
papafrito
Member#: 181280
Dark Gray Metallic
Does anyone know where to get the sweet nav/dvd systems they put in the new WRX's. I know where to get other ones (crutchfield) but i want the one that Subaru puts in? Online websites?
I got a fully loaded 08 wrx hb last night while BSM was doing some work on my car and that nav system was way too cool for school.
Old 10-27-2008, 03:07 AM   #297
Gigabelova
Member#: 81409
I see the turbo. It looks like that issue can be bypassed if you change the intercooler? Correct me if I am wrong but the stock intercooler probably has a different hose/inlet flange, so changing the stock intercooler to an older STi intercooler should make this work, correct?
Old 10-30-2008, 02:46 PM   #298
wichitalegacy
Member#: 116194
NO!!!!!!!!!!!!!! seriously man, do you know anyone with an 07 and under wrx or forester???? Take a look under thier hood . Maybe you will understand what we are telling you .
sti intake manifold
legacy tmic
sti tmic
Old 10-30-2008, 04:46 PM   #299
papafrito
Member#: 181280
Dark Gray Metallic
*sigh*
Old 10-30-2008, 06:53 PM   #300
sammage
Member#: 162325
2002 WRX Wagon
Oh ****, he's got visual aids...besides, you don't want Legacy parts, they're slow. :P
any WRX owners in the Wichita Falls area? jaciuro Texas Impreza Club Forum -- TXIC 9 11-03-2012 10:04 AM
Telocity folk affected by the Rhythms chapter 11 RiftsWRX Mid West Subaru Owners Club Forum -- MWSOC 5 08-24-2001 12:52 PM
Sti spring on stock struts... the FINAL chapter karl_hungus Brakes, Steering & Suspension 0 07-20-2001 08:06 AM
hey, i'm from KY...is this the right chapter? db97 South East Region Forum 4 07-12-2001 08:29 AM
KYB/AGX Install - The Final Chapter KC New England Impreza Club Forum -- NESIC 1 09-01-2000 08:23 PM
