Old 04-11-2008, 12:42 PM   #1
sinwagon
Member#: 60970
02 WRX wagon
white
Default Oxygen sensor part#/cross reference
I've checked all the websites that have been mentioned in the maint. forum plus a few I found googling "oxygen sensor" and have had a hard time determining which O2 sensor fits my car and where (pre-cat, post). Most web sites will list the Bosch and Denso sensors but not pre/post. Then others are listed as pre/post, but then say they only fit the 2.5. The only sensors I could find that specifically listed as fitting the 02 wrx were the most expensive Bosch and Denso.
I ended up buying a cheap Walker sensor because it said it was pre-cat and fitment was universal. When it came it had a sticker on the box saying it was for the 94+ 2.2l. I don't know if this will also work on my 02 wrx, it has the pig tails which I don't mind splicing. I just don't want to have to pay $150- $200 for the part. If anyone has info on a decent sensor (either plug and play or pigtail) for a decent price, then let me know. I assumed I could find a Bosch or Denso pigtail for around $100 but can't find accurate info for fitment.
Any help would be appreciated. I'm going to attempt installing the Walker this weekend.
sinwagon is offline   Reply With Quote
Old 04-11-2008, 02:04 PM   #2
strohausii
Member#: 26770
'02 WRX
midnight black
You do know that sensor plays a very big role in how your engine runs right? Based on the readings from that first O2 sensor and the MAF, you want to do what ever you are doing right.
I'll give ya a bump that someone more knowledgible than I can help you.
strohausii is offline   Reply With Quote
Old 04-11-2008, 02:43 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
That sensor won't work as a replacement for your front air/fuel ratio sensor. Return it and buy one of these part numbers, which will work as a replacement for the 2002-5 WRX front AFR sensor.
ACDelco - 213-2843
Airtex - 5S4302
Bosch - 15537
Denso - 234-9011
NGK - 24659
Subaru - 22641AA042
Walker - 250-54004
Jon [in CT] is offline   Reply With Quote
Old 04-11-2008, 05:32 PM   #4
birukun
Member#: 52801
1999 Legacy Wagon L
Green 30th Anniv.
Is there a published cross reference out there, or can we sticky this information somewhere?
Changing an O2 sensor is not difficult, other than a few gotchas this is a good DIY job.
But.... the information out there regarding O2 sensors and A/F sensors can be nebulous when searching for a replacement part.
If we had a list by Subaru part number and alternates, like Jon [in CT] 's list above, that would be awesome!
birukun is offline   Reply With Quote
Old 04-15-2008, 12:33 PM   #5
sinwagon
Member#: 60970
02 WRX wagon
white
Replaced the sensor last weekend with the help of my flex head ratchet and some PB blaster. The Walker looks identical to the Denso OEM sensor. Is the part # for the Walker sensor listed above for a plug and play? I bought the pigtail one and spliced the wires. I now have a CEL but the car seems to be getting better mileage (wait til I finish tank) and is definately running a few hundred rpm's lower at 70 with CC on.
Old 04-16-2008, 09:36 AM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Is the part # for the Walker sensor listed above for a plug and play? I bought the pigtail one and spliced the wires. I now have a CEL ...
It's the part # of the sensor that will actually work without setting a CEL.
Old 04-16-2008, 03:24 PM   #7
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Wow...you have thought that one out, right?
You need to get a correct O2 sensor in your car ASAP.
lancelucas is offline   Reply With Quote
Old 04-17-2008, 08:59 AM   #8
sinwagon
Member#: 60970
02 WRX wagon
white
Got the Denso OEM. Just wish web sites had correct product info instead of getting a surprise when I opened the box.
Old 04-23-2008, 10:33 AM   #9
sinwagon
Member#: 60970
02 WRX wagon
white
Any info on part #s for the rear sensor?
Old 04-23-2008, 05:00 PM   #10
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
Default 2002 Wrx
rexman2002 is offline   Reply With Quote
Old 04-23-2008, 05:07 PM   #11
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
Old 04-28-2008, 12:39 PM   #12
sinwagon
Member#: 60970
02 WRX wagon
white
Thanks man, it's been a nightmare trying to find correct info from any online parts vendors.
Old 04-29-2008, 08:46 AM   #13
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally Posted by rexman2002 View Post
- sensor in uppipe (front)
22629AA012
http://www.subarupartsforyou.com/cp_...hp?partid=3356
That part number is for the EGT sensor, not the front AFR sensor.
As I stated earlier, the Subaru part number for the front AFR sensor is 22641AA042 (see also http://www.subarupartsforyou.com/cp_...hp?partid=3352).
Old 09-09-2012, 01:34 PM   #14
XLR8T
Member#: 266684
Careful that that. If your car is going mostly by the MAF and it has not been scaled right via a produne recently... Your car has nothing accurate to calibrate itself by. Measured fuel trims will help, but wull be reset also if you clear your ecu. You could be running dangerously lean especially on high boost...
XLR8T is offline   Reply With Quote
2007 STi Rear Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 3 02-19-2009 11:49 AM
2007 STI Front Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 0 02-13-2009 02:16 PM
oxygen sensor vs air/fuel sensor paintbing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-02-2008 01:09 PM
FS: Front oxygen sensor 04 WRX 02 sensor Chino Bling Engine/Power/Exhaust 4 11-20-2007 11:56 PM
