Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-11-2008, 03:41 PM   #1
Mikeye
Member#: 100098
'99 LGT
Default What socket size do I use for Subaru wheel nuts?
Hi there,
I need to know what socket size, preferably in mm, do I need to remove wheel nuts off of my 99 LGT?
Thanks!
Mikeye is offline   Reply With Quote
Old 04-11-2008, 03:57 PM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
19mm.
rougeben83 is online now   Reply With Quote
Old 04-11-2008, 04:07 PM   #3
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Originally Posted by rougeben83 View Post
19mm.
ding
fibuz is offline   Reply With Quote
Old 04-12-2008, 02:34 AM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Be sure to get a socket that is made for an impact gun, they are alittle more durable than the normal sockets.
~Josh~
Old 04-12-2008, 04:52 AM   #5
Mikeye
Member#: 100098
'99 LGT
~Josh~
Thanks for the heads up. I'm going to test out my new 18" breaker bar this weekend.
Old 04-12-2008, 05:49 PM   #6
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
~Josh~
I just use the 19MM 1/2 drive outa my craftsmen kit
I throw it on the impact gun and when it cracks i go get a new one.
Lifetime warrantee FTW!
Kawikid20o2 is offline   Reply With Quote
Old 04-12-2008, 07:51 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Damaging my rims is not worth the risk of a cracked socket.
Old 04-12-2008, 07:56 PM   #8
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Remember to use a torque bar when putting them back on, 150+ lb-ft can damage your rotors.
Chi_San is offline   Reply With Quote
Old 04-12-2008, 08:40 PM   #9
Mikeye
Member#: 100098
'99 LGT
I don't have a torque wrench/bar...
I've always just done it until the nuts were tight but so too tight.
Old 04-12-2008, 09:05 PM   #10
Chi_San
Member#: 53558
2005 Baja Sport
Go pick up a torque wrench.
Old 04-12-2008, 09:10 PM   #11
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Really? How so?
Plays_With_toys is offline   Reply With Quote
Old 04-12-2008, 09:57 PM   #12
Chi_San
Member#: 53558
2005 Baja Sport
I was told it can warp your brake rotors, told by an instructor at my Automotive Tech class, so it's probably true. You could snap a stud with 150 lb-ft as well, putting the nuts on, if you aren't careful.
Old 04-12-2008, 10:17 PM   #13
rougeben83
Member#: 115154
2005 Outback XT
White on grey
uneven torquing causes uneven pressure on the rotor, causing uneven heat transfer, leading to warpage...
What would be more important to look out for is breaking/sheering the lug bolt due to overtorquing. That seems to happen a lot more often on subaru's than the rotor warpage issue.
torque setting is 70ft/lbs roughly.
Old 04-13-2008, 02:43 AM   #14
DJ Proez
Member#: 148196
2008 Legacy Spec.b
I have also noticed that if my lugs are over torqued I get speed wobble over 80 mph I torque them low at 75 and it's smooth as butter at 100 MPH plus
DJ Proez is offline   Reply With Quote
Old 04-13-2008, 10:34 AM   #15
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yeah, and what if it cracks or shatters and hits you in the face or something? I don't think the craftsman warranty covers stuff like that.
Wiscon_Mark is offline   Reply With Quote
Old 04-13-2008, 11:57 AM   #16
Chi_San
Member#: 53558
2005 Baja Sport
Imagine someone bringing in a handful of Dust to a Sears store asking for a new socket...
Old 04-13-2008, 12:04 PM   #17
Hiroki Tada
Member#: 8048
if there are pieces of cheekbone in it im sure they would respond accordingly.
Hiroki Tada is offline   Reply With Quote
Old 04-13-2008, 12:24 PM   #18
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
I knew the studs were pretty susceptible to shearing (have read multiple people dealing with it). Good to know about the warpage and such.
Does it matter what kind of lugs I use for Volk wheels, OEM/KICS/McGuard? subierider Tire & Wheel 4 02-18-2009 03:56 AM
quick one: what size washers do i use for the lower brace with an ALK? sigma pi Brakes, Steering & Suspension 8 03-22-2005 02:15 AM
subaru front 4 pot brake pads, what do you use for less dust? M32WRXin3seconds Brakes, Steering & Suspension 18 04-13-2004 02:11 PM
what tap size do i need for a defi egt sensor mount? Otaku64 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-18-2003 01:10 AM
Auto-xer's w/ stock wheels: What tires and Size do you use? RacerinLSL Brakes, Steering & Suspension 9 07-27-2001 01:03 PM
