Old 04-12-2008, 07:34 PM   #1
nfisheremti
Member#: 69459
2015 2.0 hatch
crystal white
Default o2 sensor location
i have a check engine light on. the code reads:
o2 sensor bank#1 sensor #2
the local shop that read the code for me, said that was the front sensor. i called the guy that usually works on my wife's car (a subaru specialty shop), he said it was the rear (and it would cost $200 to replace it). so i figured i would do it myself.
i called the dealer and they told me it was $147 for the new sensor, so i started looking on-line. i got a parts help chat going and the guy at the other end told me b1 s2 was the front. AAAAAAAAAAAAA
so i called the dealer they told me it was the rear. fhweh! boy i'm glad that's been cleared up
so i've got 2 votes for front and 2 for rear. i've never really thought of car repair as a democratic process. so does anyone really know which it is? it would make sense that sensor #2 is the rear, but what is this bank#1 bs? is that there just to cause enough confusion that you take it to a professional?
please enlighten me.
thanks.
/n
nfisheremti is offline   Reply With Quote
Old 04-12-2008, 08:06 PM   #2
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2014 XV Crosstrek
Bank 1 sensor 1 is the upstream O2 sensor. Sensor 2 is the downstream sensor. Anyone who says otherwise is wrong.
As far as the bank part goes, it refers to the cylinder banks. On our engines, since both heads blow into a common collector before the upstream sensor, we've only got 1 bank. Same thing with an inline engine, regardless of how many cylinders it has. On a V engine (be it a V6, V8, V10, etc), there are 2 banks. Bank 1 is the one that has cylinder 1 in it (typically the passenger side in the case of a longitudinally mounted engine, or at the back side in a transverse setup), bank 2 is on the other side.
The reason for the 2 banks is to let the tech know which sensor had failed. For example, a Ford Exploder with a 4.0 SOHC V6, has four O2 sensors. One in each exhaust manifold before the cat, and one in each manifold just after the cat. The exhaust then runs into a Y pipe and then travels out the back of the truck. In that case, Bank 1, Sensor 1 would be the one on the passenger side of the engine, before the cat. Bank 1, Sensor 2 would also be on the passenger side of the engine, after the cat.
I hope that helps.
silver2004impreza is offline   Reply With Quote
Old 04-12-2008, 08:10 PM   #3
nfisheremti
Member#: 69459
2015 2.0 hatch
crystal white
yes, that helps. thank you.
Where is the O2 sensor, located compfool Service & Maintenance 2 04-21-2006 11:53 AM
o2 sensor location help... CREEPS Newbies & FAQs 3 02-20-2006 01:30 PM
WBO2 in rear O2 sensor location drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 09-14-2004 02:16 PM
O2 sensor location?? Replacing..DIY job? Sobelizard109 Legacy Forum 4 03-06-2003 10:45 PM
O2 sensor location and wire to tap for AFR? camz911 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-11-2002 05:22 PM
