Old 04-12-2008, 06:37 PM   #1
psyber_0ptix
Member#: 60671
1991 e30 318i
s50b30us swapped SOLD!
Default 2.5rs problems. Press clutch in, gas indicator drops, check engine light pops on?
Hello, this is for a 2000 2.5rs. Only mods is an intake and exhaust and suspension.
The problem:
This has only happened twice, but seemed to sort itself out before we could get any code pulled. She would come up to a stop and press the clutch in. The gas all of the sudden drops to empty and the check engine light comes on. when she starts driving, the gas 'fills' up again. and the code stays. Eventually the code will disappear then nothing of the sort happened again. Until today. Same scenario... as before. I'm wondering if this is a start to a larger underlying problem. Or if i just need to make sure all the plugs are secured tightly into the ecu. Is this a fluke? or should she save up for an STi swap ?
psyber_0ptix is offline   Reply With Quote
Hood popped open while driving and check engine light came on. Flat4Wagon Newbies & FAQs 20 03-12-2010 03:19 PM
Check Engine Light comes on, whats the problem? sanovichleo Service & Maintenance 7 04-19-2005 05:56 PM
...i'm in pasadena and my check engine light is on... tre.c Southern California Impreza Club Forum -- SCIC 4 07-27-2004 10:34 PM
check engine light comes on at low gas halftendril Normally Aspirated Powertrain 2 11-28-2002 11:05 AM
check engine light comes on at low gas? halftendril General Community 1 11-28-2002 02:49 AM
Message Board Statistics All times are GMT -4. The time now is 07:48 PM.
