Old 04-13-2008, 01:46 AM   #1
wrxgeneration
Member#: 170790
2006 wrx cobb stg. 2
cgm
Unhappy Just hitting 14 psi on cobb stage 2 map instead of 16psi
Before I bought an accessport for my cobb turbo back exhaust i did some research and found out that i would be hitting 16 psi of boost. After i installed the accessport i noticed a big difference in power with the stage 2 reflash, but i'm only hitting 14 psi. Any idea why that is happening? What is the best performance map?
wrxgeneration is offline   Reply With Quote
Old 04-13-2008, 01:52 AM   #2
rudeboy_sti
Member#: 124829
2005 STI
WRB/Gold
What gear are you hitting 14psi? I believe you should only hit 16 briefly in 4th through 6th before it tapers down to around 14 before redline. I could be wrong. See what some one with more experience with the AP has to say.
rudeboy_sti is offline   Reply With Quote
Old 04-13-2008, 01:58 AM   #3
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
When I was running an OTS Stage 2 map, I was only hitting 14 psi. Why I really do not know (it could be a number of factors). The waste gate may need to be adjusted, could have a leak between the turbo and TB, the ECM might see something that is it is correcting for????? Now after the pro-tune I'm hitting 16 psi. If you have 93 octane available that would be the map to use.
06grayrex is offline   Reply With Quote
Old 04-13-2008, 02:01 AM   #4
Lawsuby1
Member#: 124554
2006 wrx
black
go external wastegate. I am.
Lawsuby1 is offline   Reply With Quote
Old 04-13-2008, 02:07 AM   #5
bbarker1
Member#: 158206
06 WRX
i noticed the other day i wasnt hittin target boost either. got bored and did a compression test and found #2 cyl down 20psi of compression. if ya got time and the know-how, it wouldnt be a bad idea, seeing as how the ringlands are soo damn fragile in our (wrx) motors.
bbarker1 is offline   Reply With Quote
Old 04-13-2008, 02:26 AM   #6
94'325is
Member#: 122315
2003 WRX
You can try adjusting your wastegate arm a little. Start off with half of a turn tighter and see if that helps you at all.
94'325is is offline   Reply With Quote
Old 04-13-2008, 02:32 AM   #7
mugenXP
Member#: 155272
2006 WRX
Panda AE86
cobb stage2 for wrx is ~14.7 to ~15.2 psi...
16-17 would be the sti's
mugenXP is offline   Reply With Quote
Old 04-13-2008, 02:37 AM   #8
djsniggedy
Member#: 102157
What you lookin at
willis?
When my car (06 wrx) was cobb stg2, I was hitting 18psi all day on the OTS map. Weird how different cars react so differently to the same maps..
djsniggedy is offline   Reply With Quote
Old 04-13-2008, 02:56 AM   #9
mugenXP
Member#: 155272
2006 WRX
Panda AE86
^^catless perhaps
Old 04-13-2008, 03:18 AM   #10
GDB FAN
Member#: 105814
two V8's..
'murica
Yep, with my Cobb OTS map and catless TBE I run 16.4psi. (reading off the AP)
EDIT: this is on the wrx 2.0L
GDB FAN is offline   Reply With Quote
Old 04-13-2008, 03:23 AM   #11
GRUMPY514
Member#: 112285
1994 E34 530i
Oxfordgrun
Hmmm Iam running 18.5-19psi
Stage 2 STi
Catless 3" TBE
GRUMPY514 is online now   Reply With Quote
Old 04-13-2008, 04:17 AM   #12
kc jazz
Member#: 109807
2007 GSX-R + '05 STi
ewg'd, slammed, recaro'd
I'm running a catless 3" TB and Cobb's ots stage 2 and see the same weak ass 14-15 PSI. meh i'm over trying to fix it
Stage 2 STi
Catless 3" TBE
That's a whole different ball game.
kc jazz is offline   Reply With Quote
Old 04-13-2008, 04:29 AM   #13
Mars_D
Member#: 90480
2005 9-2x
Only hitting 14psi may have something to do with the wonderful gas we use here in Cali, 91 octane sucks....
Mars_D is offline   Reply With Quote
Old 04-13-2008, 04:38 AM   #14
Suby.LOVE
Member#: 112163
2003 WRX MBP
Hellarockchips
Originally Posted by mugenXP View Post
cobb stage2 for wrx is ~14.7 to ~15.2 psi...Also depends if you are using the ACN stage 2 map or the regular stage 2 since the target boost for the ACN map is slightly lower that the regular map due to the gas octane/quality
Correct.
Suby.LOVE is offline   Reply With Quote
Old 04-13-2008, 08:48 AM   #15
CynicX
Member#: 48199
06 WRX
Your cheap gas isnt going too help unfortunately. What are you using to measure boost, stock gauge, ap? Mine was boosting around the same until I had it protuned....
CynicX is offline   Reply With Quote
Old 04-13-2008, 11:39 AM   #16
gaugeof12
Member#: 132859
2007 WRX
Urban Gray Metallic
The 02-05 target boost is 15.8psi @ Cobb Stage 2. However with the 2.5L block Cobb made some changes to the maps. The 06-07 target boost 15.2psi +/- 0.7psi @ Cobb Stage 2 (Link to Cobbs 06-07 91oct map notes). So @ 14.5psi you are within what Cobb considers normal for your vehicle.
gaugeof12 is offline   Reply With Quote
Old 04-13-2008, 12:13 PM   #17
onefastwrxspb
Member#: 158932
06 VF39 WRX TR
AW
I thought it took a couple of days for the car to learn the tune.....so maybe the boost will raise in a couple of days
onefastwrxspb is offline   Reply With Quote
Old 04-13-2008, 12:52 PM   #18
mugenXP
Member#: 155272
2006 WRX
Panda AE86
Originally Posted by Suby.LOVE View Post
Correct.
ahh if thats the case... i'll just leave the standard cobb map if i'm not experiencing detonation
Old 04-13-2008, 01:02 PM   #19
wrxgeneration
Member#: 170790
cgm
Have a Nice Day?
i am using my accessport to measure the boost, So is that okay for an 06 wrx? What do you guys think about boost controllers?
Old 04-13-2008, 06:30 PM   #20
hypoxvi
Member#: 173002
MBC's are a bad idea unless you really need it and know what you are doing.
hypoxvi is offline   Reply With Quote
cobb downpipe install whistling noise? 17.5 psi on perrin stage 2 91 broncofangene AccessPort 17 07-27-2009 02:50 PM
17 PSI on cobb stage 2 mars636 Engine Management & Tuning 21 12-01-2005 06:01 PM
Who has used an MBC to hit target boost on cobbs stage 2.5? blackie Engine Management & Tuning 2 04-01-2005 02:28 PM
VF30 and supporting mods on Cobb stage 2 map... help WRXVII Engine Management & Tuning 4 07-08-2004 08:16 PM
17 psi on cobb stage 2 normal? daveyboy Engine Management & Tuning 14 03-01-2004 03:25 PM
Message Board Statistics All times are GMT -4. The time now is 05:38 PM.
