Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 04-13-2008, 02:03 AM   #1
alacrity024
Review Crew
Member#: 49476
Default I broke my teeth: epoxy/superglue/human mouth question
So I broke my temporary teeth. They're attached to a plastic retainer-looking thing, and the whole contraption sticks to the roof of my mouth and provides a temporary illusion of teeth in the empty spaces.
Anyway tonight it snapped cleanly into two pieces. I could glue the two parts back together pretty flawlessly and I think that as long as I didn't try to get it to bear any load (which is how I broke it tonight) it'll last me a month or two until I get these implants restored.
My question is: what reasonably fast-setting plastic bonding agent would be best to use? Epoxy? Super-Glue? I know that superglue sees medical use in sealing cuts and blisters, so I wonder if it would be okay to walk around with it in my mouth.. once it's set and cured, of course. I think epoxy or even JB Weld would be stronger but would take longer to set and i dunno about having it in my mouth.
So does OT have any input?
alacrity024 is offline   Reply With Quote
Old 04-13-2008, 02:05 AM   #2
skywaffles
Member#: 82470
. tonier vulva
Man batter.
skywaffles is offline   Reply With Quote
Old 04-13-2008, 02:05 AM   #3
setzkell
Member#: 157986
yea if you use jb weld you'll be out of teeth for a couple days, i'd say super glue but i'm not an expert in retainer reconstruction or adhesives.
setzkell is offline   Reply With Quote
Old 04-13-2008, 02:06 AM   #4
SuperSixFour
Member#: 173739
splooge
SuperSixFour is offline   Reply With Quote
Old 04-13-2008, 02:07 AM   #5
Swordfish II
Member#: 95554
2007 The Surly Squad
If it is a retainer thing use whatever is strongest and leave it out of your mouth till it cures.
Longer = better until you can get it professionally fixed IMO
Swordfish II is offline   Reply With Quote
Old 04-13-2008, 02:23 AM   #6
skycop
Member#: 70267
If my wife was here I could give you genuine advice. But she's not so I say make a grill out of Cheetos and rubberbands.
skycop is offline   Reply With Quote
Old 04-13-2008, 02:23 AM   #7
sperry
Member#: 8636
WRX, OBXT, NA Miata,
F250SD, no more SVX :(
Super glue is probably the best idea, as it's pretty non-toxic. But I dunno if it's going to taste like anything... I bet there's no flavor after it's dry. Except for the taste of fail 'cause you broke your damn teef.
Try going back to the dentist and have them melt the two halves back together.
sperry is offline   Reply With Quote
Old 04-13-2008, 03:01 AM   #8
Matt K
Member#: 45204
16 you don't
respond to danger
super glue would be fine health and taste wise, but epoxy would probably work better, it's a lot stronger... you'd want it to be pretty fully cured though, and it might taste funny even then.
Matt K is offline   Reply With Quote
Old 04-13-2008, 03:04 AM   #9
Skell
Member#: 75638
new metalocalypse
is effin funneh
jesus christ dude, you and your teefz!
just permanently insert a dick in there.
problem solved.
problem.
SOLVED.
CASE.
CLOSED.
greet me as your liberator bish!
Skell is offline   Reply With Quote
Old 04-13-2008, 04:22 AM   #10
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Whoa, those "temporary" teeth were getting kinda old anyways weren't they Adam?
http://forums.nasioc.com/forums/showthread.php?t=999943
semaj is offline   Reply With Quote
Old 04-13-2008, 04:30 AM   #11
Samuelleeogden
Member#: 66066
04 STi
black on sold
jizm.
...i'm beginning to see a pattern here.
'yay! i started a new meme!'
Samuelleeogden is offline   Reply With Quote
Old 04-13-2008, 04:36 AM   #12
rice h8r
Member#: 94524
Why don't you ask whoever made them for you?
rice h8r is offline   Reply With Quote
Old 04-13-2008, 08:31 AM   #13
OneInchPunch
Member#: 52582
epoxy is good for gluing two metal things together, superglue can do plastics better but is generally weaker. Epoxy is much more toxic, but i don't know how bad it is when cured.
I doubt there is enough surface area to bond it together in any strong way so don't bother.
OneInchPunch is offline   Reply With Quote
Old 04-13-2008, 09:19 AM   #14
Slappie
Member#: 16500
06 sti-EWG-Spearco
Stage 2
From an R/C modeler.
Superglue will degrade in water, or your mouth.
Superglue is too brittle. Don't
Of the epoxys, I would consider the JB Weld above any 5 to 30 min. stuff.
I would expect the JB weld to last (if the chewing does not snap it right away)
I would consider Goop (any type, it's all the same) or Shoe Goo, which is the same as Goop. Sticks like a M F er, but is flexable. Might not be enough area to get a good bond though.
I'm sure your dentist has the appropriate polymer.
Do some tests with glass chips glued on something and an apple as the food to test with, prior to F ing up your grill.
I would advise aginst repairing by inserting a Johnson Rod in your mouth, unless you want an overbite look like Freddy Mercury.
Slappie is offline   Reply With Quote
Old 04-13-2008, 09:22 AM   #15
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
Ummm how bout you head over to your local CVS and pick up any of the multiple 2 part epoxy repair kits for fake teeth that they carry. When I had temps in while my veneers were getting made at the lab I had one fall out and used the stuff.
Its easy to use, 2 parts just like in the dentist office and just make sure the area is dry and clean and you use pressure.
2k2 is offline   Reply With Quote
Old 04-13-2008, 09:41 AM   #16
IONist3hfast4r
Member#: 79612
+1
Super Glue has amazing vertical strength but apply even small shearing forces and it will fail.... not something you want to have happen.
Epoxy is your best bet until you have it professionally repaired
IONist3hfast4r is offline   Reply With Quote
Old 04-13-2008, 11:51 AM   #17
kinkinhood
Member#: 54934
2011 Honda CRZ
I suppose for what it's worth I have venires or however you spell it on my 4 front teeth. AS for the temp breaking, there isn't really any simple easy fix that won't break easily. I'd say go to the dentist and see what they can do.
kinkinhood is offline   Reply With Quote
Old 04-13-2008, 11:55 AM   #18
whoosh
Member#: 40989
OT vag inspector
you're suppose to open your mouth when he withdraws
whoosh is offline   Reply With Quote
Old 04-13-2008, 11:56 AM   #19
MikeCee
Member#: 136687
15 iginla, dup...
Wait, what happened to your teeth? Do you brush? Are there dentists in Moose****er, AK or wherever you are? What's happening???
EDIT: Read Semaj's post. That sucks. I had my four front teeth knocked out too. I was lucky I had braces. They kept the teeth so I knew where they were and held them in place after the dentist put them back.
Don't ever, ever drink pureed noodles. Do you have any idea how barfy that is? Hot dogs in the blender are okay though.
MikeCee is offline   Reply With Quote
Old 04-13-2008, 11:59 AM   #20
sir_wagon
Member#: 71549
See dentist. Not sure what they use, but my mom got her fake tooth repaired recently and she was able to eat normally the same day.
sir_wagon is offline   Reply With Quote
Old 04-13-2008, 11:59 AM   #21
whoosh
Member#: 40989
OT vag inspector
he's in new hampshire
was in an accident when younger
his existing teeth died
is in the middle of having implants
temps broke from some "activity"
is paying through his ass to have teeth replaced
Old 04-13-2008, 12:02 PM   #22
MikeCee
Member#: 136687
15 iginla, dup...
I edited, whoosh and NH = Eastern AK
Old 04-13-2008, 12:02 PM   #23
whoosh
Member#: 40989
OT vag inspector
most dentist have an emergency number
give him a call, ruin his Sunday, and get your $10,000 worth.
Old 04-13-2008, 12:05 PM   #24
whoosh
Member#: 40989
OT vag inspector
Vermont and New Hampshire = maple syrup = fat women
Old 04-13-2008, 12:15 PM   #25
MikeCee
Member#: 136687
15 iginla, dup...
Nothing on the picture? That's dissapointing My daughter loves that book and I always laugh when she grabs it, but she's too young (almost 1 year ) to know what an Otter is yet, so I haven't told her.
Stupid Human Trick - Broke my cam a little fragment Built Motor Discussion 29 01-24-2010 11:55 AM
Got my oil changed at Sears and the Tech broke my OBD2 adapter for my Accessport! seanforney AccessPort 12 09-21-2009 04:55 PM
Somebody broke my wiper arms... broke off. sub_rho Off-Topic 50 11-11-2008 08:54 AM
Check out my new epoxied floor! (and what's sitting on it!)(LONG) Blugin Texas Impreza Club Forum -- TXIC 56 12-12-2005 12:28 AM
Someone backed into my car and broke my C-west rear spat! adamsrs Interior & Exterior Modification 9 03-17-2001 07:21 PM
