Vancouver Impreza Club
Old 04-13-2008, 06:58 PM   #1
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
Default 3rd, and hopefully last engine to go into the RSTi
After the engine that came with the car threw a rod, and the engine I installed after that chewed up the bearings, I'm rebuilding everything to an almost obsessive level.
Specs:
EJ22T Shortblock
Stock Rods/Crank
Michigan 77 bearings
EJ25D Heads
V4 STI-RA valvetrain incl. cams
Aasco 14lbs flywheel (replacing the stupid 7 lbs flywheel that was on it before)
Centerforce Dual-Friction clutch (replacing the ridiculous 3 puck, woo! driveability here I come)
Deadbolt VF34 Turbo
Every oil galley has been scrubbed, soaked, scrubbed, cleaned, blown out, scrubbed and blown out again, the block was jet cleaned multiple times, everything re-honed, polished and scraped.
With a bit of luck, this motor will be back in the car by Friday, then Ive given myself 2 weeks to work out the bugs and then its due for the dyno on May 2nd.
Looking for 300whp, 300wtq.... however I dont think I'll be able to make it on the 550cc injectors I have.
Splinter is offline   Reply With Quote
Old 04-13-2008, 07:01 PM   #2
fukamoto
Member#: 13339
2013 BRZ
Cheers for being persistent. 300whp/300wtq shouldn't be a problem at all. Can't wait to see results.
BTW, 7lb flywheel + 3 puck clutch?? Must have been fun to drive in traffic.
fukamoto is offline   Reply With Quote
Old 04-13-2008, 07:06 PM   #3
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
ugh it was horrible. If you didn't launch from a stop, it'd stall. Parking lots were a nightmare, parallel parking was nigh impossible.
Old 04-23-2008, 09:21 PM   #4
deamon64
Member#: 125058
are those new stock pistons and rods? where did you get them and how much?
deamon64 is offline   Reply With Quote
Old 04-23-2008, 09:44 PM   #5
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
Wiseco pistons, stock rods
Rods came from subarugenuineparts, dont remember what they cost
Old 04-23-2008, 11:11 PM   #6
semaj
Moderatour
Member#: 113533
2013 Leafs
Hatewagon
Aye
semaj is offline   Reply With Quote
Old 04-24-2008, 03:12 AM   #7
Loomin
Member#: 118113
98 Brights!
welcome to my world lol.
although im a bit luckier with a 12.5 lb flywheel. still an exedy 3-puck tho.
Loomin is offline   Reply With Quote
Old 04-24-2008, 03:16 AM   #8
patr
Member#: 97
find the weakest link in your chain, and what does it hold you to ?
in general, a built block doesnt' make "more power" than a POS block, unless the CR is significantly changed, but even if it is, unless you raise the boost (which is normally why you want a built block) you aren't going anywhere. Yes some heads flow more than others and yes some piston designs are better than others, but if your turbo is out of juice, its out of juice. same for injectors...
on a turbo which is already maxed out on a stock block, building a block isn't going to get you anywhere... except for maybe even more out of the efficiency range of that turbo...
building a block gets you really far if you have like a gt35 or something which isn't even trying at 21psi... then a built block is a good idea to run it harder. Or, if you have a setup and want to get better heads, that makes a difference.
I've never seen any sort of pinks setup ever come close to those numbers on a DD dyno, nor a vf34. Its not the tuning thats deciding that either...
patr is offline   Reply With Quote
Old 04-24-2008, 03:27 AM   #9
Loomin
Member#: 118113
98 Brights!
time for a 20g.
Old 04-24-2008, 10:19 AM   #10
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
My vf24 on the 2.0l came close to those numbers, and that block had 50% leak in two cylinders didnt it?
Anyway I want driveability more than peak power, I'll take whatever you can get out of it for me
Old 04-24-2008, 12:03 PM   #11
patr
Member#: 97
the hp isn't really going to go up if the turbo is already maxed out...
i.e. pick a 1.5L engine. max out the turbo until its a heat gun... put the same turbo on a 3L engine, with same header setup etc. the turbo is going to max out way sooner in the RPM band. the tq number at that point will be way higher. the peak hp wont really because the turbo will be out of juice way sooner. Now do the same test, but with the turbo not maxed out, but in its peak efficiency range for each setup. you're again not going to get a huge number.
Old 04-24-2008, 05:33 PM   #12
clsmooth
Member#: 86394
2000 RS Coupe
Blue Ridge Pearl
You feel you'll avoid future problems with stock rods?
clsmooth is offline   Reply With Quote
Old 04-24-2008, 05:34 PM   #13
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
300whp with a vf34? I hope you hit that.
007WRX is offline   Reply With Quote
Old 04-26-2008, 12:35 AM   #14
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
It lives.
Old 04-26-2008, 02:11 AM   #15
shum_87
Member#: 129898
2001 Impreza
how much is all this costing you? I'm very interested in doing an engine rebuild in the future, but just curious to know the numbers you're dealing with.
shum_87 is offline   Reply With Quote
Old 04-26-2008, 02:43 AM   #16
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
I work at a parts store, so I get everything at cost. My cost for this would not be comparable to yours.
Shifter doesn't want to go into 3rd and 5th mems3 Transmission (AT/MT) & Driveline 0 10-04-2009 11:44 PM
3rd, and hopefully last engine to go into the RSTi Splinter Built Motor Discussion 39 05-12-2008 02:05 AM
I'm scared to go into the Audio forum... rogue Off-Topic 16 01-25-2008 06:32 PM
need some advice for which engineering field to go into... josh...just josh Off-Topic 39 11-02-2005 04:26 PM
So, I'm hydroplaning down the highway yesterday and realize that I'm going into the m Grap Off-Topic 48 09-29-2004 02:59 PM
Message Board Statistics All times are GMT -4. The time now is 04:13 AM.
