Old 04-13-2008, 07:26 PM   #1
polish_lukasz
Member#: 160452
2007 Impreza WRX STI
Obsidian Black Pearl
Default P0171 System Too Lean (Bank 1)
hey guys i just got this one
i have 5200 miles on 2007 STI,
I found some similar stuff about it and it says i should clean a fuel filter or injector, Is that true???????
Well i had this car on stands for about 3 weeks so do you think the dirt would stay in one spot in a tank and fuel pomp sucked it or something????? I'm trying to figure out what can coz that
But i do have some mods
Intake
CatBack
Also i order Accessport but it will arrive at monday, i just want to take for a small ride today before i flash the ecu. And this code appears. Any idea? any help? thanks
polish_lukasz is offline   Reply With Quote
Old 04-14-2008, 09:32 AM   #2
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Is your intake fairly new? That may be the culprit or some loose hoses. This is a common code - try doing a search for "P0171" and you'll see what has caused other members to get this code.
Hank3 is offline   Reply With Quote
Old 04-14-2008, 11:17 AM   #3
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
pDubs is offline   Reply With Quote
Old 04-14-2008, 08:57 PM   #4
polish_lukasz
Member#: 160452
thanks guys
@Hank3
@pDubs
Of course i searched for it but i found a lots of stuff about it, and i just want to get quick opinion what can be wrong, I'm pretty sure that CEL is because of the Air Intake, I had a few CEL's so far fro example
P0102 MAV or VAF Circuit Low Input
P0113 IAT Sensor 1 High Input
Anyways thanks for respond
Old 04-16-2008, 01:28 AM   #5
2xhighpsi
Member#: 158089
2004 STi RomRaided
You probably have a vacuum leak post MAF related to the intake. Check all your clamps and couplers connecting to the inlet and the connection from the inlet to compressor housing.
I had this code from my stock inlet tearing open and taking in more air than was originally counted by the MAF; thus creates a code for too much air, and not enough fuel.
Just an idea to start with,
2xhighpsi is offline   Reply With Quote
Old 04-16-2008, 12:30 PM   #6
Rodwrx23
Member#: 170948
If you had those other CEL's, you're issue is most definitely intake related, more than likely a leak. I don't think you have nearly enough miles for it to be related to the front 02, dirty fuel filter, or many of the other causes.
Rodwrx23 is offline   Reply With Quote
How to fix: p2096 Post Catalyst Fuel Trim System Too Lean Bank 1 Honkey3k Normally Aspirated Powertrain 3 02-11-2016 10:44 PM
CEL - P0171 System too lean LTSmash Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 08-24-2011 05:43 PM
cgeck engine p1071 system too lean bank 1 brianmurder13 General Community 7 04-05-2009 04:19 AM
cel code p0171 system too lean ( bank 1) gillyfesh7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-01-2008 11:59 AM
CEL Code P0171 system to lean bank 1??? Crump Service & Maintenance 4 05-04-2006 01:57 AM
