Old 04-14-2008, 08:48 AM   #1
dunk
Member#: 15359
Default Wheel Bearing Grease
Looking for any recommendations on what grease to run in the wheel bearings. I've been using the stock grease, and replacing the bearings twice a year, however have been wondering if it's worth repacking them.
thanks
Duncan
dunk is offline   Reply With Quote
Old 04-14-2008, 09:10 AM   #2
GQ
Member#: 4830
12 DucatiSF/Abarth
Red/Nero
I have heard good things about Redline grease.
http://www.ogracing.com/catalog/2-Ca...NTHETIC-GREASE
GQ is offline   Reply With Quote
Old 04-14-2008, 09:25 AM   #3
STiBottom
Member#: 127041
02 WRX
Midnight Blue Pearl
Huh? Twice a year??? I did one a few weeks back and it made me never want to do it again.
STiBottom is offline   Reply With Quote
Old 04-14-2008, 12:52 PM   #4
XmanSTi
Member#: 65206
1986 Brat
Red
I use the Neo HP800 high temp wheelbearing grease, seems to stay in the bearings longer than the stock stuff. Rated to 800*F. Soak out the stock grease with mineral spirits and repack by hand. A tub costs about $30 and is good for at least 10 bearings, possibly more. Messy but a good idea if you get high brake temps and heavy loads from sticky tires.
http://www.allraceoil.com/neolubricants.html
http://www.allraceoil.com/neohp800bearing.html
The Neo CV grease is a good idea as well.
XmanSTi is offline   Reply With Quote
Old 04-14-2008, 02:17 PM   #5
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
thanks
Duncan
What you need is the 6GunRacing kit to covert to the 05 front bearings.
-Tom
trhoppe is offline   Reply With Quote
Old 04-15-2008, 02:05 AM   #6
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
I use Amsoil Series 2000 racing grease. I also used to pack a spare set of knuckles when I ran a 5x100 hub.
When you say 'stock grease', do you mean the little dabs that come in a new set?
eastcoastbumps is offline   Reply With Quote
Old 04-15-2008, 03:44 AM   #7
slalom274
Member#: 29757
06 STI
I also used to have to replace my front wheel bearings about that often in my wrx, about every 3 or 4 track days. I switched to Neo HP800 and it made a HUGE difference. I think I had to replace them like once more since I switched to the new grease. I really recommend it, and yea replacing and re greasing them is a huge pain, so its definitely worth it.
slalom274 is offline   Reply With Quote
Old 04-15-2008, 12:17 PM   #8
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
What parts should I looks for if I want to have some "spare" wheels bearing setup? Just knuckles and hub?
I'm assuming I'd need to do an alignment after installing new ones right?
xcdhridr is offline   Reply With Quote
Old 04-15-2008, 02:01 PM   #9
TubeDriver
Member#: 14987
I use the ART front bearings which last longer than OEM. They look to be packed with the red Redline bearing grease. I go through a set of front hubs/bearings each season.
TubeDriver is offline   Reply With Quote
Old 04-15-2008, 02:21 PM   #10
dunk
Member#: 15359
Where can I get ART bearings?
Duncan
Old 04-15-2008, 02:34 PM   #11
mesa50w
Member#: 83044
04.5 blue STi
97 miata, 93 miata turbo
^^^what he said
mesa50w is offline   Reply With Quote
Old 04-15-2008, 03:08 PM   #12
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
I used to eat bearings like mad (and crack rotors) until I switched to Stoptechs - now I replace the bearings usually once a year, just as insurance. I carry a spare set of spindles with me as well.
-Keith-
CTKAG is offline   Reply With Quote
Old 04-15-2008, 04:18 PM   #13
TubeDriver
Member#: 14987
http://www.appliedracingtechnology.com/
but they only make em for Miatas.
I should have been more specific but I think that if Redline grease is good enough for ART hub/bearings then it would probably work well for STI bearings too.
Duncan
Old 04-16-2008, 04:05 AM   #14
slalom274
Member#: 29757
06 STI
Yea just a spare set of knuckles and hubs, and that should be it. You shouldnt NEED a spare set as long as you replace the bearing as soon as you feel it is loose. If you wait too long to replace it you risk damaging the inner hub, which is easy to do actually. And by switching to the Neo grease you will be replacing the bearing much less often and negate the need to have a spare set.
Old 04-16-2008, 04:07 AM   #15
slalom274
Member#: 29757
06 STI
Lol, why mention it then?
Go with the Neo grease.
Old 04-16-2008, 12:42 PM   #16
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
I use RX7 bearings and they're great. Never had a problem. But they don't fit a Subaru, so you're SOL.
Old 04-16-2008, 12:48 PM   #17
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Yes, just a knuckle and hub. I went to a pick and pull junkyard and got a set for $30. They came in very handy at the next track day. One of my friends lunched his right wheel bearing and I gave him one. Then I had a ball joint go bad on the left side and had to swap the whole knuckle since I couldn't separate the ball joint from the knuckle.
Old 04-16-2008, 02:14 PM   #18
dunk
Member#: 15359
I bought a spare set recently. They'd been sitting outside for awhile, so I need to disassemble them, knock the rust off, paint and then reassemble. After that I'll just store them in the trailer until they're needed.
Duncan
Old 04-24-2008, 08:02 PM   #19
dunk
Member#: 15359
When you repack the bearing, do you take out the plastic retainer and remove the inner races, or can you just pack the bearing as a unit. I've soaked them in mineral spirits to remove the factory grease.
thanks
Duncan
Old 04-24-2008, 09:19 PM   #20
XmanSTi
Member#: 65206
1986 Brat
Red
I pull them apart and clean them up thoroughly. I use a screwdriver and my fingers (wear gloves) to really clean everything out well. There is a lot of grease that doesn't come out unless you do that. Not sure how the two different greases would interact. Some don't like each other and turn sticky. Better to be safe than sorry, the two halves go back together pretty easily. You also need to repack them separately or there just won't be enough grease up in where it needs to be. I'm sure there is a bearing packing process somewhere online, doesn't need to be subaru specific, a wheel bearing is a wheel bearing.
Old 04-25-2008, 07:27 AM   #21
dunk
Member#: 15359
thanks,
Duncan
Old 04-26-2008, 01:34 AM   #22
Mykl
Member#: 14311
2010 GTI
-Tom
I second this.
Mykl is offline   Reply With Quote
Old 04-26-2008, 09:14 PM   #23
Sharky NRK
Member#: 29549
2003 WRX
so redline or neo - any opinions on which is better? I really like the idea of the spare knuckles. I need to look into that - pick and pull here I come lol
Sharky NRK is offline   Reply With Quote
Old 04-27-2008, 12:05 AM   #24
slalom274
Member#: 29757
06 STI
With the neo grease I used to push the grease in from one side until all the other grease was out. The oem grease is white while the neo is blue so its easy to tell one from the other. Its not necessary to clean off all the old grease first.
wheel bearing grease ? jsin93816 Brakes, Steering & Suspension 20 02-15-2010 12:25 PM
FS: Wheel Bearings w/seals. Prepacked with Neo HP800 Bearing Grease Gro Harlem Suspension/Brakes/Handling 9 03-04-2009 10:35 AM
wheel bearing grease DJ_STI Newbies & FAQs 8 01-17-2005 10:10 AM
which wheel bearing grease ? JasonE Brakes, Steering & Suspension 3 06-08-2003 11:15 AM
Wheel Bearing Grease BG5 Service & Maintenance 4 12-07-2001 03:25 AM
