Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 04-14-2008, 10:10 PM   #1
burm
Member#: 153807
2001 Impreza rs
Aspen white
Default oil leak front main seal?
I'm replacing my crank sprocket and woodruff key and I have had an oil leak, that I could never find where is was coming from. It would drip down and blow back on the the exhaust, and smoke. Which would get some interesting looks while sitting at the stop light. Any way when i took off the timing casing there was oil along the bottom. So I thought cam seals. But when I took off the timing belt, I could see the oil looks like it some from the crank area. I know the oil pump is back there. and I believe the crank seal, and front main seal ( are the crank seal and front main the same thing?). Well give me in your input and let me know what you think and how hard this would be to replace? I do already have the timing belt out the radiator fans out, the alternator out and all that good stuff. Oh also, I had the head gasket replaced in august. The the timing belt, cam seals and some other seals were also replaced.
burm is offline   Reply With Quote
Old 04-15-2008, 12:16 AM   #2
Sudafed
Member#: 70090
2002 2.5 RS
crank seal and front main are the same. it could be your oil pump or the crank seal, just pull the oil pump off and reseal it. replace the o ring behind it also, and install a new crank seal.
Sudafed is offline   Reply With Quote
Old 04-15-2008, 12:36 AM   #3
burm
Member#: 153807
2001 Impreza rs
Aspen white
how difficult would this be, and how much time would it take. My cars been down for a month, because i only have an hour here or and hour there to work on it.
Old 04-15-2008, 01:03 AM   #4
Sudafed
Member#: 70090
2002 2.5 RS
not too difficult at all. you just need to clean up the pump surface and block surface and use a liquid sealant, and make sure you torque the bolts to spec. put the new crank seal in after the pump is on of course. you can take the pump off with the old seal in it too, that will make it easier to get out. it depends on your skill level, but it shouldnt take more than 30 minutes with everything already apart.
Two leaking rear main seals in a year?? Leaking Head Gasket...Oil Pressure Issues??? jsavage Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-21-2010 11:06 AM
How deep should front main seal be installed? Patrick Olsen Service & Maintenance 6 06-22-2007 12:20 AM
Cam and front main seals leak more since replacement???? logoguy General Community 0 09-09-2005 10:06 PM
Replaced front main seal and oil pump o-ring archer Normally Aspirated Powertrain 4 12-28-2001 03:28 AM
Front main seal, timing belts -oil pump&water pump? immortal_suby SVX Forum Archive 3 06-25-2000 07:15 PM
