Old 04-14-2008, 10:20 PM   #1
cah
Member#: 131965
2003 WRX
Default will a 2.5 legacy automatic tranny fit to a 1991 2.2L automatic?
will a pre 1999 2.5L legacy automatic tranny fit to a car that had 1991 2.2L automatic?
my stepdad is trying to fix his daughter's legacy, and the (pre 1999) tranny he bought. so far he has notices a difference in the speedometer sensor thread size/pitch, and that the older tranny had a mechanical cable, and then the newer tranny uses an electronic sensor.
does anybody have experience with swapping transmissions in these old legacy's, and does anybody have insight on if this is a lost cause or if it might work?
thanks,
Chris
cah is offline   Reply With Quote
Old 04-14-2008, 10:40 PM   #2
cah
Member#: 131965
2003 WRX
hmm never mind he just called me and ended up figuring it out on his own. everything worked fine.
Old 04-15-2008, 12:01 AM   #3
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Wouldn't the 2.5 be from a GT so it would have a 4.44, and the 2.2 would be a 3.90? Will the 91 TCU even work with the new transmission?
subiekid is offline   Reply With Quote
Old 04-15-2008, 12:18 AM   #4
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
GT or Outback and yes both are 4.44 so no and the TCU would prolly need some resistor or something.
Kawikid20o2 is offline   Reply With Quote
Old 04-15-2008, 12:47 PM   #5
cah
Member#: 131965
2003 WRX
interesting. I will be sure to mention this to him.
I don't know the details, but I am under the impression that a previous owner changed out (what I am guessing to be be) the rear diff and that has contributed to the transmissions failure. although I am not sure what the current configuration is.
Is there a correct way to install a 2.5 (probably gt/outback etc since it's a 2.5...) transmission on a 2.2 legacy, or is it more trouble than it's worth.
at this point i think he has it physically together again, but that seems to be no guarantee that it is configured properly.
thanks for you input!
02 2.0 WRX flywheel in an 03 2.5 Legacy, will it work? meandean Transmission (AT/MT) & Driveline 3 11-15-2006 11:45 PM
will a 2002 or 2004 wrx motor fit to my tranny? simprezl25 Subaru Conversions 2 08-18-2005 11:26 PM
Will a 2002 WRX rear sway bar fit into a 1999 2.5 RS buz1nonly Brakes, Steering & Suspension 5 07-21-2005 03:54 AM
Will 2.5 RS Bumper Cover fit onto 94 GC8? ashleyneon Interior & Exterior Modification 9 12-16-2001 10:50 PM
