Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 04-15-2008, 12:14 AM   #1
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Impreza GC8 My '96 XP Impreza build
Originally Posted by Crash477 View Post
Dude, you must post pics and info on the build!!! Please!
Updated first picture as of 6/24/11.
Original build post starts here-
This is what it looked like over the winter-
I am doing everything I can afford and have time for to make this a competitive XP car. It started as a '96L 2dr Impreza. I swapped in a WRX engine, did the wiring myself (with help from Nasioc and my co-driver), deleted AC, airbags, radio, and every other extra (not necessary) electrical component possible. Switched to a braille race only battery that weighs 5.4 pounds mounted in the rear passenger seat area. The interior is gutted, no sound deadening, no carpet, no passenger seat or belts. Hacked the dash to lose weight where I could and keep a decent mounting points for the gauge cluster. The front a rear bumper beams were cut up to just support the bumper cover, but don't lean on the bumpers. Fog lights are gone, all AC components are gone, all airbag components are gone, this car didn't come with power windows or ABS, so that saves me a little weight. Last I think is the home-made CF hood, reference this thread. Final weight on the scales was 2367 lbs with 1/4 tank of gas.
Power comes from the '02 WRX engine through an 11 lb flywheel and excedy stg 1 clutch to the stock '96 tranny (I like the 3.9:1 ratio). I added a LSD rear diff last year to help direct power to the 225/50R16 V710's at each corner. The engine is helped by no cats, a 3" turbo back with a stromung dual dip muffler, TGV deletes, 665 cc injectors, Grimmspeed Phenolic spacers, an APS 65mm intake, and an enginuity tune to make it all work together. 236whp 240wtq is what it put down on a dynodynamics when it was tuned.
Suspension is Koni SA's in stock housings with a GC coil-over kit and 600F 650R springs. Helper springs are 200F 150R with 1.75" of travel in the helper spring at each end. 22mm whiteline bar up front, 24mm Helix in the rear through Helix endlinks. Noltec camber/ caster plates up front with Cusco GC specific camber plates in the rear. Whiteline ALK in the front with custom UHMW front control arm bushings. Chassis stiffening provided by GTspec fender braces (fitment on these is crap, but the work great once you get them in), a GC STI CF front strut bar, Whiteline rear subframe lock bolts, and a Rally Innovations Harness bar (these guys are awesome).
Interior additions include a Sparco 333mm steering wheel, a Corbeau Forza seat, Schroth 5pt. harness, assorted gauges on a center gauge cluster, and the ECU has been remounted on the center tunnel (just to be different).
My first event this year with the car in the described setup was in Iowa this past weekend. The car felt great and was much faster than I could handle. After some practice in it I think I should be able to post some decent times. Locally I have Steve G's (Mnbiker) XP Miata to chase, so the competition will be good (assuming I am anywhere close to him).
In the next few year I am planning on too many mods to list as the budget allows. First and foremost will be ~275 or 12" wide R-comps or slicks, a built tranny with good diffs, and more power.
I won't be at Nat's this year or next due to work, but 2010 I am planning on being there with this car to push for a decent placing. Should be a good challenge in the coming years.
speedyHAM is offline   Reply With Quote
Old 04-15-2008, 12:23 AM   #2
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
Dude, that is so awesome! Best of luck
Crash477 is offline   Reply With Quote
Old 04-15-2008, 12:28 AM   #3
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
Oh, and you should definitely put an EJ257 in it, and get some 15x10" wheels with 275 hoosiers
Old 04-15-2008, 01:29 AM   #4
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
The 257 is on the list, but I'm still split between 15x10's and 275's or 15x14's and 23.5 x 13.0R-15 R25 compound slicks.
Thanks for the compliments.
Old 04-15-2008, 06:57 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Note that wheel widths beyond a certain point carry weight penalties in the Prepared category. At least, they used to.....
That said....I'd put some 13's on it just to be that much different!
I agree that an EJ257 would be a nice addition once you get a handle on what the EJ20 can do.
Jay Storm
Old 04-15-2008, 09:11 AM   #6
Chiketkd
Member#: 71634
In hibernation...
+12345 Sweet project! I'm jealous.
Chiketkd is offline   Reply With Quote
Old 04-15-2008, 09:39 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Sean, that's awesome!! First thing I thought when I saw that hood, is "man, he's getting really good". Glad to see you are finally able to make this your full blown toy car now!!! Can't wait to see some video from it once you've adjusted to it
oh, guess what I did this past weekend that reminded me of your garage?...more frozen lateral links
Old 04-15-2008, 10:45 PM   #8
ejh25
Member#: 65267
Congrats!
That is quite an accomplishment.
ejh25 is offline   Reply With Quote
Old 04-16-2008, 11:59 AM   #9
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
That is one cool car!
forced4 is offline   Reply With Quote
Old 05-17-2008, 02:04 PM   #10
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Got a good picture taken of my co-driver last weekend.
Old 05-17-2008, 03:44 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Looks just like my car....except alot taller!
Jay Storm
Old 05-17-2008, 04:22 PM   #12
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Jay Storm
Geez that's low. Did you find it beneficial to lower it that far? I know I should lower mine another 1/2" or so, but it looks like your car is at least 1.5" lower than mine.
What are your ride heights (if you don't mind sharing).
Old 05-17-2008, 05:01 PM   #13
Aaron B
Member#: 67924
2003 #25/125 STX WRX
Well, I'm guessing running 13" wheels has a little something to do with the overall height as well.
Aaron B is offline   Reply With Quote
Old 05-17-2008, 06:44 PM   #14
Boxologist
Member#: 21118
looks like its going well so far. I think u will progress quickly enough to show the limitations of the ej205. if u have the extra weight, always keep an eye out fo that ej257 shortblock.
i think u may be to heavy to see the best results of teh r25. r35 maybe more suitable?
bigger bar up front, and eventually ur gonna cage it and ditch the stop gap sreet bracing. then u'll have fun!
Boxologist is offline   Reply With Quote
Old 05-17-2008, 08:35 PM   #15
Storm
Member#: 5218
96L Most Over-
Developed Beater
Yeah, the 13" wheels really drop the car down. To the point where it just doesn't roll much at all. That above pic is with 600F 450R rear springs and no bars at either end. My ride heights are 12.5" up front and 13" in the back. Here's another pic in a fairly heavy state of cornering.
I'm anticipating a little raise once we put the 15x10's on.....
Jay Storm
Old 05-18-2008, 02:57 PM   #16
shane86
Member#: 67387
04 WRX - STX
05 LGT Limited Wagon
Sean, you need some new seat brakets :O
Got to take this thing out for a run during buck runs... i'm all strapped in, rev rev rev... launch... and the seat slides all the way back!
the best part, is the car's owner is running start marshal for me while i took the run!
shane86 is offline   Reply With Quote
Old 05-18-2008, 05:24 PM   #17
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Called the seat company the nest day and they are sending me a new set. I was less than pleased with Courbeau. Apparently they had a few QC issues with the early sets of sliders this year and I got one of those sets. For now the seat is riding on some modified stock seat brackets and it works great. It might just stay on the stock brackets for how much better they work (and they aren't any heavier).
Old 05-18-2008, 09:38 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
yeah, I use to work at a shop that was a corbeau dealer...those seats are crap IMO...
"cheap" but you get what you pay for...
Old 05-19-2008, 12:02 AM   #19
jakeachy
Member#: 162893
00 STM GC8
that is a pretty awesome setup!
jakeachy is offline   Reply With Quote
Old 07-06-2008, 11:01 PM   #20
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Some video that was taken at an autoX/ high speed run. Very fun event, a short autox course followed by a ~0.2 mile straight before the finish flags. I took 3rd at the event behind a pair of Evo's.
http://www.youtube.com/watch?v=f8Erjg80el4
http://www.youtube.com/watch?v=j7Ay0jpTFOk
Old 07-07-2008, 06:49 AM   #21
Storm
Member#: 5218
96L Most Over-
Developed Beater
Sweet!!!! Looks good!
Jay
Old 12-22-2008, 10:55 PM   #22
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
2008-'09 winter update-
I took 1st in XP for one of the two local clubs mostly due to showing up to every event and a certain Miata not being so reliable, and not very drivable in the rain. I'm happy with that, but for next year I want to be competitive when that Miata does run. My local XP competition took 6th at Nats this year 2.244 seconds out of first.
Plans include-
275/35R15 A6's on 15x10's
lexan
Front splitter
PnP turbo
Turbo inlet
equal length headers
E85 tune
3" lightweight turboback- just far enough back to be legal
Cross drilled rotors front and rear - weight savings
built tranny
Clutch front and rear diffs
35/65 center diff
and I'm aiming for it to weigh in around 2100 lbs ready to run
This car won't be going to any road circuts, it won't be driven on the road, it will just be an autox car.
I got started last weekend-
Next I have to get out those pesky door beams.
Compare the wiring to the pictures above from last year.
Old 12-22-2008, 11:06 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
sounds like quite the recipe sean...I'll be following the thread for sure.
Curious, how much does the car weigh now?
Old 12-23-2008, 12:05 AM   #24
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
It was 2367 with 1/4 tank of gas at the beginning of 2008, right now it's probably 60 or 70 lbs lighter than that and dropping weight every time I work on it.
Old 12-23-2008, 11:56 AM   #25
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
Sick!!!
xcdhridr is offline   Reply With Quote
'96 Subaru Impreza AWD 85k 5 spd energy0uth MAIC Private Classifieds 14 06-15-2009 02:09 PM
'96 Subaru Impreza AWD 85k 5 spd energy0uth Private Vehicle 'For Sale' Classifieds 13 06-12-2009 09:41 PM
'96 - '98 impreza L wagon questions. Jeepman775 Subaru Conversions 5 03-17-2008 12:23 PM
how do I set my SAFC 2 on my '96 WRX WRXpro General Community 6 05-01-2005 12:45 PM
Picking up my '96 OBS... efoo New England Impreza Club Forum -- NESIC 6 10-01-2000 07:25 PM
