Old 04-15-2008, 08:43 PM   #1
subaru7717
Member#: 53922
2000 Legacy GT
Default Does this sound like a bad cat?
Car: 2000 Impreza RS w/ 140k miles, stock
CEL Codes: P0303 (Cylinder 3 misfire) intermittent
I have replaced
fuel filter
spark plugs (#3 was covered in oil)
spark plug wires
spark plug gaskets and cleaned inside valve cover
cleaned coil pack
When I start the car, exhaust is smoky. Afraid to drive more than 1 mile at a time. When I stop, engine idles too low, and exhaust is sputtering with a sulfer smell. Engine is shaking like it wants to stall.
My question is if my cat is bad, then why do I not a get any CELs pertaining to my cat? I have been driving my sisters car for 2 weeks now trying to fix this, and I am very close to taking it to a mechanic. The reason I haven't is because I could barely afford it.
If I do need to replace the cat, is it OK to purchase a universal and have a muffler shop weld it in place?
subaru7717 is offline   Reply With Quote
Old 04-15-2008, 09:14 PM   #2
stealth06wrx
Member#: 131568
2006 WRX to 2015 WRX
OB Swirl / DGM
you should do a compression and leakdown test. Sounds to me like you have a bad ringland or piston? Is your car consuming oil? Does smoke come out of the oil filler cap when the car is on?
stealth06wrx is offline   Reply With Quote
Old 04-16-2008, 10:43 AM   #3
subaru7717
Member#: 53922
2000 Legacy GT
I have also concluded that my car is burning/losing/something coolant. I put fresh coolant in 2 weeks ago. after driving 1 mile, I had to add 2 cups. last night after driving 2 more miles I had to add 4 more cups... I do not know much history about the car before 130k (now at 140k)
Could this be a combination of head gasket and clogged cat, or does a head gasket problem cause all these issues?
Old 04-16-2008, 03:16 PM   #4
stealth06wrx
Member#: 131568
OB Swirl / DGM
A head gasket would definitely cause those types of problems. Do a leakdown test to see which side its on. Losing coolant is never a good sign.
does this sound like a bad idle air control? subaru7717 Legacy Forum 4 03-27-2006 08:38 AM
does this sound like a bad clutch to you?!? janikphoto Legacy Forum 10 03-26-2006 04:08 AM
Does this sound like an alright system? ImprezedRS Car Audio, Video & Security 3 01-14-2002 02:52 PM
Does this sound like a good idea??? SomeoneStoleMyName General Community 33 12-09-2001 06:44 PM
Help Me:- Does this sound like a normal Canadian Address? MY99 2.5GT Canada Region Forum 11 07-16-2001 10:50 AM
