Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 04-16-2008, 02:04 AM   #1
JDMmanny
Member#: 177576
2004 subie
325boi !!!!!!!!!
Default 17x9.5+22,17x9.5+38 5x114.3 fit sti?
wanted to know if i can run these rims on my car running 245/40/17 all the way around on a 06 sti...? thanks
Gram Lights 57C
two are 17x9.5+22
and other two are 17x9.5+38
5x114.3
JDMmanny is offline   Reply With Quote
Old 04-16-2008, 05:54 AM   #2
mywaganiswhite
Member#: 150586
2084 Wagin
19x7 Krew
yeah it could fit but it wont be happy about it. I would put the +38 in the rear with normal camber and the +22 in the front with lots of camber. It would look hot and would be as flush as the zerosports 06/07
mywaganiswhite is offline   Reply With Quote
Old 04-16-2008, 08:16 AM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
If you don't want to do some modification to the alignment & fenders, no, it won't fit. And a 245 on 9.5" rim?
Old 04-16-2008, 10:00 AM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
mad stretched & flush yo!
Old 04-16-2008, 10:25 AM   #5
mav1c
Hoodbridge!
Member#: 560
Yeah. I'm pretty sick of all this flush BS.
Old 04-16-2008, 12:47 PM   #6
JDMmanny
Member#: 177576
2004 subie
325boi !!!!!!!!!
what kind of modification? rolling fenders? spacers? i was just thinking that a 245 would be good because that was it wont rub...? a noob when it comes to rims, off set, camber...etc..
oh ya would i be able to DD on this set up?
Old 04-16-2008, 01:28 PM   #7
mav1c
Hoodbridge!
Member#: 560
You're a newb, so let's just say DON'T get them. They won't fit. Look for wheels that have all the same offset, and are somewhere in the +40 to +50 range, depending on width.
You should look through this: http://forums.nasioc.com/forums/showthread.php?t=335263
and This: http://forums.nasioc.com/forums/showthread.php?t=400311
Old 04-16-2008, 01:41 PM   #8
JDMmanny
Member#: 177576
2004 subie
325boi !!!!!!!!!
not a newb... this is my second sti so been around for a long time but just always went for performance first and not too much on wheels.... bit of help would be nice.
ps. if you say they wont fit, explain why.. thanks
Old 04-16-2008, 01:42 PM   #9
remowgn
Member#: 41149
09 FXT
SSM
Most 245's (especially 245/40's) are only spec'd up to a 9" wheel. You would need at least 255's, unless you really want to go for the stretched look and don't care too much about the performance of the tire.
remowgn is offline   Reply With Quote
Old 04-16-2008, 01:46 PM   #10
mav1c
Hoodbridge!
Member#: 560
They won't fit because the offset is too low, especially the +22, and they're too wide. This is if you want to just bolt them on the car right now. You could get them to fit if you wanted to run a lot of negative camber (will effect the handling and tire wear), and do some major fender rolling/pulling. A 245/40-17 tire is really not wide enough for a 9.5" wide rim. If you want to run a 245 get an 8" or 8.5" wide rim, and the thinner wheels will be lighter too. And you really want all 4 wheels to be the same offset.
Old 04-16-2008, 01:49 PM   #11
JDMmanny
Member#: 177576
2004 subie
325boi !!!!!!!!!
thanks...
FS/FT : 17x9 Gun metal 5 Zigen Pro Racer 520 wheels +38 5x114.3 jaironsti Wheels/Tires 7 09-06-2010 10:30 PM
Volk Racing CE28N by Rays Engineering 19x9.5 +22 19x10.5 +22 5x114.3 Japan TimeAttack vutony Wheels/Tires 12 04-20-2010 01:30 PM
Enkei Rpf1 17x9.5 +38 5x114.3 Silver with Tires dtmcnamara Wheels/Tires 19 08-19-2009 10:46 AM
FS socal Gram Lights 57C 17x9.5+22,17x9.5+38 5x114.3 Ray0124 Wheels/Tires 17 04-17-2008 02:26 PM
Wanted: 17x8.5 +48 or 17x9 +45 5x114.3 - fits over Brembos. mav1c Private 'Wanted' Classifieds 9 03-18-2008 08:03 AM
