Old 04-16-2008, 11:53 AM   #1
ret030
Member#: 110494
2006 WRX- Stage 2
Crystal Gray Metallic
Default Hid Help!!
Ok... I bought a cheap crappy pair on ebay a while ago to try out... 8k's.... HORRIBLE decision... so I am going out and getting a good pair this time...
Here lies my question...
I have read TONS of threads and found tons of 'good' types and vendors... Which ones seem to be the best? I have read so many that I can't keep them straight!!
My initial idea was to go with ProLumen's. They have a special right now at bavtoys.com where you can buy one pair for 250 bucks and get a pair free... for your fogs... I am thinking 3ks for the fogs... or if not... getting a yellow foglight bulb... say piaa ion crystals... anyone have any idea on yellow foglight bulbs if i decide on a bulb not hid for the fogs??
I think I have narrowed my opinion to wanting 5000k's... I have looked and looked... and I really wouldn't mind the small blue hue that some of the bmw's and other european cars have... but I think that I want 5ks... 6ks still have a little too much blue in them... maybe there is something in between 5ks and 6ks... that has mostly white with just a hint of blue??
So that was my initial decision... ProLumen's ftw... heck of a deal for two sets of HIDs for 250 bucks... But now as I look more... I see other ones sometimes having better reputations... say Phillips... and Mcclulloh (sp?)... and I am completely confused on what brand seems to be the best...
Can ANYONE point me in the right direction?? Any opinions on these or any other brands... or places to buy??
Any help would be appreciated... THANKS!
ret030 is offline   Reply With Quote
Old 04-16-2008, 02:39 PM   #2
ret030
Member#: 110494
2006 WRX- Stage 2
Just called and talked to the guys at lightwerkz... I'm gonna go thru them...
/thread
Old 04-16-2008, 03:55 PM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
yep if you are gonna get plug and plays at least go through lightwerkz
since you have an 06 i would strongly reccommend a tsx retrofit using oem bulbs and ballasts, but with budget concerns and a pnp kit, lightwerkz will steer you in the right direction
jdubya301 is offline   Reply With Quote
Old 04-16-2008, 05:15 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
With an 06 you have H7 lights, so instead of buying someone's "kit" of dubious quality you can get OEM-grade HID components- D2S 4300K bulbs and standard Hella or Phillips ballasts. The D2S bulbs will fit directly into your H7 lights with a cheap set of adapter rings (readily available on Ebay and from various vendors).
The results will still not be as optimal as true OEM HIDs such as a set of STi lights or a full retrofit, but they will be far better than what you'd get from an aftermarket setup with rebased bulbs plus you will have zero trouble sourcing replacement parts in the future should you need them.
Old 04-18-2008, 04:49 AM   #5
PA-Outback2000
Member#: 161832
2000 Outback Limited
5000K or 6000K are very popular color temps. i would recommend apexcone from xenonexpert.com. i have had them since november and love them. they are $150 + $70 for lifetime warranty.
PA-Outback2000 is offline   Reply With Quote
Tech help HID HELP PLEASE give me some info Evolved8 Electrical & Lighting 11 02-12-2010 04:15 PM
HID help! and headlight wiring help! Speeding101 Electrical & Lighting 5 03-27-2009 05:42 PM
HID Help? Deeman81 Interior & Exterior Modification 5 12-27-2002 02:27 AM
PA: Locally, HID HELP!! RobPA Tri-State Area Forum 5 12-09-2002 04:45 PM
HID help ducktapeguy Forester Forum 16 12-04-2002 06:41 PM
