#1 |
Member#: 109527
Vehicle:1997 STI blue |
Well I thought I would start a thread documenting the slow assembly of a GC8.
The car started as a jdm RHD import and has been slowly modified over the years. Here is a link showing the first builds. http://www.youtube.com/watch?v=Jf94WIS1bCk The car was a solid 10 sec car but I felt we had reached the max potential with the setup. So we have stripped her down and trying to produce a 1000HP 2.5lt all alcohol motor running a twin scroll UR GT4202 kit. the goal is to get into the 8's with a manual box. The first order of the day has been to shed weight.we have gone to an all composite body, doors,fenders,trunk, Aluminum hood(lighter than the CF one I had )![]() ![]() ![]() Today it came out of the spray booth. ![]() ![]() ![]() ![]()
#2 |
Member#: 109527
The Engine is a Raw performance built unit consisting of a sleeved EJ22t block running a RAW crank/ internals package 9.5 comp.
the UR exhaust components have been swaintech coated. ![]() ![]() ![]() ![]() Last edited by saintluciascooby; 04-19-2008 at 06:46 AM. |
#3 |
Member#: 129832
Vehicle:2005 STI GT4094r |
jeez 8's that thing will be ridiculous
#4 |
Member#: 109527
I had ordered a drivers image intake manifold. when I received it I was disappointed with what had been done and between Ron and Gregg they decided to fabricate a new one the new manifold has intake horns and nicely finished porting, I hope it performs well.
If it doesn't I will have an extrude honed stocker waiting in the wings ![]() 1st manifold. ![]() ![]() 2nd manifold. ![]() ![]() ![]() ![]() thanks again gregg for a nice job. Last edited by saintluciascooby; 04-16-2008 at 10:13 PM. |
#5 |
Member#: 109527
The Fuel system is 8x 1600cc injectors driven by a 2000hp weldon pump,regulator and filter.
#6 |
Member#: 109527
Suspension is one of three manufactured for ESX for thier drag car.
I hope it works well the guys at perfection are very helpful so I am sure they will help me tweak it. The picture shows the helper springs on the front but they actually go on the back struts. The rear suspension parts are from Poltec (trailing arms, lateral links) for weight reduction along with a Torqline CF drive shaft and ultralight brakes from The Brakeman LTD and a hydraulic handbrake so there is no rear drums to add weight to the rear unsprung assembly. Tyres are be 10" Hoosier slicks all round. ![]() ![]() ![]() ![]() Last edited by saintluciascooby; 04-16-2008 at 10:08 PM. |
#7 |
Member#: 109527
As things progress I will put more stuff up.
Starting the plexi windows this weekend ![]() |
#8 |
Member#: 109527
Engine Mounts.
![]() ATI damper and oil pump drive. ![]() |
#9 |
Member#: 109527
Im trying for the 8's doesn't mean I will get there
![]() But I'll have a lot of fun trying!!!!! |
#10 |
Member#: 109527
Here is the Nitrous System designed by Wizard of NOS out of the UK. These are the guys supplying RCMS Gobstopper,Andy forrest, Zen Performance.
They do a great job. http://www.noswizard.com/ ![]() ![]() ![]() ![]() |
#11 |
Member#: 91074
Vehicle:04 sti white |
looking good. keep up all the good work and keep showing the progress
#12 |
Member#: 132130
NWIC
this thread rocks. awesome build..
#13 |
Member#: 33782
Vehicle:96 2.4L LR 35R Search before you PM me |
looking very good!! I know you've been working towards this for a while now.
**subscribed** |
#14 |
Member#: 9960
looks good so far! Keep up the good work!
question though...is this the one that hit the hydro pole when the steering locked while being towed by an suv? I saw that vid a looooong time ago and this looks really familiar in the pics posted on the video. |
#15 |
Member#: 84482
Vehicle:2005 STI.UR gt40r craving the corn |
great start man!!!
#16 |
Member#: 109527
Yea it hit the pole I will never hear the end of it. I wish the video had never been posted. it wasnt with my permision...
#17 | |
Member#: 9960
I'm also curious as to how the intake manifold solution will pan out.. Unfortunately we don't have many in the way of solutions on the market. Maybe I'll have to approach Ron as well for one. He's a good guy to deal with. |
#18 |
Member#: 9960
oh.. is there any reason why you did not go with ACPT for the prop shaft??
#19 |
Member#: 109527
Ron doesnt have anything to do with these intakes they come from Gregg at drivers Image, Ron was just giving the pointers on the second revision.
#20 |
Member#: 109527
Because torqline says 1400hp proof and the quality ext ,if you look at the two side by side there is no comparison, I believe from looking at the torqline unit it is filament wound construction where as the actp is a hand layup job, could be wrong though.
#21 | |
Member#: 9960
#22 |
Member#: 109527
heres a link.
http://www.torqline.com/product_detail_6.php They are around $2500.00-$3000.00 rated to 2200ft/lbs torque ![]() Last edited by saintluciascooby; 04-17-2008 at 02:42 PM. |
#23 | |
Member#: 9960
#24 |
Member#: 109527
US dollars, they come from the UK 1300-1500 pounds landed USA
One thing that I find strange since I changed to the CF shaft I havent broken one rear axel up until that point I had gone through 8, 6 stock sti and two upgraded shafts from the uk. the second set of upgraded shafts have taken all I can throw at them without a murmer. I wonder if how the shaft loads up on launch helps the shock to the drivetrain? |
#25 | |
Member#: 9960
It's hard to say though which is the way to go for drag racing though.. The steel stocker would be dead reliable and take all you can throw at it, while on the other hand, the CF one although lighter, is likely not as bulletproof.. It would be crazy the way to go for road-racing though for sure. I'd be curious to see how well the CF shaft holds up in the long run ![]() I'm thinking about getting in on one later on, but want to wait to see how they are holding up after a period of time. Have you used this shaft yet?? Does it wobble at all at speed or introduce any vibrations or anything into the car?? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| My V4 STI GC8 Build | bstoehr83 | Member's Car Gallery | 50 | 10-12-2009 05:05 PM |
| My NWIC GC8 Build! Lot of Pics | hustleshark206 | North West Impreza Club Forum -- NWIC | 22 | 08-20-2009 09:18 AM |
| My slow ass build continued | IllNastyImpreza | New England Impreza Club Forum -- NESIC | 82 | 11-20-2008 09:09 AM |
| My slow ass build continues | IllNastyImpreza | Built Motor Discussion | 27 | 11-05-2007 12:46 PM |
| Small ? on my slow build up | Mr.Krinkle | Newbies & FAQs | 5 | 09-06-2006 09:20 PM |
