Old 02-20-2002, 10:29 AM   #1
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Question O2 Sensor In Up-pipe Melted...????
Ah, guys? What does this mean?
I got a new exhaust leak, so I got a chance to go under and check it out. Well the entire back of the O2 sensor was melted off.... this is why I had an exhaust leak!!
I hope that this doesn't mean my EGTs are sooo hot that the O2 sensor cant handle it.... or does it mean that the O2 sensor was faulty? I would think that any O2 sensor could withstand the heat from hell....ya know?
Well, I bought another O2, this time its a Bosch sensor. Looks to be much beefier than the NAPA part I had before. But do I need to worry about any type of heat range on these things? I didn't think so, but I dont want to put the Bosch one in just to have it melt, too.
I would appreciate any input!
Thanks
Doug
BTW- both sensors are/were a 1 wire unheated O2.
dug-e-fresh is offline   Reply With Quote
Old 02-20-2002, 12:01 PM   #2
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
*whispers* Help!
Old 02-20-2002, 01:04 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Sounds like a bad part. I wouldn't worry about it unless you go through another, somehow.
Old 02-20-2002, 02:02 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
sounds like a bad sensor to me, if you EGT's were that damn hot the pistons would have melted LONG before that.
jeremy
Old 02-20-2002, 04:04 PM   #5
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
good point!
Old 02-20-2002, 06:12 PM   #6
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
take a look at the sparkplugs. if the cc is hot enough to fry an oxygen sensor then the plugs will show it.
a backfire in the exhaust could explain the o2 sensor.
ColinL is offline   Reply With Quote
Old 02-21-2002, 03:38 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
[i]
a backfire in the exhaust could explain the o2 sensor. [/b]
a very good point colin
remember that your exhaust pressure is about 30% higher then your intake pressure so a backfire coupled with constant abuse of pressure might have cause it to come apart.
jeremy
What size wrench to remove EGT sensor in up pipe? Aspenbullet Service & Maintenance 3 11-24-2006 09:38 PM
o2 Sens, in up pipe?? Ctracer911 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-26-2006 08:47 PM
o2 sensor for up pipe ninjaboy76 Engine Management & Tuning 4 08-13-2003 06:47 PM
A/F O2 sensor in up-pipe or stock - Results 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-31-2002 02:41 PM
NAPA O2 Sensor In Up-pipe Melted!...??? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-20-2002 03:44 PM
