Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-17-2008, 12:49 AM   #1
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
Default Rear ended in parking lot...anything to worry about?
My sister got rear ended in her 2002 (I think) Outback Limited sedan. I don't think there is any visible damage except for some scratches and scuffs. Is there anything internal that might need to be replaced as far as bumper shocks (don't know if they have them) and mounts go?
PS: I tried searching but the search function was down and the google search returned nothing useful.
RallyLegacy is offline   Reply With Quote
Old 04-17-2008, 12:02 PM   #2
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
If everything LOOKS ok (mainly no misalignment of the bumper or cracks in the body), you're most likely in good shape. If you're worried about it, get the rear end of the car up off the ground and check in behind the rear bumper to see if anything came loose. I believe all that is really between the bumper and frame is a couple pieces of reinforcement foam (styrofoam basically).
REXtard04 is offline   Reply With Quote
Old 04-17-2008, 12:16 PM   #3
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
How fast was the car going that rear ended her?
If it wasn't too fast, and it was a square hit, you don't have too much to worry about. Crawl under and take a look, make sure nothing is cracked or obviously warped/out of place. Other than that not much to do.
Doc Holiday is offline   Reply With Quote
Old 04-18-2008, 01:40 AM   #4
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
Ok, thanks for the replies and I think the person that hit here was going about 5mph.
Old 04-18-2008, 08:16 AM   #5
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
If it was only 5mph and pretty dead on, I think you should be all set!
Old 04-18-2008, 08:27 AM   #6
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
^^ Agreed
If you're not doing anything wrong, you don't have anything to worry about. Corn-Picker Political Playground 7 07-24-2008 12:08 AM
is this sound anything to worry about? Brian204 'Old School' Subaru Forum 5 06-10-2004 05:15 PM
'98 RS heagasket anything to worry about? jamesfacts Normally Aspirated Powertrain 11 02-04-2004 06:28 PM
Getting 91 MR2 - anything to worry about? WRXVII Off-Topic 16 10-05-2003 01:50 AM
Anything to worry about...? XROLLER Brakes, Steering & Suspension 4 05-15-2002 12:04 PM
