Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 01-10-2007, 08:25 PM   #1
Nsantos23
Member#: 71172
95 LegoOutbackfied
Default 93 impreza blower fan, speed 4 only
Hello everyone
i just aquired a 93 impreza... its a good little car its my first impreza i have been a legacy owner for years
the only electrical issue is the blower fan, it works on the 4 speed only, do you guys hav an idea what it may be??
thanks in advance
Neo
Nsantos23 is offline   Reply With Quote
Old 01-10-2007, 09:41 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Sounds like a burned out blower motor resistor, it's a fairly cheap and easily replaced part.
Old 01-10-2007, 09:52 PM   #3
Nsantos23
Member#: 71172
95 LegoOutbackfied
where does the resistor resides? i may be able to get one at the junk yark
Old 01-10-2007, 10:17 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
On the newer cars it's located in the HVAC housing, down by where the fan is. Probably in a similar location on yours, it's placed there so it's in the airflow for cooling as the resistor element generates a lot of heat.
Look for a second electrical plug near where the fan plugs in, if it's attached to a small module that screws into the housing that's it.
Old 01-11-2007, 02:40 AM   #5
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Yeah, those resistor failures can be common, especially with higher mileage cars. All sorts of crap can get into them despite being a surrounded by a protective cage.
-paK +2
Pakin is offline   Reply With Quote
Old 01-11-2007, 10:12 AM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
It's behind the glovebox and is located with the blower motor assembly. It's white and bolted into the black housing and will have a connector harness sticking out of it.
Brian
North Ursalia is offline   Reply With Quote
Old 01-11-2007, 09:51 PM   #7
Todd Breakey
Member#: 123741
1998 OBS
Not trying to hijack this thread, but I have a similar problem. I don't have any fan most of the time. Every once in a while I get all 4 speeds available. I tried replacing the resistor and it didn't fix the problem. Any thoughts?
Neo,
Not sure if your car uses the same part number, but I have a brand new resistor for sale now. My car is a 98. Let me know if you want it.
Todd
Todd Breakey is offline   Reply With Quote
Old 03-02-2007, 09:10 PM   #8
STi_v4_Wagon
Member#: 120368
04 Forester XT
Neo,
Todd
I have the same problem! Have you found the fix? All 4 speeds are intermittent, but mostly the fan doesn't work, from time to time it will run for a few seconds.
STi_v4_Wagon is offline   Reply With Quote
Old 03-02-2007, 09:19 PM   #9
Nsantos23
Member#: 71172
95 LegoOutbackfied
yes i have found the problem its was the resistor, i changed it with one from the junk yard and bingo it worked
Old 03-04-2007, 04:32 PM   #10
68sprintb
Member#: 104893
2005 Impreza WRX
Obsidian Black Pearl
Neo,
Todd
sounds like a bad connection somehwere... look around for corroded connectors
68sprintb is offline   Reply With Quote
Old 03-04-2007, 05:12 PM   #11
STi_v4_Wagon
Member#: 120368
04 Forester XT
I had the same problem and found out it was a bad blower motor relay. It was intermittent on all speeds.
Old 04-17-2008, 03:16 PM   #12
vosdyk
Member#: 177742
Does this apply to Impreza 95'?
vosdyk is offline   Reply With Quote
Old 04-17-2008, 06:21 PM   #13
Nsantos23
Member#: 71172
95 LegoOutbackfied
yes it does
Old 04-17-2008, 08:15 PM   #14
rkramer
Member#: 118209
2015 WRX Limitec
it applies to ANY car that has a multi-speed blower made in the last 30 years. Some cars have multiple combinations of resistor packs, so it is possible to have speeds 2 and 4.
rkramer is offline   Reply With Quote
1986 subaru gl trans on a 93 impreza fwd 5 speed soobxnoob Transmission (AT/MT) & Driveline 3 04-16-2010 02:39 PM
WTB: stock 93-97 impreza radiator fans jicc Private 'Wanted' Classifieds 2 05-27-2009 12:48 PM
Fs: (de) 93 Impreza 5 Speed 4 Door Wrx Upgrades Sti Rear Seat 1700 Obo blueghost Private Vehicle 'For Sale' Classifieds 13 09-05-2008 12:19 AM
Heater blower fan only works on High? dg_performance Service & Maintenance 4 01-29-2008 09:46 PM
93 impreza L top speed? speakerman86 Normally Aspirated Powertrain 43 01-14-2006 07:47 PM
