Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 04-17-2008, 09:55 AM   #1
HamrTym
Member#: 35205
2002 Rubisu
2002 CBR1100XX
Default Front oxygen sensor life expectancy?
What is the general consensus on the life of the front (or lower) O2 sensor. I know it is a major contributor to the long term tuning of the engine via computer.
Will they definately throw a CEL when they are defective? Or do they lose their effectiveness over time gradually?
Got an '02 WRX wagon, with about 97,000 miles on it. About 65,000 of those have been at Cobb's Stage 2 map. Should I go ahead and replace it, or just wait until a CEL comes on as a sign?
Thanks for your time.
P.S. Sorry for any grammatical errors....
HamrTym is offline   Reply With Quote
Old 04-17-2008, 11:34 AM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
These sensors are designed to last a minimum of 100K miles. I wouldn't change a sensor until the ECU diagnoses a problem with it.
Jon [in CT] is offline   Reply With Quote
Old 04-17-2008, 04:05 PM   #3
strohausii
Member#: 26770
'02 WRX
midnight black
^ yah, both of my cars WRX & Highlander had O2 sensor replace codes shortly after 100k miles. Don't worry, they will let you know when they need replacing. Is you gas milage starting to dip? Seemed to me when it got colder, that was when they started failing (increased resistance?).
strohausii is offline   Reply With Quote
Old 04-19-2008, 12:51 AM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I replaced mine at around 80k, but it should last up to 100k miles easily.
Old 04-19-2008, 12:59 AM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
^ same
Old 04-19-2008, 03:58 PM   #6
my scoop eats babies
Member#: 174894
Mine crapped out around 90k, so ~100k sounds about right. It did in fact show signs of failing before the CEL came on, I dropped a few MPG before I got any CEL.
my scoop eats babies is offline   Reply With Quote
Old 04-19-2008, 07:58 PM   #7
Engmus
Member#: 115645
agreed, just because you dont throw a code doesnt mean you might not have an issue. I remember Nissan use to recommend replacing them at 60k, but these aren't nissans obviously.
Engmus is offline   Reply With Quote
Old 04-20-2008, 02:32 AM   #8
sleeperrex
Member#: 19466
2002 wrx/hybrid
My A/F sensor just went a month ago at about 110k.
sleeperrex is offline   Reply With Quote
Old 04-22-2008, 09:30 AM   #9
sinwagon
Member#: 60970
02 WRX wagon
white
Had an mpg drop at about 85k and replaced it at 94k.
sinwagon is offline   Reply With Quote
Old 04-22-2008, 09:47 AM   #10
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
...and did the mpg come all the way back up to where it had been upon replacement?
bulwnkl is offline   Reply With Quote
Old 04-22-2008, 10:07 AM   #11
sinwagon
Member#: 60970
02 WRX wagon
white
No, but I have an issue finding the right O2 sensor. I've ordered 2 so far based on incomplete info on the web site.
Old 04-22-2008, 10:13 AM   #12
jk988
Member#: 60959
'03 WRX
My A/F sensor died at 120k miles. I just want to know why a replacement costs $150. The dealership that does my alignments wanted $200... .
jk988 is offline   Reply With Quote
Old 04-22-2008, 10:42 AM   #13
strohausii
Member#: 26770
'02 WRX
midnight black
Semi-wide band, 4 wire, pre-heated, and controls your Air/ Fuel (Sensor 1, Bank 1). Probably $50 bucks just to touch your car....
Old 05-15-2008, 01:20 PM   #14
d1a9j
Member#: 173810
2002 WRX Stg2
Platinum Silver Metalic
my front o2 sensor just **** itself at 80k-ish.... no cel from it, just crappy gas mileage !!!!
yay, $200 dealer only part
d1a9j is offline   Reply With Quote
Old 05-15-2008, 03:59 PM   #15
Jon [in CT]
Member#: 2992
02 WRX Sedan
If there isn't a sensor-related trouble code stored then it's very unlikely your crappy fuel economy is related to the operation of the front AFR sensor. And any auto parts store can sell you an exact replacement for your front AFR sensor, if it ever does malfunction.
Old 05-15-2008, 04:46 PM   #16
d1a9j
Member#: 173810
2002 WRX Stg2
i went for a stage 2 street tune and the car was running super lean under boost (on stock tune) ... my guess is front o2 sensor is on its way out. also i cleaned my maf, so i dunno what else it would be
Old 05-15-2008, 05:36 PM   #17
Jon [in CT]
Member#: 2992
02 WRX Sedan
You damaged the MAF sensor trying to clean it. You introduced an exhaust leak downstream from the front AFR sensor while installing a stage 2 exhaust. You have an intercooler leak. The aftermarket wideband was mounted poorly in the muffler.
Any of these might be a reason you ran "super lean under boost."
Old 05-15-2008, 06:38 PM   #18
d1a9j
Member#: 173810
2002 WRX Stg2
maf wasnt damaged, i had the problem before i cleaned it. no exhaust leak. not sure about the ic, but i doubt it. no wideband yet !
im honestly guessing its the o2 sensor
Old 05-15-2008, 07:27 PM   #19
Jon [in CT]
Member#: 2992
02 WRX Sedan
no wideband yet !
So, exactly how did you determine your engine was "running super lean under boost" without a wideband AFR meter?
Old 05-15-2008, 08:45 PM   #20
d1a9j
Member#: 173810
2002 WRX Stg2
i dont have a wideband, but my tuner does... he hooked it up (innovate lc-1) and used his puter to get real time readings
Old 05-15-2008, 09:02 PM   #21
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
since 2000ish Subaru started usng a front Air/Fuel Ratio sensor before the cat. After the cats is where you will find Oxygen sensors.
Old 05-15-2008, 09:12 PM   #22
d1a9j
Member#: 173810
2002 WRX Stg2
u know what i meant !!!
Old 05-16-2008, 09:11 AM   #23
Ray@revitup
Member#: 82064
2011 sti & evo ix
white
john im convinced its the 02 sensor on this car. this is the 2d one i had doing this. i pulled the af and cleaned it and it didnt make a change. the car has no boost or exhaust leaks wither. and its running afrs of 15 and 14 at wot on the stock map.i also suggested replacing the fuel filter
Ray@revitup is offline   Reply With Quote
Old 05-16-2008, 10:48 AM   #24
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally Posted by Ray@revitup View Post
john im convinced its the 02 sensor on this car. ... and its running afrs of 15 and 14 at wot on the stock map.
The WRX's front A/F sensor is ignored during WOT. What was LTFT during these WOT runs? If the front A/F sensor is at fault for the lean WOT condition, then you should see a large negative value (e.g. -20%). The owner reports crappy fuel economy. If the front A/F sensor is at fault, then logging LTFT during idle and cruising should produce large positive values (e.g. +20%) and AFR logged by a wideband should be much less than 14.7 (e.g. 13.5).
I'm not a big fan of the shotgun approach to problem diagnosis (i.e. replacing every part in sight which MIGHT somehow be related to a problem).
Old 05-16-2008, 10:59 AM   #25
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
hey guys, if the front 02 sensors is bad would you have any funny idle issues??
gingertooth is offline   Reply With Quote
Front Oxygen sensor AKA air/fuel sensor swap out Peaty Tribeca Forum 0 02-20-2010 04:36 PM
2007 STI Front Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 0 02-13-2009 02:16 PM
Pressure sensor life expectancy? sportwagon Interior & Exterior Modification 1 03-05-2008 10:01 PM
FS: Front oxygen sensor 04 WRX 02 sensor Chino Bling Engine/Power/Exhaust 4 11-20-2007 11:56 PM
Recall: MY00 GT, Outback w/5MT: ECU, (perhaps) front oxygen sensor miksmi Legacy Forum 0 10-09-2000 08:05 AM
