Notices
Old 04-17-2008, 05:40 PM   #1
MS WRX
Member#: 117780
2004 WRX
Default STi heads on non avcs ecu??
The set-up i will be running will be an ej255 shotblock with 2007 sti heads with portwork and yet to be decided cam specs.
Which cams can i use if i do NOT want to get an AVCS ECU? Do i get 257 spec cams or 205 spec?
Im really confused here
Some help would be great!!
MS WRX is offline   Reply With Quote
Old 04-18-2008, 08:14 AM   #2
sjl1614
Member#: 56791
06 OBS
You can use just about any stock or aftermarket non-avcs cams. Of course the avcs would be non functioning with any cams, avcs or not.
sjl1614 is offline   Reply With Quote
Old 06-12-2008, 06:40 PM   #3
MS WRX
Member#: 117780
2004 WRX
So would Spec C cams work if i pinned the AVCS holes in the intake cams?
Old 06-12-2008, 08:11 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
yes, they should work
sti cams and non-avcs wrx heads... jason miller Built Motor Discussion 8 09-25-2009 06:14 PM
AVCS Heads on Non-AVCS blocks. readymix Built Motor Discussion 43 03-27-2009 10:30 PM
FS/AZ: 04 STI Heads + 272/278 AVCS Cams hrmax Engine/Power/Exhaust 10 08-08-2008 10:07 PM
AVCS heads ---> non-AVCS use??? Peeblesmx445 Built Motor Discussion 14 03-19-2006 10:06 PM
JDM V7 STi heads vs. non-STi heads sheikthin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-02-2005 10:51 PM
