Old 04-17-2008, 09:18 PM   #1
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Default JE 2618 Pistons Ring gap & valve notches...
I just checked the top and second ring gap on my S3L build and look what i found:
Top ring: 0.010"
Second ring: 0.018"
Itīs that ok, or i should need to open the gap on both rigns? Whats the recomended ring gap for a built motor and 35R turbo
The pistons are JE crawford customs to be used with + 2mm long Rods.
What about these pistons without valve notches & DPR stage 2 cams , Itīs that oK?.... or the valves will hit my pistons?
Thanks in advance for your suggestions...
xbcaraudio is online now   Reply With Quote
Old 04-17-2008, 09:30 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I think JE recommends 0.0055 per inch diameter of cylinder, so that top ring end gap is a little small.
If you are worried about valves hitting it's easy to measure. clay the top of the pistons, bolt on the heads with a used gasket of the desired thickness, tdc the piston and rotate the cam by hand.
mick_the_ginge is offline   Reply With Quote
Old 04-17-2008, 10:11 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
http://www.cppistons.com/catalogs/mi...ochRing3hr.pdf
These are the same as JE reccommended for my JE pistons.
Old 04-17-2008, 11:21 PM   #4
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Thanks... that,s what Iīm going to do... pre assembly the engine and measure the clearance with a used gasket...
Old 04-17-2008, 11:23 PM   #5
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Thank you... I will follow the recomendations of CP and JE on the gap settings
Piston ring end gap advice afmardve Built Motor Discussion 22 10-15-2010 10:40 PM
piston rings...end gap? Mawheaton Normally Aspirated Powertrain 1 02-17-2009 01:43 AM
ej20 arias .020 over pistons ring gap Scooby Rex Built Motor Discussion 5 07-31-2006 12:24 AM
ej20 arias .020 over pistons ring gap Scooby Rex Built Motor Discussion 1 07-26-2006 10:33 AM
EJ20 JE Forged pistons w/rings Yeah baby Private 'For Sale' Classifieds 4 01-28-2005 02:27 PM
