Old 04-17-2008, 08:51 PM   #1
guy_in_red_wrx
Member#: 169355
Default Car idles at 1k-1500 rpm.
Hey guys.
I left for work this morning for work. when i got home from runing some errands i notice that my car idles at 1k , when slight push the gas peddle the gauge went up and drop to 1500 , when let go of the peddle for 2-7 sec the guage went back down to 1k.
Usually idles at 500.
There are no mods as far as a simple cai, just plain stock , but only a catback exhaust that seems to vibrate against the heat sheilds.
anyone have any ideas where to check?.
guy_in_red_wrx is offline   Reply With Quote
Old 04-17-2008, 09:32 PM   #2
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
What year, how many miles on your car? Have you ever cleaned the IACV since you owned the car. If you never cleaned it, and you have a good amount of miles on the car, it wouldn't be a bad idea to clean it, it might actually help. I never experienced any idle issues, but since I have 133k miles on my car, I cleaned it anyway. Btw, your car idles at ~750 rpms.
Link for cleaning the IACV
http://forums.nasioc.com/forums/showthread.php?t=781242
rexman2002 is offline   Reply With Quote
Old 04-17-2008, 10:24 PM   #3
mostasz
Member#: 170512
2012 WRX
Ice Silver
mostasz is offline   Reply With Quote
Old 04-20-2008, 07:42 PM   #4
guy_in_red_wrx
Member#: 169355
the car is bout 75k
Old 04-20-2008, 07:46 PM   #5
guy_in_red_wrx
Member#: 169355
i have not cleaned my iacv sinced i own this car, still is not normal to idle that high.
Today the idle climbed up to 2k rpm.
now im really concerned.
Old 04-20-2008, 08:31 PM   #6
bdpAKAknox
Member#: 121248
Have the stock airbox to put back on?
just to rule out the cai.
bdpAKAknox is offline   Reply With Quote
Old 04-21-2008, 12:53 AM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Well clean the damn thing. Clean it and report back as until then, you will just get 900 posts of clean your IACV.
Old 04-21-2008, 06:32 AM   #8
fastwrx25
Member#: 126441
03 bugeye
CLEAN the IACV
this happened to me and its easy to fix.
fastwrx25 is offline   Reply With Quote
Old 04-21-2008, 12:59 PM   #9
timmah
Member#: 54203
2011 WRX
also clean the MAF, i had this issue and cleaning the MAf resolved it
timmah is offline   Reply With Quote
HELP! Car idles at rough and @ 500rpm TRSaitz_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-25-2008 09:06 PM
What RPM did your last car idle at? ZeppelinPie792 Normally Aspirated Powertrain 15 12-07-2007 12:58 PM
HELP!! Just changed plugs and car surges at high boost/RPMs??? Clzay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-09-2007 05:50 PM
Car is rough at around 1500 rpm AzNStiImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-13-2005 12:41 AM
What RPM does your car idle at? sbsnyder Normally Aspirated Powertrain 13 05-29-2001 12:50 AM
