Welcome to the North American Subaru Impreza Owners Club Wednesday February 10, 2016
Old 09-27-2011, 01:27 AM   #1
thomas18a
Member#: 284880
2004 WRX Wagon
Default Losing Cam Pulley
Hi everyone,
I got a 2004 wrx wagon. It has 87k now. Recently, I have a horrible oil leakage from the cam seal. Thus, I decided to replace the belt, pump, cam seal, crankshaft seal...together
The problem is I cant figure out a way to lose the cam off.
Is there any special tool which i need?
thanks
Thomas
thomas18a is offline   Reply With Quote
Old 09-27-2011, 05:55 AM   #2
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
the cam sprockets are one of those things that people break often even if they are using the right tools. they suck to say the least. there are special tools. http://www.amsperformance.com/cart/a...cket-tool.html here is a link to the PROPER tools, but with a big breaker bar (and maybe a cheater bar on the end of that) and some muscle, usually you can get them. try not to break the cam gears if at all possible. i usually will dremel the bolt heads off if they won't come loose because the bolts are MUCH cheaper than the sprocket is.
amalgrover is offline   Reply With Quote
Old 09-27-2011, 02:09 PM   #3
thomas18a
Member#: 284880
2004 WRX Wagon
Thanks for the information. Is there any lower budget tool? 174 for a tool is a little bit out of my budget..thanks
Old 09-27-2011, 02:22 PM   #4
Cool Hwip
Member#: 295976
2011 STI Sedan
It's a $700 job if you bring it to the dealership so it's hard to complain about $174.
Cool Hwip is offline   Reply With Quote
Old 09-27-2011, 07:26 PM   #5
amalgrover
Member#: 183480
2009 Forester XT
if you are looking for the cheap route, just cut the bolt head off if you can't get them loose...the bolts are less than $10ea
Old 09-27-2011, 08:08 PM   #6
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
You use the old timing belt, two Vise-Grips, and someone that's strong enough to hold the belt when it's clamped up and wrapped around the alternator or A/C pulley to hold the cam-gear pulleys in place while you loosen the bolts.
Did it both times, off and on for a friend's car. No broken bolts. No broken cam gears. Approximately 140,000 miles on the engine.
Old 09-28-2011, 10:45 AM   #7
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
This is how i will do it in the future, and How I recommend it be done. It's how I have always done it on my older cars. However, when I did the suby, I had a friend at a dealer loan me the dealer tool. I chipped the cam gear, even though I was using the proper tool. I was pissed.
If you do it like this, DO NOT RE-USE THE TIMING BELT!!!
Bacon117 is offline   Reply With Quote
Old 09-28-2011, 11:05 AM   #8
amalgrover
Member#: 183480
2009 Forester XT
a few times on higher mileage BIG horsepower cars this has not worked for me, the proper tools didn't work for me, and the breaker bar and cheater bar wouldn't work for me. in those cases the only solution is to cut the bolts off. obviously, this is a route i try to avoid on customer's cars, but sometimes it is the only option when 500+CHP has been pulling those bolts tighter and tighter for 75,000+ miles.
Old 09-29-2011, 01:15 AM   #9
thomas18a
Member#: 284880
2004 WRX Wagon
I finally got 3 of the bolts off with an old timing belt. how can i cut the bolt head off, the bolt head is in the pulley..is it?
Old 09-29-2011, 08:38 AM   #10
amalgrover
Member#: 183480
2009 Forester XT
you can do it 1 of 3 ways pretty much...
1. use a dremel and a cutting wheel. start by making a line right across the bolt head (a gash so to speak), then make another line that makes a cross with that one (make a cross), then make another line that intersects those two, and then keep doing this until you have cut down to the pulley itself (don't cut the pulley though) and the bolt head will fall right off. (this way took me about 10-15mins)
2. use a drill bit slightly larger than the shaft of the bolt and start drilling into the bolt head. eventually the bolt head will fall off the shaft. (this way took me MUCH longer than the others...like 30mins)
3. this way isn't actually cutting the bolt head off, but more just giving yourself leverage. basically cut a gash in the bolt head just like in the first way that i told you, but make it so you have a flat spot to rest a punch on top of. then you would hold the pulley with the old timing belt as you did before, and using a hammer and a punch try and back the bolt out. i have found that this in combination with the first way works the fastest. sometimes you can get the bolt head cut about halfway off and it will start to turn loose using this last method.
...let me know if any of this didn't make sense and i will try to explain it better.
WTB: Cam Pulley for left side exhaust cam torkeh Private 'Wanted' Classifieds 5 11-09-2009 12:18 PM
Does a cam regrind require modified cam pulleys? SubSyncro Normally Aspirated Powertrain 2 12-12-2004 11:59 AM
WTB WRX cam pulley and cam cover socalrsdriver Private 'Wanted' Classifieds 1 07-30-2004 09:10 AM
Cam Pulley Removal moswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-12-2003 04:12 PM
Does NE1 make a adjustable Cam pulley for WRX? Hashiriya Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-12-2001 11:53 AM
