Old 04-18-2008, 12:14 AM   #1
KenSekiguchi
Member#: 175331
2002 WRX STi - WRB
JDM V7 EJ207/13' Felt Z85
Unhappy 2002 WRX Fuse & Relay Box
I have a slight problem.....Last night I was installing my BLITZ FATT DC IV and I came to the part where you have to cut and tape up the Dark Green with Black Stripe wire on the Keyless Entry Module.....Well, not paying much attention, I looked above the fuse panel and saw two harnesses, so I figured this must be it.....WRONG!!!!! I unplugged the harness, found the Dark Green with Black Stripe wire and cut it.....Then I noticed the small black box above.....which was the Keyless Entry Module.
Here's a pic of the Fuse & Relay Block to help with identification.
(the harness I am talking about is the one in the upper left hand corner)
http://img165.imageshack.us/img165/7...seblockpz1.jpg
Now my question is this, what is the purpose of that Dark Green with Black Stripe wire that I cut??? What does it control/relay??? I'm not too familiar with the electric system and cannot properly identify it on a schematic. I quick fixed it by using a quick splice wire tap. But I need to know if I can just solder it back together with another piece wire (the same gauge of course) or if I have to replace the whole harness. PLEASE HELP!!!!!
KenSekiguchi is offline   Reply With Quote
Old 04-18-2008, 01:04 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Splicing in an extra piece of wire and soldering it well and then covering the bare wires with good electrical tape will work fine. It's just DC voltage you are dealing with.
Old 04-18-2008, 10:39 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
wiring manual suggests it might go to fuse #18 (should be two green/blk wires) - goes to the AC relay, the sub fan relays, and the thermal protector. Hard to say much else (the pic you posted is really, really, really small...)
Old 04-18-2008, 12:00 PM   #4
KenSekiguchi
Member#: 175331
2002 WRX STi - WRB
Later on today, I'll post a few pics of the Fuse & Relay Box. Thanks a lot.
FS in central IL - 2002 Wrx Ecu & STi exhaust mani, DP & uppipe SilverSurfer04STi MWSOC Private Classifieds 17 12-05-2008 06:19 PM
FS in IL - 2002 WRX ECU & STi exhaust mani, DP & uppipe SilverSurfer04STi Engine/Power/Exhaust 25 12-05-2008 06:18 PM
STi Gauge Cluster into a 2002 WRX, fuse problem MTR_Suby02 Newbies & FAQs 2 03-24-2007 09:32 PM
Fuse and Relay Box catch20who Service & Maintenance 0 02-03-2007 12:31 PM
Any interest in a 2002 WRX / RS only subwoofer box? BrysImpreza Car Audio, Video & Security 26 03-22-2002 02:06 PM
