Old 04-18-2008, 09:50 AM   #1
sujorosa
Member#: 146739
1999 Camaro z28
Red
Question Misfire around 3000RPM???
Hey everyone,
I have run into some trouble recently and can't figure out the root cause as of yet. Here is the rundown of what is happening:
When i am driving normally, in any gear around 3000 RPM my car is stumbling. In some cases so much that I get a misfire CEL in cylinders 1 and 3. The stumbling only lasts between 2900RPM to about 3200RPM. Partial throttle I feel it big time, and in WOT I still get the stumble as well I recently noticed - but it's no where near as noticable. The car feels solid otherwise. Even cruising on the highway at about 70-75mph when my car is around 3000RPM you can hear it stumble - temporarily throwing a CEL without the cruise flashing.
My current mod list is:
Buschur Racing 3inch Turbo Back Exhaust
Custom 4-1 header and uppipe
Agency Power 3inch Turbo inlet
Perrin Big MAF
Blouch Dominator 3.0R (GT3076)
SSAutoChrome FMIC
Power Enterprises 850cc Injectors
Agency Power Fuel Rail
Agency Power TGV Spacers
Grimmspeed TGV Deletes w/ Heat Coating
Walbro 255 Fuel Pump
Forge BPV
Summit Racing Heat Wrap
GM Boost Solenoid
NGK Iridium 1 Step Colder Spark Plugs
I just ordered new 1 step colder plugs thinking maybe the gaps were off, or since at one point I found my car to be running extremely rich that it could have fouled something. I am putting those in this afternoon. I was told it may be failing coilpacks as well. Any help would be greatly appreciated.
Thanks,
Matt
sujorosa is offline   Reply With Quote
Old 04-18-2008, 03:24 PM   #2
sujorosa
Member#: 146739
1999 Camaro z28
Red
bump, any ideas ppl? all help would be greatly appreciated!
Old 04-19-2008, 10:05 PM   #3
awdguy
Member#: 59101
2004 wrx
white
maybe your coil packs. spray a little water on the coil packs and see if it acts up. or just swap the coils that are misfiring with ones that are not, see if the misfire jumps. if it does, then you need new coil packs.
awdguy is offline   Reply With Quote
Old 04-20-2008, 05:27 PM   #4
sujorosa
Member#: 146739
1999 Camaro z28
Red
spray water on the coil packs? any more info on this? never heard of doin that b4 thx
Old 04-20-2008, 05:41 PM   #5
stiplayer
Member#: 173727
2004 Sti Stage II
hmm thats pretty weird i see that **** on fords all the time hahahaha but never ona sub
stiplayer is offline   Reply With Quote
Old 04-20-2008, 06:04 PM   #6
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Coilpack probably....how does the big maf work for you? I had one for a while but never could get it to fit that great with my front mount and the silicone coupler leaves much to be desired..Also if in your ecu map there is a rich point or two that could cause a very slight hestitation or bog feeling. Let us know when you get it fixed..
stretchedk7 is offline   Reply With Quote
Old 04-21-2008, 10:31 AM   #7
sujorosa
Member#: 146739
1999 Camaro z28
Red
i replaced the coil pack on cylinder 3 and moved the others to see if anything would change its location, it didn't change anything. it still shows Cylinder 3 misfire. new spark plugs are in as well. is it possible a injector could be doing that?
the perrin big maf fit just great. i didnt get a coupler with it, i had 1 laying around that i used and it fit great
Old 04-23-2008, 01:42 PM   #8
sujorosa
Member#: 146739
1999 Camaro z28
Red
bump.....
Old 04-24-2008, 06:02 PM   #9
sujorosa
Member#: 146739
1999 Camaro z28
Red
crank case might b the issue? i think the pvc line is blocked.
Old 04-24-2008, 08:45 PM   #10
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
you will see spark jumping. i used to do that on distruributor type to check them wires!
if you see jumping on the wire, it will be the wire or go to shop and they are going to check with scanner to see misfire data and misfire counts! on 3k rpm!
EJ20_lee is offline   Reply With Quote
Old 04-25-2008, 02:36 AM   #11
silversubie02WRX
Member#: 178269
DOMtuned
My guess would be you have bad coil packs or they are cracked. Not sure if its the same, but in my maxima the same thing would happen.
-Alex
silversubie02WRX is offline   Reply With Quote
Old 08-07-2008, 06:29 PM   #12
sujorosa
Member#: 146739
1999 Camaro z28
Red
Fuel pressure issue it turns out.
Old 08-08-2008, 02:01 PM   #13
ptirmal
Member#: 82243
07' Acura TL-S
What about fuel pressure? Did you get it fixed?
ptirmal is offline   Reply With Quote
Old 08-12-2008, 05:53 PM   #14
Teraldinho
Member#: 120707
2002 Impreza WRX
Please follow up. Did you replace the fuel pump?
Teraldinho is offline   Reply With Quote
Old 09-29-2008, 06:57 PM   #15
sujorosa
Member#: 146739
1999 Camaro z28
Red
Hey sorry I forgot about this post! I didn't get it fixed. My friend bought the car and hes getting some parts together to swap to see if it fixes it. Sounds like the fuel rail or the regulator so far. I'll def post once we figure it out!
Old 11-01-2008, 08:35 PM   #16
STIBungy
Member#: 51684
I fixed a customer's car that had misfire issues. The problem was the AP fuel rails.
STIBungy is offline   Reply With Quote
Old 11-02-2008, 12:37 PM   #17
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
what did you do to fix it? Reinstall stock rails or go to another aftermarket? My friend just rebuilt his rebuilt motor (cracked cylinder) but this problem is still there. He has the AP fuel rails.
thanks
Any update from the OP?
byroll01 is offline   Reply With Quote
Old 11-02-2008, 02:28 PM   #18
STIBungy
Member#: 51684
Removed the rails and went back to stock. A shady local shop sold him a bunch of things he didnt need and did a poor job installing them. At first, I thought it may be due to the leaky fittings but after sealing everything up, the misfire was still there. I also did the obvious troubleshooting as well: new plugs, switched coil packs around, etc.
thanks
Old 11-03-2008, 05:46 PM   #19
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Do you have an open source cable? If so could you data log a short run where the problem exists?
Old 12-09-2008, 11:52 AM   #20
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
We FINALLY decided to give the fuel rails a shot and I guess that was it. The stutter/misfire was gone as soon as we pulled out of my street. He hasn't thrown a CEL in over a week since the install.
Thanks for the info STIBungy!!!
04STI swap w/ misfire around 4k please read log bstoehr83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 10-22-2009 10:55 AM
04STI swap Misfire around 4K rpm, what can i log to rule out fuel components? bstoehr83 Open Source Reflashes 5 10-20-2009 10:52 PM
Jerk around 3000rpms sti_my05 Other Engine Management 5 10-03-2006 09:16 AM
misfires,misfires,misfires eatsrice Engine Management & Tuning 6 08-04-2004 09:47 AM
First post: Outback with hesitation/misfire around 30mph rba007 Service & Maintenance 3 02-29-2004 03:36 PM
