Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 04-18-2008, 12:09 PM   #1
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
Question Bar's Leaks
in relation to this thread:
i may have coolant getting into my combustion chamber. I searched about solutions when i came upon this product called Bar's Leaks
has anyone used this stuff before? does it work? is it safe to use on my ej205?
lawn boy is offline   Reply With Quote
Old 04-18-2008, 01:19 PM   #2
Member#: 81995
2008 Impreza
02 WRX 247k RIP
before you do anything i would make sure it's a head gasket for sure. did you do a compression test? leak down test? drain the oil, does it look like chocolate milk? smell the exhaust, is it sweet like coolant?
if so, is it both headgaskets or just one side?
you can try that stuff but i'm pretty sure it's not gonna fix a leaking headgasket. can't hurt though i guess if it's already leaking so if it doesn't work then you know what has to be done.
bugeye829 is offline   Reply With Quote
Old 04-18-2008, 05:59 PM   #3
Member#: 141672
Use this instead. http://www.crcindustries.com/hd/cont...401016%2D6&S=N
I used this a few times when as an auto tech at a Honda dealership (diesel truck mech for UPS now). It worked the few times I was around it but you must follow the directions to the letter.
mikeythejew is offline   Reply With Quote
What do sway bar's do for you? Malasubidude Newbies & FAQs 16 08-07-2008 10:51 PM
FS: Full 04 sti susp, sway bar's, endlink's(OEM) KB'izzle Suspension/Brakes/Handling 1 06-30-2008 10:26 PM
Bar's alone. GUTz 03 Off-Topic 9 05-10-2006 03:49 AM
How long after an 'energy bar' is eaten, does the 'energy' kick in ZMANNH25rs Off-Topic 15 04-21-2006 04:33 PM
Gil de Ferran named BAR's Sporting Director Ferg Motorsports 10 04-06-2005 09:41 PM
