Old 04-18-2008, 01:48 PM   #1
vosdyk
Member#: 177742
Exclamation Replaced relay, air blower won't blow still!
My 95' Impreza blower acting weired recently, it works intermittently. Anyway, after went through the threads here, high probable because this happens because of bad relay. So I changed with a new relay this morning. Air blower still won't blow.
Couple week of ago, when blower not working, I took out the blower and test with voltmeter, the connection seemed fine. When I put the blower back, it blowed and stop the next day.
Do I need to wait some time to get the relay to charge in order to work normally or something else is causing this problem? Please advise.
Chih How
vosdyk is offline   Reply With Quote
Old 04-19-2008, 12:29 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
also check fuse box..
The couch won't stay still when doin it Audiosavvy Off-Topic 35 02-19-2009 01:53 AM
replaced oil pump, now won't start sureshot007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-06-2008 03:35 PM
Air blower died grizz3000 Service & Maintenance 2 11-11-2006 11:30 PM
air intake and blow off valve 04subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-24-2003 09:11 PM
Just Replace Battery and lights won't tstop blinking archer Normally Aspirated Powertrain 4 08-05-2002 12:59 PM
