Old 04-18-2008, 02:44 PM   #1
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
Default A/C doesn't work
Okay so I bought my 99 legacy during winter and couldn't really tell if my a/c worked. And now that's it's 80 degrees out I know it doesn't.
I've never worked on an a/c system before. I want to recharge/service it. Would those kits at Autozone do the trick or is there a better way. Also is there any other way to see if there's anything wrong with it? I know when I had my STi that if you turn the a/c on the car shudders a bit and feels like you lost 20 hp, but with my legacy there's not such shudder.
Any help would be appreciated.
Thanks
fasterthanrayswrx is offline   Reply With Quote
Old 04-18-2008, 02:55 PM   #2
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
So when you turn the A/C on the compressor doesn't engage? You can tell not only by the rpm/power drop but also looking under the hood.
You can just recharge it but you should probably do a full diagnosis to see why the system lost its pressure to begin with.
jey is offline   Reply With Quote
Old 04-18-2008, 04:25 PM   #3
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
What's the fix it the compressor doesn't engage/HVAC button doesn't light up? The HVAC panel is working, the buttons just don't light up anymore.
Huffer is offline   Reply With Quote
Old 04-18-2008, 09:20 PM   #4
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
So i went to check my fuses. I pulled some A/C relays and put them back in. I'm not sure if that did anything but it seems like the compressor does engage now as the rpms rise when the a/c is turned on. But still no cool air. I'll try a recharge if that does anything.
Old 04-18-2008, 11:05 PM   #5
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Subaru's have a fail safe built in (low pressure switch) and 90% of the time if the compressor isn't coming on it's because you're too low (or completely out of) refrigerant. They build this fail safe in because refrigerant (along with oil) also acts as lubricant for the compressor, and without it the compressor would burn up, sending aluminum shards through the entire ac system, which would require flushing/replacing many parts.
In my experience at the dealer, the schrader valves (where the refrigerant is usually charged) can sometimes have a slow leak, and over a few years time you lose enough pressure to cause the low pressure switch to trigger and disable the compressor from being turned on.
Other things to look at would be the AC switch itself, the wiring on the compressor, the condition of the lines. The best way to diagnose it is have a professional look at it. If you were to bring it into my shop I would first check the refrigerant level, and if it checked out and would then look at the fuses, and then check to see if the compressor was receiving a signal from the switch in the car. If all this checked out I would then start looking more closely at the compressor itself. This is if the compressor was clearly not kicking on. If the compressor is kicking on and the air isn't cold, then that's a whole new set of components to trouble shoot.
rexorama is offline   Reply With Quote
Old 04-18-2008, 11:08 PM   #6
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Huh?
Old 04-19-2008, 12:59 AM   #7
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
ok great. That's the exact response I was looking for.
Thanks.
Old 04-19-2008, 11:43 AM   #8
suby2low
Member#: 82633
'08 WRX STI
if the compressor is kicking on and shutting of very rapidly, the refrigerant is definitely low. just recharging it with the kit at autozone isnt a great idea by any means. the pressure gauge that comes with them doesnt mean the system is full. you have no idea how much refrigerant you are actually putting in, or how much oil you are adding to the system. plus, if it is low, there is a leak in the system. which means you will just be dumping r134 back into the atmosphere. NOT GOOD. a/c systems are one thing you should have professionally worked on. please take this advice seriously. i am a master hybrid toyota technician. i am not bulls**ting you. the high pressure side of a/c systems can run over 350 psi if not worked on correctly. we are talking about serious pressure that can do a lot of damage.
suby2low is offline   Reply With Quote
Old 07-26-2008, 10:32 AM   #9
aldebaraan
Member#: 185421
2008 Impreza 5-door
Dark Gray
I've got a similar problem on my '93 Impreza. The compressor is kicking on, but it stays on. It actually diminishes power to the engine, just as if it were actually working. However, the pressures never get far enough apart to get the cooling I need. It's like the compressor is working, but not compressing...weird! Is this a condenser problem?
aldebaraan is offline   Reply With Quote
Old 07-28-2008, 03:06 PM   #10
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
First thing I'd check is the freon level/pressure in your system.
Old 07-28-2008, 03:31 PM   #11
Huffer
Member#: 36735
99 GF8 Impreza 2.0
So how would you test the refrigerant level? Would you use a pressure gauge on the Low port?
Old 07-28-2008, 04:39 PM   #12
aldebaraan
Member#: 185421
2008 Impreza 5-door
Dark Gray
I've had the pressure and freon level in the system checked, and it's fine. The problem is that it's not pressurizing the high side as it should. I've replaced the valve and checked out the core, but it still isn't working. My next guess is to go for the condenser...but I'm flying blind here. Any other ideas?
Old 07-29-2008, 11:00 PM   #13
greenleg88
Member#: 185716
2000 OBS
Green
what is the psi that hte low pressure valve should be reading? i have a 97 legacy L Sedan and im trying to do a charge. cept the gauge is saying its in the danger zone. i JUST read that people were saying to ignore the colors.. and just look at hte numbers.. and that youre supposed to take the temperature... and add 23 and thats the psi to fill to... im really not sure..
any ideas?
greenleg88 is offline   Reply With Quote
Old 08-23-2008, 10:16 AM   #14
aldebaraan
Member#: 185421
2008 Impreza 5-door
Dark Gray
Default A/C clutch engaging, but no cold air
So if the clutch is engaging and I have a new expansion valve, the correct amount of freon and no leaks, I'm guessing now that it may be a bad compressor.
Is there a way to "test" a compressor? Or am I missing something else obvious?
Old 10-27-2008, 09:14 AM   #15
aldebaraan
Member#: 185421
2008 Impreza 5-door
Dark Gray
Well, I finally decided that everything looked good but the compressor. So I bought a pulled working unit online, and did the install myself. It was rather easy, and after getting a new o-ring for the high side, it works beautifully. In 85 degree weather, I'm getting 55 degrees out! Whohoo!
Old 11-28-2013, 05:47 PM   #16
oujerzy
Member#: 374822
2001 Impreza 2.5 RS
Good to know about the safety function. I had a leaky schraeder valve but didn't realize it may have been faster than I thought. HVAC light doesn't come on now so it looks like I'll have to actually get around to changing the valve and then recharge.
oujerzy is offline   Reply With Quote
Heat Fan works then doesn't work (50%-50%) 98 Impreza OB Jutboy Electrical & Lighting 0 12-07-2007 01:11 AM
('93-'01) cabin fan works then doesn't work walt mazar Impreza Forum 1 08-13-2003 10:20 AM
('93-'01) A/C doesn't work in my 2002 RS ToJo Impreza Forum 1 05-23-2001 08:48 AM
Any idea why the links page doesn't work..?? Aaron'z 2.5RS General Forum Archive 1 02-14-2001 03:11 AM
