Old 04-18-2008, 03:51 PM   #1
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
Unhappy P0303 code, misfire rough idle
Hi all, First things first I have
05 STi
Cobb Turboback exhaust
AEM shortram intake
Cobb accessport Stage 2
GFB Blowoff valve
A few months ago I drove my Sti through a huge puddle like 3 feet deep. Got the intake all wet. Car was starved of 02 and stalled. I got an MAF Flow high and all kinds of missfires. Dryed out the car it runs fine, now I am getting a p0303 code and really rough idle.
What should I DO.
Replace the sparkplugs
or the coil packs
or the wires
or the MAF
Or all of the above?
Thanks
Charles.
afcivileng is offline   Reply With Quote
Old 04-18-2008, 08:36 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
all of the above
Old 07-02-2008, 07:10 PM   #3
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
Ok I replaced the spark plugs, It fixed the problem for a little bit, but now the P0303 code keeps comming up. I switched out the coil packs, and still getting p0303, WTF.
What could be causing the misfire, if its not the plugs, not the coil packs, Then what is it?
Please Help
Thanks
Old 07-02-2008, 08:00 PM   #4
Arctic Penguin
Member#: 119532
2006 WRX
if your engine tried to hydrolock but didnt, quite
id look for vac leaks in the intake up to the turbo
do a compression check
Arctic Penguin is offline   Reply With Quote
Old 07-02-2008, 09:15 PM   #5
Clark Turner
Member#: 178047
02 WRX STI Spec C
Start off by a doing a compression check. The water might have knocked out a ring land on one of your pistons.
Clark
Clark Turner is offline   Reply With Quote
Old 07-04-2008, 07:25 PM   #6
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
I also have a strong unburned fuel smell coming from my exhaust, What does thant mean?
Old 07-04-2008, 07:38 PM   #7
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
check the wires at 3rd cyl coil pack. Wiggle them and see what happens.
Old 07-04-2008, 11:47 PM   #8
serdet
Member#: 134543
2005 Subaru WRX STI
you need to do what clark said above. too much water in an engine at one time is no good. I would bet the compression on #3 cylinder is low. good luck
serdet is offline   Reply With Quote
Old 07-06-2008, 01:22 PM   #9
psychoskip
Member#: 78408
any news?
psychoskip is online now   Reply With Quote
Old 07-08-2008, 01:07 PM   #10
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
Did the compression test here are the numbers:
cylinder 1: 135
cylinder 2: 135
cylinder 3: 141 ( the one with the misfire, Go figure highest compression)
cylinder 4: 138
So if its not a jacked up ring, could it be the injectors?
Old 07-08-2008, 01:10 PM   #11
psychoskip
Member#: 78408
cylinder 1: 135
cylinder 2: 135
cylinder 4: 138
How is your car running?
Old 07-08-2008, 02:26 PM   #12
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
It still idles rough, but I changed the base map on the ECU, went to stock mode, I think it helped, I didn't get the cel code when I came back from the shop. I'll keep driving it see if the code comes back.
I think I'll swap out the injectors for some 850 cc ones for good measure
Old 07-08-2008, 02:28 PM   #13
P&L Motorsports Inc.
Member#: 67199
07 [email protected] STI
97 RS [email protected]
Maybe I missed it... but did you try swapping 1 and 3's coils around, seeing if the problem migrates?
-J
P&L Motorsports Inc. is offline   Reply With Quote
Old 07-08-2008, 02:52 PM   #14
AVANTI R5
Member#: 73805
2017 911 Turbo
Miami Blue/ pdk
might be in the valves(if your smelling fuel out the exhaust)
Old 07-08-2008, 03:18 PM   #15
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
If he is actually misfiring in cylinder 3 that fuel isn't combusting and is going right out the tail pipe. Since he said the car is idling rougher I believe he is misfiring.
kellygnsd is online now   Reply With Quote
Old 07-08-2008, 04:38 PM   #16
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
Yeah I switched the coils around didn't change the misfire. the fuel smell might of come from the fact that I have a High Flow Cobb catt, and the misfire has messed up the catalyist.
Old 07-08-2008, 04:39 PM   #17
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
how could I check if it is a valve problem, is there a visual inpspection I can do or do I have to run some kind of diagnostic?
Old 07-08-2008, 05:11 PM   #18
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
You would have to do a leak down test and if you are leaking then you could check and see if you can feel/hear it leaking out of the exhaust. IIRC 7% is the max for a stock motor.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 07-08-2008, 07:12 PM   #19
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
Just had a thought, could it be my BOV. I have a GFB WRX Hybrid BOV Runing Half recerc and half Atm. Could that be making it too rich when I shift and then cause the misfire? I have had the BOV for years and had no problem with it.
Old 07-09-2008, 02:06 PM   #20
AVANTI R5
Member#: 73805
2017 911 Turbo
Miami Blue/ pdk
^^ get rid of it,esp. while trying to solve a misfire,
Old 07-09-2008, 02:35 PM   #21
sts2689
Member#: 145708
2007 WRX TR
TopSpeed Built =D
Not to give you any scare but I have the same symptoms and ended up blowing a ringland. It seems you have ruled that out but who knows what it could be
sts2689 is offline   Reply With Quote
Old 07-09-2008, 08:18 PM   #22
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Or you had a blown ringland leading to misfires in that cylinder(more likely)
Old 07-09-2008, 10:59 PM   #23
Timdog1650
Member#: 45516
MY04 STi
Hey man, it's Tim from morning muster with the black 04. I would put the stock BPV back on the car asap and take it for a drive on the stock map...see how it feels. The whole "drove through a puddle" thing sounds nasty and would really scare me, but if you have eliminated plugs, coils, and don't suspect the maf, then there's really only a few things it could be.
A leak down test would definitely eliminate the longblock as a source of the problems, assuming it tests normally. After that I would suspect an injector or something electrical that could have gotten wet.
Timdog1650 is offline   Reply With Quote
Old 07-10-2008, 12:49 AM   #24
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
I went to full recerc on the bov, see if that has an effect, If I get the misfire again, i'll pull out the injectors, keep you posted, I hate not knowing the problem.
Old 07-10-2008, 01:03 AM   #25
psychoskip
Member#: 78408
You're not alone man. My car is in the shop right now for the same problem.
Misfire/Rough Idle azguard4 Newbies & FAQs 0 05-04-2009 06:53 PM
Flashing CEL/No codes/Semi Rough Idle- HELP! Gfunk720 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 08-23-2008 03:19 PM
P0301 Misfires - Rough Idle as well jputnam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-14-2008 10:46 PM
P0303 & P0302 Codes, Misfire, Running on 2 Cylinders bigbird Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2004 01:44 PM
