Old 04-19-2008, 12:50 AM   #1
Jose99
Member#: 164319
2013 STi / 08LGT
Default Auto Trans Fluid Question(nooB)
Im just checked my trans fluid and its pretty dark im feeling that its time to change it out its an automatic 20052.5rs and i need help with what would be the best fluid for the trans and differentials so i can do the change thanks for the help
Jose99 is offline   Reply With Quote
Old 04-19-2008, 08:08 AM   #2
mikeythejew
Member#: 141672
Valvoline Maxlife ATF if you need a fluid obtainable outside of a dealership as it is formulated for import trannys better then most other fluids. For the diff I would use valvoline synpower 75w90.
mikeythejew is offline   Reply With Quote
Old 04-19-2008, 10:30 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
does it smell burnt? Not sure about Subaru auto transmissions (I have only had manuals) but for our van, a drain/fill of the transmission gets only a very small portion of the fluid - Honda's "procedure" is to drain fill 5 times (with some driving between cycles, making sure it goes through all the gears) which gets 90% or so of the fluid (via serial dilution) - not the most fun way to change it, but Honda stronly recommends against having the system flushed.
Old 04-19-2008, 12:20 PM   #4
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
I'd agree with mikey's suggestion for MaxLife DEX/MERC ATF. I've used 'universal' or ATF+4 ATFs from SuperTech, Valvoline, and Schaeffer with excellent results. ATFs are not quite so very diverse right now as the automakers would have us believe.
bulwnkl is offline   Reply With Quote
Old 04-19-2008, 09:01 PM   #5
awdguy
Member#: 59101
2004 wrx
white
make sure to get a new trans filter if you change the oil
awdguy is offline   Reply With Quote
Old 04-20-2008, 01:41 AM   #6
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Wrong, Subaru's AT Filter is a non-maintenance item and will last as long as the car does.
formula91 is offline   Reply With Quote
Old 04-20-2008, 10:17 PM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
even so, since it's a relatively inexpensive item, and a clean filter is better (in terms of acting as a flow restrictor) than a dirty one, you might as well change it out when you change the transmission fluid...
Changing auto trans fluid vfr Forester Forum 3 06-22-2006 04:44 PM
Auto Trans fluid change--an easier/more thorough way? sethdorlan Transmission (AT/MT) & Driveline 6 05-14-2004 09:38 PM
How much Auto Trans Fluid does the Torque converter hold? bdoss123 Legacy Forum 5 10-07-2003 07:00 AM
differential and auto trans fluid leaks - Subaru Liberty rjbonde Newbies & FAQs 0 09-17-2003 09:01 AM
