Old 04-19-2008, 01:24 AM   #1
Nuke209
Member#: 108089
2003 WRX
NF Performance
Default Fuel Needle won't go move!
Back in December, my car was rear ended.
So I got it fixed (the car was hit out of state, fixed out of state)
But once close to about 1/5 of a tank, the needle stops there (and that's where it was, when I got hit also)
So I'm sure there's a damage with the fuel sensors.
But what to do to fix this? before I start tearing things apart
Nuke209 is offline   Reply With Quote
Old 04-19-2008, 06:49 AM   #2
6spdawd
Member#: 177862
it might be the whole intank fuel unit try swaping it out with a fellow member.. and see if that fixes it.
6spdawd is offline   Reply With Quote
Old 04-19-2008, 03:16 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
I can do that, but is there any other stuff I should do?
I rather try to narrow down the problem than to just replace the whole thing.
If nothing works, then I'll try replacing the whole thing.
Old 04-20-2008, 09:52 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
there's got to be a fuel level sensor that's been damaged
are you trying to fix this yourself?
did insurance cover your accident?
if so... they should fix the car right....
call your agent and tell em the car is not right is not fixed....
Jamie
04 WRX won't start; fuel pump won't stop priming styng88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 09-19-2008 09:12 PM
Fuel pump won't start, blown fuse SBF 2, car won't start ClassicGC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-29-2008 09:18 PM
omori gauge needle won't light up?? autowagon Interior & Exterior Modification 10 12-12-2005 07:17 AM
needle on gauge moves when turn signal is on Rickyh Electrical & Lighting 2 11-23-2003 11:22 PM
Removing Tacho, Speedo, Temp and Fuel Needles silverbetty Interior & Exterior Modification 8 12-30-2002 09:18 AM
