Old 04-20-2008, 08:24 AM   #1
SubbyOBS
Member#: 124035
99 LOB and RS
Default A/C Compressor problem?
I recently turned on the A/C in my 97 IMP OBS because the hot weather and pollen. The first few times, the A/C compressor went okay without any squeezing or problem.
Today, when I turned the A/C on again, there was a squeezing sound comes out from the A/C compressor. Whenever, the compressor tried to kick on, it blew cool air (~40-50 F checked with infra-red at the vent). But whenever the squeezing sound comes, the air is not that cold at all (~60/70) or I should say just regular air blowing through.
I checked the belt tension and worth outs, it looks okay. I checked the R134 on the L-pressure port (while the a/c running) it is at the green region.
May be it is time for me to replace the A/C Compressor? If so, any instructions that I should take care of before take out the bolts and etc? The engine is 2.2L and it charge with R134.
SubbyOBS is offline   Reply With Quote
Old 04-20-2008, 08:55 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There is no way to properly diagnose your situation from what you have posted. Unless you have the skills/knowledge and tools for AC testing and repair, this is a job best left to a shop. You don't want to just throw expensive parts at it.
Air Compressor Problems wtf vf22-wrx Off-Topic 27 03-22-2008 10:21 PM
Still Have AC Compressor Problem jikhead Service & Maintenance 9 09-24-2007 09:56 AM
AC compressor problems maciek Normally Aspirated Powertrain 3 10-15-2003 02:08 AM
Compressor Surge Problems? RshaoKh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-16-2003 01:32 PM
Compressor stall problem I think. Also, is there a such thing a wastegate slap? knuckles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-19-2002 07:28 PM
